查看: 2307|回复: 7
[讨论]:Mtext带格式的字符串如何提取处纯文本?
发表于 2004-10-13 19:53:12 | 显示全部楼层 |阅读模式
如果纯粹直接识别字符串 有点麻烦,等于要自己写编译代码
下面一个串的例子
ABCDEFG\\\{你\\\}好MT{\f新宋体|b0|i0|c134|p49;E\P\PXT\}你为}和{\H0.8x;这么}罗嗦
发表于 2004-10-13 20:22:41 | 显示全部楼层
1.vlisp方法.因为取实体表dxf组码,或vla方法取textstring,都返回如上带mtext文字格式代码,处理起来比较麻烦. xd和明经都有过实例.你找一下,可供参考.
(不推荐,当然要是能写出来,说明你的水平已经不俗了)
2.哈哈,还有什么.你炸了它!!!
炸开后的文字实体是按顺序的.
用(while (setq e (entnext e) .....) 提取并处理.然后删除炸开的文字.
一般推荐.应用可以,写成函数就不太好了:)
发表于 2004-10-13 20:31:16 | 显示全部楼层
Steve Doman有这样一个VLisp程序,你可以参考一下:
STRIPMTEXT[3].LSP
[php];|
StripMtext v3.07 for AutoCAD 2000 thru 2004
This program creates a user command that will quickly remove
formatting applied to individual characters and words inside
Mtext objects.
StripMtext can remove the following types of formatting:
Alignment
Color
Font
Height
Underscore
Overscore
Linefeed (Paragraph Return)
Obliquing
Stacking
Tracking
Width
Non-breaking Space
StripMtext does not modify Mtext properties such as style,
justification, width, and rotation.  Nor does it manipulate
inherited properties such as layer, entity color, etc.
Note:
Removing Mtext formatting is a very complex procedure.  This program
has been designed to safely remove formatting but no guarantee
exist.  Until you become familiar with StripMtext, please save your
drawing before using.  If you do not like the results, you can
immediatly issue an Undo command to restore your Mtext to its prior
condition.  You are encouraged to spend a few minutes experimenting
with different format removal settings on sample drawings before
using this program on your real drawings.
How to use:
(1) When you start StripMtext, you will be asked to select Mtext and
    Dimension objects.
(2) After you have completed selecting, a dialog box will appear
    that contains several check boxes labeled with formatting names.
    Check mark each type of formatting you want removed.
(3) If you would like StripMtext to use your current check marked
    formats as your default, check mark the "Remember Settings" box.
(4) Hit OK to process, or Cancel to abort.
History:
v1.0 11-17-1999
Removes font formatting from Mtext objects
v2.0 08-25-2001
Faster speed and removes all formatting from Mtext (except linefeed)
v3.0 05-26-2003
Improved format removal by replacing prior format strip functions
with John Uhden's more robust 'UnFormat function.
Added Support for dimension Mtext.
Added dialog so user can choose which formatting to remove.
Added feature to save default format options
v3.05 01-14-04
"Quit/Exit" Bug fixed
v3.06 03-21-04
Only changes to comments, otherwise same as v3.05
v3.07 04-15-04
Fixed a "Unknown dimension" bug when drawing contained 2LineAngular dimensions.
Thanks to Keith Kempker for reporting this error and for helping with debugging.
Credits:
John Uhden for donating his brillant and robust 'UnFormat function
which perfoms the actually format parsing.
Joe Burke, the Number 1 user and beta tester!
User interface written by Steve Doman
This program is donated to the public domain.
Anyone experiencing any bugs or annoyances from this program is
encourage to report them so that it can continue to be improved.
Without feedback, nothing happens.
