查看: 3729|回复: 25
[日积月累]:自认最快捷最省时省事的ACAD.PGP
发表于 2004-11-3 17:17:23 | 显示全部楼层 |阅读模式
自认最快捷最省时省事的ACAD.PGP
; [AutoCAD Command Aliases]
A,         *exchprop  R14的属性面板(简单明了,但必须有exchprop.lsp exchprop.dcl ac_bonus.lsp 附件我会提供下载,下载之后解压到CAD的SUPPORT下,因为版主从不给我加分,所以我就收费了,希望物有所值)
AA,        *Matchprop  特性匹配
AC,        *Arc
AE,        *Area
AL,        *Align   对齐
AP,        *Appload
AR,        *Array
B,         *Bmake
-B,        *Block
BH,        *Bhatch
BO,        *Boundary
-BO,       *-Boundary
BR,        *Break
C,         *Copy
CC,        *Circle
CP,        *Copy
D,         *Dist
DD,        *Ddim
DIV,       *Divide
DDD,       *Dimlinear
DT,        *Dtext
E,         *Erase
ED,        *Ddedit
EL,        *Ellipse
EX,        *Extend
EXIT,      *Quit
EXP,       *Export
EXT,       *Extrude
F,         *Fillet
FI,        *Filter
G,         *Group
-G,        *Group
H,         *Bhatch
-H,        *Hatch
HE,        *Hatchedit
HI,        *Hide
I,         *Ddinsert
-I,        *Insert
J,         *Align   对齐
L,         *Line
LA,        *Layer
-LA,       *-Layer
LE,        *Leader
LEAD,      *Leader
LEN,       *Lengthen
LI,        *List
LT,        *Linetype
-LT,       *-Linetype
LTS,       *Ltscale
M,         *Mirror
ME,        *Measure
ML,        *Mline
MS,        *Mspace
MT,        *Mtext
MV,        *Mview
N,         *Move
O,         *Offset
OS,        *Ddosnap
-OS,       *-Osnap
P,         *Pan
PA,        *Pastespec
PE,        *Pedit
PL,        *Pline
PO,        *Point
POL,       *Polygon
PR,        *Preferences
PRE,       *Preview
PRINT,     *Plot
PS,        *Pspace
PU,        *Purge
Q,         *Pan
-Q,        *-Pan
R,         *Rotate
RW,        *Redraw
S,         *Stretch
SB,        *SNAPBASE  定义原点
SC,        *Scale
SN,        *Snap
SO,        *Solid
SP,        *Spell
SPE,       *Splinedit
SPL,       *Spline
ST,        *Style 文字样式
T,         *Trim
-T,        *-Mtext
TA,        *layon  开所有层(要安EXPREE)
TE,        *extrim 超级剪切(要安EXPREE)
TH,        *Thickness
TI,        *Tilemode
TM,        *Tilemode
TO,        *Toolbar
TOL,       *Tolerance
TOR,       *Torus
TT,        *Mtext
TTA,       *laythw 解冻所有层(要安EXPREE)
UC,        *Dducs
UCP,       *Dducsp
UN,        *Ddunits
-UN,       *Units
UNI,       *Union
V,         *Move
-V,        *View
VP,        *Ddvpoint
-VP,       *Vpoint
VV,        *Ddview
W,         *ai_molc 选择将使其图层成为当前图层(要安EXPREE)
WA,        *LMAN 图层管理(要安EXPREE)
WB,        *Wblock
WC,        *LAYcur 使物体转为当前层(要安EXPREE)
WD,        *LAYOFF 关闭层(要安EXPREE)
WE,        *Wedge
WF,        *LAYFRZ 冻结层(要安EXPREE)
WS,        *LAYISO 只显所选当前层(要安EXPREE)
X,         *Explode
Z,         *Zoom
这些就是我平时常用的!附件在我的另一个帖子提供,里面有更详细的介绍!
直接点击我下面个性签名提供的链接(紫红色的:***修改了的双击属性修改对话框)就可以到我说的帖子!
