查看: 664|回复: 2
[ARX程序]:c# Arx2
发表于 2004-9-23 15:39:47 | 显示全部楼层 |阅读模式
#region Using directives
using System;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Colors;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.Runtime;
using DBTransMan=Autodesk.AutoCAD.DatabaseServices.TransactionManager;
using Autodesk.AutoCAD.Interop;
using Autodesk.AutoCAD.Interop.Common;
#endregion
namespace ZHFArxLibrary
    public class Arx
        private Database db;
        private DBTransMan tm;
        private Transaction myT;
        BlockTable bt;
        BlockTableRecord btr;
        public Arx()
            db = HostApplicationServices.WorkingDatabase;
            tm = db.TransactionManager;
        #region Line
        public Line AddLine(Point3d pt1, Point3d pt2)
            Line line;
            try
                Initialize();
                line = new Line(pt1, pt2);
                btr.AppendEntity(line);
                tm.AddNewlyCreatedDBObject(line, true);
                myT.Commit();
            finally
                DisposeAll();
            return line;
        public Line AddLine(Point2d pt1, Point2d pt2)
            Line line;
            line = AddLine(new Point3d(pt1.X, pt1.Y, 0), new Point3d(pt2.X, pt2.Y, 0));
            return line;
        public Line AddLine(Point3d pt1, double x, double y)
            Line line;
            Point3d pt2 = new Point3d();
            pt2.X = pt1.X + x;
            pt2.Y = pt1.Y + y;
            pt2.Z = pt1.Z;
            line = AddLine(pt1, pt2);
            return line;
        public Line AddLineR(Point3d pt1, double angle, double length)
            Line line;
            pt2 = GetPointAR(pt1, angle, length);
            return line;
        #endregion
        public void Initialize()
            myT = tm.StartTransaction();
            bt = (BlockTable)tm.GetObject(db.BlockTableId, OpenMode.ForRead, false);
            btr = (BlockTableRecord)tm.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
        public void DisposeAll()
            bt.Close();
            btr.Close();
            myT.Dispose();
        public Point3d GetPointAR(Point3d pt1,double angle,double length)
            Point3d pt2=new Point3d();
            pt2.X = pt1.X + length * Math.Cos(angle);
            pt2.Y = pt1.Y + length * Math.Sin(angle);
            pt2.Z = pt1.Z;
            return pt2;
发表于 2004-9-28 11:27:36 | 显示全部楼层
还没有学到c#,倒是蛮感兴趣的
发表于 2005-4-12 08:26:06 | 显示全部楼层
可以,继续钻研
GMT+8, 2026-11-6 08:13 , Processed in 0.405910 second(s), 37 queries , Gzip On.