Please send comments, wish list, or bug reports to: sdoman@qwest.net
(defun c:StripMtext ( /
  ; Functions
  *error*
  AcceptButton
  ClearAllButton
  MainDialog
  SelectAllButton
  Setup
  StripMtext
  Unformat
  ; Variables
  dcl_id
  dclfilemsg
  dclfilename
  dialogmsg
  keylist
  modcnt
  save
  settings
  space
  ss
  tilemsg
  versionmsg
  ;;; Local functions
  (defun *error* (msg)
    (if docobj (vla-endundomark docobj))
    (cond
      ((member msg
         '("Function cancelled"
           "quit / exit abort"
           "console break"
      ((princ (strcat " Error: " msg)))
    (princ)
  (defun SelectAllButton ()
    (foreach key keylist (set_tile key on))
    (set_tile "error" "")
    (mode_tile "accept" 2)
  (defun ClearAllButton ()
    (foreach key keylist (set_tile key off))
    (set_tile "error" tilemsg)
  (defun AcceptButton ()
    ;Build string to be passed later to the unformat function
    ;Strcat key character for each checkmarked key
    (setq settings "")
      (if (= (get_tile key) on)
        (setq settings (strcat settings key))
    ;If no keys are checkmarked, show error message
    ;Else if save is enabled, save settings to registry
    (if (= settings "")
      (progn
        (if (= (get_tile "save") on)
          (progn
            (vl-registry-write StripMtextKey "Settings" settings)
            (vl-registry-write StripMtextKey "Save" on)
          (vl-registry-write StripMtextKey "Save" off)
        (if (= (strlen settings) (length keylist))
          (setq settings "*")
      );progn
  (defun MainDialog ( / status done)
    ;Display checkbox default values and define checkbox callbacks
    (set_tile "save" save)
      (if (vl-string-search key settings)(set_tile key on))
      (action_tile key "(set_tile \"error\" \"\" )" )
    ;Define button callbacks
    (action_tile "clearall" "(ClearAllButton)")
    (action_tile "selectall" "(SelectAllButton)")
    (action_tile "accept" "(AcceptButton)(done_dialog 1)")
    (action_tile "cancel" "(done_dialog 0)")
    (setq status (start_dialog))
    (unload_dialog dcl_id)
    ;Return key used to close dialog
    ;If status = 0 , then Cancel button hit
    ;If status = 1 , then Accept button hit
    status
  ; The following function was written by John Uhden
  ; This version of Unformat is slightly modified from the original.
  ; Thanks John!
  ; Primary function to perform the format stripping:
  ; Arguments:
  ;   Mtext   - the text string to be Unformatted
  ;   Formats - a string containing some or all of
  ;             the following characters:
  ;     A - Alignment
  ;     C - Color
  ;     F - Font
  ;     H - Height
  ;     L - Underscore
  ;     O - Overscore
  ;     P - Linefeed (Paragraph)
  ;     Q - Obliquing
  ;     S - Spacing (Stacking)
  ;     T - Tracking
  ;     W - Width
  ;     ~ - Non-breaking Space
  ;   Optional Formats -
  ;     * - All formats
  ; Returns:
  ;   nil  - if not a valid Mtext object
  ;   Text - the Mtext textstring with none, some, or all
  ;          of the formatting removed, depending on what
  ;          formats were present and what formats were
  ;          specified for removal.
  (defun UnFormat (Mtext Formats / All Format1 Format2 Text Str)
    (and
      Mtext
      Formats
      (= (type Mtext) 'STR)
      (= (type Formats) 'STR)
      (setq Formats (strcase Formats))
      (setq Text "")
      (setq All T)
      (if (= Formats "*")
        (setq Formats "S"
              Format1 "\\[LO`~]"
              Format2 "\\[ACFHQTW]"
              Format3 "\\P"
        (progn
          (setq Format1 "" Format2 "" Format3 "")
          (foreach item '("L" "O" "~")
            (if (vl-string-search item Formats)
              (setq Format1 (strcat Format1 "`" item))
              (setq All nil)
          (if (= Format1 "")
            (setq Format1 nil)
            (setq Format1 (strcat "\\[" Format1 "]"))
          (foreach item '("A" "C" "F" "H" "Q" "T" "W")
              (setq Format2 (strcat Format2 item))
              (setq All nil)
          (if (= Format2 "")
            (setq Format2 nil)
            (setq Format2 (strcat "\\[" Format2 "]"))
          (if (vl-string-search "P" Formats)
            (setq Format3 "\\P")
            (setq Format3 nil All nil)
          T
      (while (/= Mtext "")
        (cond
          ((wcmatch (strcase (setq Str (substr Mtext 1 2))) "\\[\\{}]")
