查看: 802|回复: 0
[分享]:MS2004可使用WBLOCK命令,做AUTOCAD块。
发表于 2004-9-23 19:00:17 | 显示全部楼层 |阅读模式
MS2004可使用WBLOCK命令,做AUTOCAD块。选择物体,在KEYIN里面输入WBLOCK。具体看下面内容:
Creating WBlocks in MicroStation as AutoCAD "Cells"
This tip was submitted by Ryan Berger, chief engineering technician and MicroStation administrator at the
Portland, Ore., office of KPFF Consulting Engineers:
Many engineering firms nowadays run multiple CAD platforms, such as our firm. We run
both AutoCAD 2004 and MicroStation V8 2004 Edition.
When working in AutoCAD, there are times when a cell from MicroStation would be useful,
but AutoCAD doesn't use cells. What do you do? Well, when this happened to me I simply
created a WBlock within MicroStation. A WBlock is like a cell and a reference file combined
into one. To create a WBlock in MicroStation V8 2004 Edition, follow these simple steps:
1. Select the MicroStation elements or cell you wish to turn into an AutoCAD WBlock.
2. In your Key-In Browser Toolbar type: wblock
[Editor's note: If MS_DWG_COMMANDPREFIX is set to something other than the
default "", you should use that as the first character instead of ]
3. This brings up a small dialog that prompts you to choose if you want to make a
WBlock out of the entire drawing, a group of selected objects (if a selection set
exists), or a shared cell definition within the current file.
Choose the option that you want from the available selections in the pulldown. If you create
the WBlock from a selection set, two check boxes will become active, one that allows you
to set an insertion point, and another that will allow you to delete the elements you are
WBlocking. Check these if you need them and accept. This brings up the Save Block File,
where you can specify the name and location of
GMT+8, 2026-11-3 20:15 , Processed in 0.473267 second(s), 32 queries , Gzip On.
