查看: 1536|回复: 0
[日积月累]:修复硬盘分区FIXHDPT V2
发表于 2003-1-11 00:24:53 | 显示全部楼层 |阅读模式
修复硬盘分区FIXHDPT V2.0的源程序
2001年08月08日 阅读次数: 279
该程序对FAT 16的修复很有效,对FAT 32扩展分区(D、E等)的修复也很有效,对FAT 32主分区的修复只要稍作修改也可以使用。
    本程序用Borland C++ 3.1或者Turbo C++ 3.0编译,其中的MBR_DATA.H头文件由后面给出的MBR2C程序自动从正常的硬盘引导区中提取。
    FIXHDPT.CPP源程序:
#include
#include
#include
#include
#include
#include
#include
#include "mbr_data.h"
typedef struct {
 unsigned char Head,Sector,Track;
 } HST;
typedef struct {
 unsigned char ActiveSign;
 HST PTBegin;
 unsigned char PTType;
 HST PTEnd;
 unsigned long PTBeginID;
 unsigned long PTSize;
 } HDPT;
HDPT HDPT1,HDPT2;
unsigned int MaxHead,MaxTrack,MaxSector;
int MainMenu(void);
int WarningPrompt(char *Message);
void DetectHD(void);
void RewriteMBR(void);
void FixHDPT(void);
void ClearHDPT(void);
void AutoFixHD(void);
void QuickFdisk(void);
void RebootComputer(void);
HST HDToHST(unsigned int Head1,unsigned int Track1,unsigned int Sector1);
void HSTToHD(HST HST2,unsigned int &Head2,unsigned int &Track2,
unsigned int &Sector2);
unsigned int SearchHD(void);
void ReCreateHDPT(unsigned int BeginTrack);
int main(int argc,char *argv[])
 printf("FIXHDPT V2.0\n");
 printf("Fix Hard Disk Partition Table Tool\n");
 printf("Copyright(C) by Zhao Shi-ping\n");
 printf("TBsoft Software Studio  1997/10\n\n");
 if(argc==2)
  if(stricmp(argv[1],"/?")==0)
   printf("Usage:\n");
   printf("    FIXHDPT /? : View help information.\n");
   printf("    FIXHDPT /R : Rewrite MBR.\n");
   printf("    FIXHDPT /F : Fix HD partition table.\n");
   printf("    FIXHDPT /C : Clear HD partition table.\n");
   printf("    FIXHDPT /A : Automatic Fix HD.\n");
   printf("    FIXHDPT /Q : Quick fdisk.\n");
   printf("    FIXHDPT /B : Reboot computer.\n\n");
   printf("    If the command line didn''t have command line parameters,
FIXHDPT V2.0\n");
   printf("could view its menu !\n");
   exit(0);
  if(stricmp(argv[1],"/R")==0)
   RewriteMBR();
   exit(0);
  if(stricmp(argv[1],"/F")==0)
   FixHDPT();
   exit(0);
  if(str
GMT+8, 2026-11-22 09:25 , Processed in 0.351084 second(s), 11 queries , Gzip On, File On.