            (setq Mtext (substr Mtext 3)
                  Text   (strcat Text Str)
          ((and All (wcmatch (substr Mtext 1 1) "[{}]"))
            (setq Mtext (substr Mtext 2))
          ((and Format1 (wcmatch (strcase (substr Mtext 1 2)) Format1))
            (setq Mtext (substr Mtext 3))
          ((and Format2 (wcmatch (strcase (substr Mtext 1 2)) Format2))
            (setq Mtext (substr Mtext (+ 2 (vl-string-search ";" Mtext))))
          ((and Format3 (wcmatch (strcase (substr Mtext 1 2)) Format3))
            (if
              (or
                (= " " (substr Text (strlen Text)))
                (= " " (substr Mtext 3 1))
               (setq Mtext (substr Mtext 3) Text (strcat Text " "))
          ((and (vl-string-search "S" Formats)(wcmatch (strcase (substr Mtext 1 2)) "\\S"))
            (setq Str   (substr Mtext 3 (- (vl-string-search ";" Mtext) 2))
                  Text  (strcat Text (vl-string-translate "#^\\" "/^\\" Str))
                  Mtext (substr Mtext (+ 4 (strlen Str)))
          (1
            (setq Text (strcat Text (substr Mtext 1 1))
    Text
  (defun StripMtext (ss / docobj cnt mtextobj objname txtprop txtvalue errobj)
    ;The argument 'ss must be a pickset containing at least
    ;one Mtext or Dimension entity
    ;Repeat for each entity in pickset:
    ;  Get Mtext textstring and pass it to the Unformat function
    ;  Put returned stripped textstring back into entity
    ;  If successful, increment count of modified entities
    (vl-load-com)
    (setq
      docobj (vlax-get-property (vlax-get-acad-object) "ActiveDocument")
      cnt 0
      modcnt 0
    (vla-startundomark docobj)
    (repeat (sslength ss)
      (setq
        mtextobj (vlax-ename->vla-object (ssname ss cnt))
        objname (vlax-get-property mtextobj "ObjectName")
        txtprop (cond
                  ((= objname "AcDbMText")
                     "Textstring"
                  ((member objname
                     '("AcDb3PointAngularDimension"
                       "AcDbAlignedDimension"
                       "AcDbAngularDimension"
                       "AcDb2LineAngularDimension"
                       "AcDbDiametricDimension"
                       "AcDbOrdinateDimension"
                       "AcDbRadialDimension"
                       "AcDbRotatedDimension"
                     "Textoverride"
                   (t
                     (alert
                       (strcat "StripMtext Error:"
                               "\nSorry, unknown dimension type"
                               "\n"
                               "\nPlease report error to:"
                               "\nsdoman@qwest.net"
        txtvalue (vlax-get-property mtextobj txtprop)
        errobj (vl-catch-all-apply
                 'vlax-put-property
                 (list
                   mtextobj
                   txtprop
                   (Unformat txtvalue settings)
        modcnt (if (not (vl-catch-all-error-p errobj))(1+ modcnt))
        cnt (1+ cnt)
      );setq
    );repeat
  (defun Setup ()
    (setq
      ;--- Set Constants ---
      ;Toggles for dcl checkbox status
      on  "1"
      off "0"
      ;Error messages
      tilemsg     "Select one or more settings or press \"Cancel\" to exit"
      versionmsg  "StripMtext error:\nRequires AutoCAD 2000 or higher"
      dialogmsg   "StripMtext error:\nUnable to load dialog"
      dclfilemsg  "StripMtext error:\nCannot load DCL file \"StripMtext[3].dcl\""
      ;DCL file
      dclfilename "StripMtext[3].dcl"
      ;List of dcl checkbox key names
      ;Must correspond with DCL keys and Unformat function
      keylist '("A" "C" "F" "H" "L" "O" "P" "Q" "S" "T" "W" "~")
      ;Registry path for storing user's settings
      StripMtextkey "HKEY_CURRENT_USER\\SOFTWARE\\StripMtext\\"
      ;--- Set Defaults ---
      ;Get user's default settings from registry if exist
      ;If user has not saved default settings, use coded default
      settings (cond
                 ((vl-registry-read StripMtextKey "Settings"))
                 ((vl-registry-write StripMtextKey  "Settings" "CFH"))
      save    (cond
                 ((vl-registry-read StripMtextKey "Save"))
                 ((vl-registry-write StripMtextKey "Save" "1"))
    );setq
  ;;; Main Program
  (princ "\nStripMtext v3.07")
  (Setup)
  (cond
    ;Running in Acad 2000 or above