发表于 2004-11-3 21:41:00 | 显示全部楼层
来点相似的:
;;;*------------------ 画线缩写 -------------------------------------
(defun c:l () (command "line"))                            ;线
(defun c:lc () (command "line" "cen"))                    ;圆心
(defun c:lcc () (command "line" "cen" pause "cen")) ;圆心-圆心
(defun c:lce () (command "line" "cen" pause "end")) ;圆心-端点
(defun c:lci () (command "line" "cen" pause "int")) ;圆心-交点
(defun c:lcm () (command "line" "cen" pause "mid")) ;圆心-中点
(defun c:lcp () (command "line" "cen" pause "per")) ;圆心-垂点
(defun c:le () (command "line" "end"))                    ;端点
(defun c:lec () (command "line" "end" pause "cen")) ;端点-圆心
(defun c:lee () (command "line" "end" pause "end")) ;端点-端点
(defun c:lei () (command "line" "end" pause "int")) ;端点-交点
(defun c:lem () (command "line" "end" pause "mid")) ;端点-中点
(defun C:lep () (command "line" "end" pause "per")) ;端点-垂点
(defun c:lic () (command "line" "int" pause "cen")) ;交点-圆心
(defun c:lie () (command "line" "int" pause "end")) ;交点-端点
(defun c:lii () (command "line" "int" pause "int")) ;交点-交点
(defun c:lim () (command "line" "int" pause "mid")) ;交点-中点
(defun c:lip () (command "line" "int" pause "per")) ;交点-垂点
(defun c:lm () (command "line" "mid"))                    ;线中点
(defun c:lmc () (command "line" "mid" pause "cen")) ;中点-圆心
(defun c:lme () (command "line" "mid" pause "end")) ;中点-端点
(defun c:lmi () (command "line" "mid" pause "int")) ;中点-交点
(defun c:lmm () (command "line" "mid" pause "mid")) ;中点-中点
(defun c:lmp () (command "line" "mid" pause "per")) ;中点-垂点
(defun c:ln () (command "line" "int"))                    ;交点
 楼主| 发表于 2004-11-5 11:27:50 | 显示全部楼层
我提供的exchprop.lsp exchprop.dcl ac_bonus.lsp 保证能在CAD2002和CAD2005用,而且不会导致CAD2005部分命令使用不了的情况,因为我修改了ac_bonus.lsp使得原来是EXPREE的命令而今为CAD2005的命令能正常使用!
我还是喜欢R14的属性修改界面,简单明了,改完属性就自动关掉,不像CAD2002以上的属性修改界面那样要用就必需占视窗空间,而且不能自动关闭。
发表于 2004-11-16 16:25:26 | 显示全部楼层
楼主真热心,还详细介绍了自定的快捷键,我发现快捷键都基本上设在左手能及的位置上,而且图层管理的快捷键很实用!谢谢!
发表于 2004-11-18 01:39:10 | 显示全部楼层
我也 是常用CAD画图,自己也改了一部份键的设定
发表于 2004-11-18 21:55:54 | 显示全部楼层
快捷键都被我改得面目全非了
发表于 2004-11-19 10:21:04 | 显示全部楼层
楼主的快捷键设的很合理,可惜我已经用惯了自己设置的,要改太难了。
发表于 2004-11-19 17:30:52 | 显示全部楼层
感谢楼主提供,尤其是EXPREE部分非常精彩,对图层的控制VERY GOOD!内容写得很清楚,不用下载文件也可以自己更改PGP了:)
发表于 2004-11-20 00:44:34 | 显示全部楼层
再设置下去的话我的快捷键就升四位了,呵呵~~~
发表于 2004-12-16 20:54:24 | 显示全部楼层
其实快捷就是把常用的定义在键盘上加快ACAD的绘图操作,多了反而记不着,反而用不了,最好是边用边加.那才真正叫快捷!
发表于 2005-1-6 22:12:18 | 显示全部楼层
最初由 bluestarqq 发布
[B]楼主的快捷键设的很合理,可惜我已经用惯了自己设置的,要改太难了。 [/B]
同意!
对啊!各有各的绝招。
熟能生巧啊! 熟练了自然就快了。
发表于 2005-1-21 11:13:19 | 显示全部楼层
AA, *Matchprop 特性匹配,和我设置一样啊,1,2,3,4,5是我的隐藏,显示,冻结等,这么久了,很快的
发表于 2005-2-20 07:39:26 | 显示全部楼层
最初由 whhhx 发布
[B]其实网上早就有专门的左手键训练教程下载了,我用了以后,就再也不愿改回默认设置,左手键盘,右手鼠标多方便呀 [/B]
如果在别人的机器上作图还顺手乎?我建议新手还是把系统默认的各键搞清楚,最起码要把常用命令名称记一下,等会用了,若确实感觉系统默认的各键不是太顺手,再改,这样在新的机器环境中摸不到北。
发表于 2005-2-20 19:14:40 | 显示全部楼层
左手键训练教程请问哪里有下载阿?
发表于 2005-3-1 11:41:22 | 显示全部楼层
我是做市政道路设计的,看我用的快捷键,全是左手键。
保证好用。
GMT+8, 2026-11-3 15:06 , Processed in 0.803069 second(s), 61 queries , Gzip On.
