查看: 1266|回复: 0
[求助]:阵列图块时,图块的动态显示,附一小程序(上一主题不能编辑,重发)
发表于 2008-5-14 15:21:29 | 显示全部楼层 |阅读模式
浩辰暖通中,阵列布置空调风口时,每个图块随着选择范围增大而动态显示,这样的功能用什么程序段实现?
下面的程序,是从他人的程序上改过来的,
(vl-load-com)
(defun C:TT (/ TEST SS TMP MODE PT PT0)
(setq el nil)
(setq p1 (getpoint "\n请点取风口的插入点>: "))
(setq TEST t)
(while TEST
(setq TMP (grread 4 2)
MODE (car TMP)
PT (cadr TMP)
) ; (princ MODE)
(cond
((= MODE 5) ;移动
(setq pt_mid (mapcar '+ p1 pt))
(setq pt_mid (mapcar '/ pt_mid '(2 2 2)))
(setq pt1 (list (nth 0 p1) (nth 1 pt)))
(setq pt2 (list (nth 0 pt) (nth 1 p1)))
(redraw)
(grdraw p1 pt1 7)
(grdraw pt1 pt 7)
(grdraw pt pt2 7)
(grdraw pt2 p1 7)
(if (/= el nil)
(entdel el)
(command "insert" "高效送风口GKF-05A" pt_mid 1 1 0)
(setq el (entlast))
((= MODE 3) ;左击
(entdel el)
(redraw)
(setq TEST NIL)
((= MODE 25) ;右击
(setq el (entlast))(entdel el)
(redraw)
(setq TEST NIL)
(t
;(princ (strcat "\r" (vl-princ-to-string TMP)))
(princ)
将其中的“高效送风口GKF-05A”改为你图中的图块名称就可以了,
请教高手,如何在选取第二个点时,能捕捉点,现在不能精确定位
由于在动态显示风口设备时(因插入图块命令)在命令窗口显示大量的插入图块的信息,现将显示图块用grdraw命令在一子程序中实现单一图块的动态显示,可将该子程序添加命令改成显示任意图的动态显示了程序,程序如下
(vl-load-com)
(defun show_blk        (blk_pt blK_w blk_h /)        ;动态显示单个风口
  (setq        pt_1 (list (- (nth 0 blk_pt) (/ blk_w 2))
                   (- (nth 1 blk_pt) (/ blk_h 2))
  (setq        pt_2 (list (nth 0 pt_1)
                   (+ (nth 1 pt_1) blk_h)
  (setq        pt_3         (list (+(nth 0 pt_2) blk_w)
                (nth 1 pt_2)
  (setq        pt_4 (list (+ (nth 0 pt_1)blk_w)
                   (nth 1 pt_1)
  (grdraw pt_1 pt_2 7)
  (grdraw pt_2 pt_3 7)
  (grdraw pt_3 pt_4 7)
  (grdraw pt_4 pt_1 7)
  (grdraw pt_3 pt_1 6)
  (grdraw pt_2 pt_4 6)
(defun C:TT2 (/ TEST SS TMP MODE PT PT0)
  (setq el nil)
  (setq os (getvar "OSMODE"))
  (setq TEST t)
  (while TEST
          MODE (car TMP)
          PT   (cadr TMP)
    )                                        ;        (princ MODE)
    (cond
      ((= MODE 5)                        ;移动
       (if (setq TMP (osnap PT "end")) ;_捕捉
         (progn
           (setq PT TMP)
           (grdraw PT (polar PT 0 1) 2) ;_显示标记
       (redraw)
       (grdraw p1 pt1 7)
       (grdraw pt1 pt 7)
       (grdraw pt pt2 7)
       (grdraw pt2 p1 7)
       (if (/= el nil)
         (entdel el)
       (setq el (entlast))
       ;(princ "/n插入点:")
      ; (princ pt_mid)
       (setq blk_w 500)
       (setq blk_h 500)
       (show_blk pt_mid blk_w blk_h)
      ((= MODE 3)                        ;左击
      ; (entdel el)
       (redraw)
       (setq TEST NIL)
      ((= MODE 25)                        ;右击
       (setq el (entlast))
       (entdel el)
       (redraw)
       (setq TEST NIL)
      (t
  (setvar "osmode" os)
  (princ)
请各位高手指点,由于在程序中第二点的选取中用osnap来达到了捕捉点的功能 ,却显示不出捕捉的的形式。请教如何才能显示出捕捉点形式。
GMT+8, 2026-11-22 09:24 , Processed in 0.401333 second(s), 10 queries , Gzip On, File On.
