查看: 1406|回复: 1
[其他]:GRAPHISOFT_ARCHICAD_V9.0_R1_INTERNATIONAL
发表于 2004-10-9 09:02:44 | 显示全部楼层 |阅读模式
10.08.04.GRAPHISOFT_ARCHICAD_V9.0_R1_INTERNATIONAL_ISO-LND
ArchiCAD offers a different approach to your workflow process, which gives
you more control over your design, while maintaining accuracy and efficiency
in documentation. While you raise walls, lay floors, add doors and windows,
build stairs and construct roofs this Building Information Authoring Tool
creates a central database of 3D model data. From this you can extract all
the information needed to completely describe your design - complete plans,
sections and elevations, architectural and construction details, bills of
material, window/door/finish schedules, renderings, animations and virtual
reality scenes. That means while you're designing, ArchiCAD is creating all
the project documentation so there's little repetitive and tedious drafting
work. And unlike designing in 2D software, the Virtual BuildingTM approach
also means that you can make changes at any time maintaining the integrity
of your documents, without risking costly errors or costing you productivity.
http://www.graphisoft.com/products/archicad/
发表于 2004-10-11 05:52:50 | 显示全部楼层
是介绍,我还以为是下载,bs自己一下!
GMT+8, 2026-11-22 08:20 , Processed in 0.276936 second(s), 13 queries , Gzip On, File On.
