查看: 895|回复: 1
[求助] [求助]:请问怎样可以通过"A1"而不是行列号来访问Excel的Cell
发表于 2004-10-22 15:48:10 | 显示全部楼层 |阅读模式
请高手多多指教.
发表于 2004-10-22 16:37:13 | 显示全部楼层
(defun c:aaaa(/ xy excelapp activeworkbook sheets sheet sheetname value)
(vl-load-com)
(setq xy (getstring "\nrow column value(A1,b2):"))
(setq excelapp (vlax-get-object "excel.application")
      activeworkbook (vlax-get-property excelapp "activeworkbook")
      sheets (vlax-get-property activeworkbook "worksheets")
      sheet (vlax-get-property sheets "item"
                   (setq sheetname (vlax-get-property (vlax-get-property excelapp 'Activesheet) "name")))
(setq value (vlax-variant-value (vlax-get-property (vlax-get-property sheet "range" xy) "value")))
(princ ( vlax-get-property excelapp "name"))(princ " \\ ")
(princ (vlax-get-property activeworkbook "path")) (princ " \\ ")
(princ (vlax-get-property activeworkbook "name"))(princ " \\ ")
(princ sheetname)(princ " \\ ")
(princ value)
(princ)
GMT+8, 2026-11-5 10:56 , Processed in 0.345114 second(s), 34 queries , Gzip On.