    ((< (atoi (getvar "acadver")) 15)
     (alert versionmsg)
    ;Find dcl file
    ((< (setq dcl_id (load_dialog dclfilename)) 0)
     (alert dclfilemsg)
    ;Succesful pickset
    ((not (setq ss (ssget ":L" '((0 . "MTEXT,DIMENSION") ))))
      (princ "\nNothing selected")
    ;Successful dcl load
    ((not (new_dialog "stripmtext" dcl_id))
      (alert dialogmsg)
    ;If user exits dcl using Accept button, process pickset
    ((= (MainDialog) 1)
       ;Process
       (StripMtext ss)
       ;Display count of stripped objects
       (princ
         (strcat
          "\nStripped: " (itoa modcnt) " mtext object"
          (if (= 1 modcnt) " " "s ")
  );cond
  (princ)
);program
(princ "\nStripMtext v3.07 loaded. Start command by typing \"STRIPMTEXT\" ")
(princ)
[/php]
STRIPMTEXT[3].DCL
[php]
/// StripMtext[3].DCL Steve Doman sdoman@yahoo.com
stripmtext : dialog {
  label = "StripMtext v3.06";
  spacer_1;
    : toggle {
        label = "Remember Settings";
        key =  "save";
        fixed_width = true;
     spacer_1;
     : boxed_row {
       label = "Select type of formats to remove";
         : column {
             : toggle {
                 label = "Alignment";
                 key = "A";
                 fixed_width = true;
             : toggle {
                 label = "Color";
                 key = "C";
                 fixed_width = true;
             : toggle {
                 label = "Font";
                 key = "F";
                 fixed_width = true;
             : toggle {
                 label = "Height";
                 key = "H";
                 fixed_width = true;
             : toggle {
                 label = "Underline";
                 key = "L";
                 fixed_width = true;
             : toggle {
                 label = "Overscrore";
                 key = "O";
                 fixed_width = true;
         : column {
             : toggle {
                 label = "Linefeed";
                 key = "P";
                 fixed_width = true;
             : toggle {
                 label = "Oblique";
                 key = "Q";
                 fixed_width = true;
             : toggle {
                 label = "Stacking";
                 key = "S";
                 fixed_width = true;
             : toggle {
                 label = "Tracking";
                 key = "T";
                 fixed_width = true;
             : toggle {
                 label = "Width";
                 key = "W";
                 fixed_width = true;
             : toggle {
                 label = "Non-breaking Space";
                 key =  "~";
                 fixed_width = true;
                 width = 1;
         : column {
             : button {
                key = "selectall";
                label = "Select All";
             : button {
                 key = "clearall";
                 label = "Clear All";
              : spacer {
                  height = 4.0;
    : column {
        errtile;
        ok_cancel;
[/php]
发表于 2004-10-13 21:53:52 | 显示全部楼层
参考:
;;;MTEXT文本提取
;;;WBTQ.lsp 文本提取
;;;* C:WBTQ
;;;-- XYP@bsedi.com
;;;2004.10.13
(prompt "\n\r      加载文本提取(MTEXT)程序。")
(DEFUN C:WBTQ(/ aa bb a nn n m txt)
  (while (/= aa "MTEXT")
    (setq bb (entsel) aa (dxf 0 (entget (car bb))))
  (setq a (DXF 1 (entget (car bb)))
        nn (strlen a)
        n 1
  (while (/= (substr a n 1)";")
    (setq n (+ 1 n))
  (setq m n)
  (while (/= (substr a m 1)"}")
    (setq m (+ 1 m))
  (setq txt (substr a (+ 1 n) (- m n 1))
        TXT (STRCAT "Mtext文本 : " txt)
  (alert txt)
  ;(princ txt)
  (pxyp"WBTQ      (文本提取MTEXT)")
(defun dxf (code elist) (cdr (assoc code elist)))
(DEFUN PXYP (TXT1)
  (SETQ        TXT1 (STRCAT "\n\r      程序命令: "  TXT1 "      -- XYP@bsedi.com"))
  (PRINC TXT1)
  (princ)
  );defun
(princ)
;;;END
加载wbtq.lsp,运行wbtq。
请斑竹指教!
 楼主| 发表于 2004-10-14 10:22:25 | 显示全部楼层
aidraft
提供的函数丢失了很多重要字符,看起来困难。
楼上的显然太简单了 我提供的字符串就无法识别,而且未考虑组码3
对mtext格式字符识别其实也不是很复杂的事情, 只是一个简单的编译问题。
但由于没有资料 不知道有哪些格式控制符号,或者有哪些更直接的方法,
但炸开法对于字符串长的时候好像蛮危险的,
发表于 2004-10-14 13:00:34 | 显示全部楼层
本版版主hww写过一个,我觉得不错.
好像没有在论坛发表过.我只是帮他测试
发表于 2019-7-10 23:13:33 来自手机 | 显示全部楼层
我采取的是临时炸开的方式(应用在提取线+文字的自绘表格中提取文字,正好我写了水单元格列线判断,不怕文字炸断了)
来自: 微社区
已领礼包: 22个
发表于 2021-9-17 16:01:50 | 显示全部楼层
很久远的主版了,不知道有关MTEXT格式的最新版?
GMT+8, 2026-11-3 07:30 , Processed in 0.703970 second(s), 47 queries , Gzip On.
