查看: 713|回复: 0
[分享]:绘制SmartSolid立方体源程序。
发表于 2004-9-8 18:01:54 | 显示全部楼层 |阅读模式
最近编写了一个绘制SmartSolid立方体的MDL程序,主要用于查看我程序中设置的扫描范围是否正确(当然是三维中的了!)。源程序如下,供大家分享。
Public void displayRange (DVector3d *rngP, int drawMode)
   MSElementDescr *edP = NULL;
   KIBODY         *bodyP = NULL;
   double         xyz[3];
   xyz[0] = rngP->end.x - rngP->org.x;
   xyz[1] = rngP->end.y - rngP->org.y;
   xyz[2] = rngP->end.z - rngP->org.z;
   mdlKISolid_beginCurrTrans (ACTIVEMODEL);
   mdlCurrTrans_invScaleDoubleArray (xyz, xyz, 3);
   mdlKISolid_makeCuboid (&bodyP, xyz[0], xyz[1], xyz[2]);
   if (bodyP){
      mdlKISolid_bodyToElement (&edP, bodyP, TRUE, -1, NULL, ACTIVEMODEL);
      mdlKISolid_freeBody (bodyP);
   mdlKISolid_endCurrTrans ();
   if (edP){
      Transform      tMatrix;
      Dpoint3d       pt;
      pt.x = (rngP->end.x + rngP->org.x) / 2;
      pt.y = (rngP->end.y + rngP->org.y) / 2;
      pt.z = (rngP->end.z + rngP->org.z) / 2;
      mdlTMatrix_getIdentity(&tMatrix);
      mdlTMatrix_setTranslation (&tMatrix, &pt);
      mdlElmdscr_transform(edP, &tMatrix);
      mdlElmdscr_display (edP, ACTIVEMODEL, drawMode);
      mdlElmdscr_add (edP);
      mdlElmdscr_freeAll (&edP);
这段程序虽不长,但用到了许多MDL中的精华。如果你能不费力地读懂它,说明你的MDL水平应该在中级以上。
GMT+8, 2026-11-4 18:59 , Processed in 0.420759 second(s), 32 queries , Gzip On.
