查看: 1483|回复: 5
[讨论]:VAV空调系统
发表于 2004-10-8 16:00:07 | 显示全部楼层 |阅读模式
中央空调VAV系统对于,洁净厂房(要求温度、湿度、正压)的中央空调系统是否可以使用?怎样使用?
我们公司厂房车间由七台组合风柜分别送风,满足各个车间的温度、湿度及正压。所有风柜电机全部工频运行,领导想改变频节能,本人愚钝,不知如何控制,请大家帮帮忙!
发表于 2004-10-12 14:52:18 | 显示全部楼层
采用vav fume hood不就可以了吗?
 楼主| 发表于 2004-10-14 09:42:03 | 显示全部楼层
能否说具体点!谢谢!
发表于 2004-10-14 14:38:38 | 显示全部楼层
Fume hoods are used by pharmaceutical companies, universities, industrial companies and government agencies as safety devices. Since the early 1980's, these organizations have had the option of installing Variable Air Volume (VAV) fume hood controllers. VAV hood controllers provide added safety by maintaining a constant face velocity at all sash openings and also provide energy savings by minimizing the volume of exhausted air.
One issue that must be considered when specifying VAV controls is speed of response. The controller and associated exhaust system components must be able to respond to sash movements and other changing conditions with sufficient speed so that potentially hazardous fumes within the hood cannot escape.
 楼主| 发表于 2004-10-21 17:36:12 | 显示全部楼层
Thank you!
发表于 2005-1-12 10:09:11 | 显示全部楼层
我们在生物安全实验室里经常用VAV系统,但主要是调节风量,现在还没有考虑到节能的问题.
主要的做法是用风管静压控制风机变频来调整送风量,再用室内外的压差调整支管上的变风量阀保证室内外的压差,变风量阀一般选用与压力无关的文丘里阀,据我所知,现在中国建研院空调所的人也在推这种阀.
我想可不可以从送风排风管道上安装变风量阀,精确的保证压差,用室内的温湿度控制一下风机的送风量,我想就可以起到节能的作用.
我想节能主要是想减少冷热水的用量,我风机的用电量,这需要仔细做一下技术经济分析.
GMT+8, 2026-11-2 23:12 , Processed in 0.467225 second(s), 42 queries , Gzip On.
