查看: 827|回复: 1
[ARX程序]:晓东!请问……?
发表于 2003-1-13 20:43:09 | 显示全部楼层 |阅读模式
晓东!请问我自定义了标注样式"USER";请问用哪个函数可以把他设置成默认的函数;还有哪个函数可以得到当前标注样式列表?
已领礼包: 145个
发表于 2003-1-13 20:48:13 | 显示全部楼层
Re: [ARX程序]:晓东!请问……?
最初由 sickman 发布
[B]晓东!请问我自定义了标注样式"USER";请问用哪个函数可以把他设置成默认的函数;还有哪个函数可以得到当前标注样式列表? [/B]
1、设置成默认的函数是什么意思?
2、你可以直接用 AcDbSymbolUtilities::getDimStyleId 获得具体名字的尺寸样式的ID,然后你就可以对这个对象进行操作了。
  1. <normalfont>
  2. AcDbSymbolUtilities::getDimStyleId Function inline Acad::ErrorStatus
  3. getDimStyleId(
  4. AcDbObjectId & objId,
  5. const char * name,
  6. AcDbDatabase * pDb);
  7. objId Output AcDbObjectId of found symbol record
  8. name Input pointer to symbol name to find
  9. pDb Input pointer to database to access
  10. Retrieves the AcDbObjectId for a symbol record given name, the name of the symbol, and pDb,
  11. \a pointer to the database that contains the dimstyle table. If the function succeeds,
  12. it returns the AcDbObjectId in objId and returns Acad::eOk.
  13. This function opens the table and looks for the specified record. If successive calls are necessary,
  14. open the table directly instead of incurring the overhead of repeatedly opening and closing the table
  15. using this function.
  16. </normalfont>
GMT+8, 2026-11-3 07:02 , Processed in 0.393635 second(s), 32 queries , Gzip On.
