楼主: jeepsheep
[日积月累]:自认最快捷最省时省事的ACAD.PGP
发表于 2005-3-4 10:45:48 | 显示全部楼层
3A,        *3DARRAY
3F,        *3DFACE
3P,        *3DPOLY
A,         *ARC
AA,        *AREA
AL,        *ALIGN
AP,        *APPLOAD
AR,        *ARRAY
AAD,       *ASEADMIN
AEX,       *ASEEXPORT
ALI,       *ASELINKS
ASQ,       *ASESQLED
ARO,       *ASEROWS
ASE,       *ASESELECT
AT,        *DDATTDEF
-AT,       *ATTDEF
ATE,       *DDATTE
-ATE,      *ATTEDIT
BM,        *BMAKE
-B,        *BLOCK
BH,        *BHATCH
BL,        *BLOCK
BO,        *BOUNDARY
-BO,       *-BOUNDARY
B,        *BREAK
Cc,         *CIRCLE
CH,        *DDCHPROP
-CH,       *CHANGE
CHA,       *CHAMFER
CM,        *CHAMFER
COL,       *DDCOLOR
C,        *COPY
cr,        *chprop
CW,        *CHWID
D,         *DDIM
DAL,       *DIMALIGNED
DAN,       *DIMANGULAR
DBA,       *DIMBASELINE
DCE,       *DIMCENTER
DCO,       *DIMCONTINUE
DDI,       *DIMDIAMETER
DE,        *DDEDIT
DED,       *DIMEDIT
D,        *DIST
DIV,       *DIVIDE
DLI,       *DIMLINEAR
DO,        *DONUT
DOR,       *DIMORDINATE
DOV,       *DIMOVERRIDE
DR,        *DRAWORDER
DRA,       *DIMRADIUS
DST,       *DIMSTYLE
DT,        *DTEXT
DV,        *DVIEW
E,         *ERASE
dD,        *DDEDIT
EL,        *ELLIPSE
Ee,        *EXPLODE
Et,        *EXTEND
EXIT,      *QUIT
EXP,       *EXPORT
EXT,       *EXTRUDE
F,         *FILLET
FI,        *FILTER
G,         *GROUP
-G,        *GROUP
G4,        *GLCD4
GP,        *GPDRAW
GR,        *DDGRIPS
H,         *BHATCH
-H,        *HATCH
HE,        *HATCHEDIT
HI,        *HIDE
I,         *DDINSERT
-I,        *INSERT
IAD,       *IMAGEADJUST
IAT,       *IMAGEATTACH
ICL,       *IMAGECLIP
IM,        *IMAGE
-IM,       *-IMAGE
IMP,       *IMPORT
INt,       *INTERSECT
INF,       *INTERFERE
IO,        *INSERTOBJ
In,        *INSERT
L,         *LINE
LA,        *LAYER
-LA,       *-LAYER
LE,        *LEADER
LEN,       *LENGTHEN
Ll,        *LIST
LS,        *LTSCALE
LT,        *LINETYPE
-LT,       *-LINETYPE
LTS,       *LTSCALE
M,         *MOVE
Mm,        *MATCHPROP
ME,        *MEASURE
MI,        *MIRROR
ML,        *MLINE
MO,        *DDMODIFY
MS,        *MSPACE
MT,        *MTEXT
MV,        *MVIEW
ff,         *OFFSET
OS,        *DDOSNAP
-OS,       *-OSNAP
P,         *PAN
-P,        *-PAN
PA,        *PASTESPEC
PE,        *PEDIT
PF,        *PREFERENCES
PL,        *PLINE
PO,        *POINT
POL,       *POLYGON
PR,        *PREFERENCES
PRE,       *PREVIEW
PRINT,     *PLOT
PS,        *PSPACE
PU,        *PURGE
R,         *REDRAW
RA,        *REDRAWALL
RE,        *REGEN
REA,       *REGENALL
REC,       *RECTANGLE
REG,       *REGION
REN,       *DDRENAME
-REN,      *RENAME
REV,       *REVOLVE
RM,        *DDRMODES
RO,        *ROTATE
RPR,       *RPREF
RR,        *RENDER
Ss,         *STRETCH
SC,        *SCALE
SCR,       *SCRIPT
SE,        *DDSELECT
SEC,       *SECTION
SET,       *SETVAR
SHA,       *SHADE
SL,        *SLICE
SN,        *SNAP
SO,        *SOLID
SP,        *SPELL
SPL,       *SPLINE
SPE,       *SPLINEDIT
ST,        *STYLE
SU,        *SUBTRACT
mt,         *MTEXT
-T,        *-MTEXT
TA,        *TABLET
TH,        *THICKNESS
TI,        *TILEMODE
TO,        *TOOLBAR
TOL,       *TOLERANCE
TOR,       *TORUS
T,        *TRIM
UC,        *DDUCS
UCP,       *DDUCSP
UN,        *DDUNITS
-UN,       *UNITS
UNI,       *UNION
V,         *DDVIEW
-V,        *VIEW
VP,        *DDVPOINT
-VP,       *VPOINT
VR,        *VIEWRES
W,         *WBLOCK
WE,        *WEDGE
X,         *EXPLODE
XA,        *XATTACH
XB,        *XBIND
-XB,       *-XBIND
XC,        *XCLIP
XL,        *XLINE
XR,        *XREF
-XR,       *-XREF
Z,         *ZOOM
发表于 2005-3-20 14:17:09 | 显示全部楼层
快捷键发展是从修改acad.pgp到acad.mnu最到加载快捷键脚本程序,功能越来越强,acad.pgp功能局限太多,修改acad.pgp是初学autocad的使用者方法,所以斑主不该加分
发表于 2005-3-20 20:50:44 | 显示全部楼层
自己设置的快捷在自己的机器倒是很好用,但是要是到别人的机器上呢,那怎么办?
个人感觉还是用系统定义的好,通用,不为别的!
发表于 2005-9-13 13:13:15 | 显示全部楼层
楼主提供的内容很好,很好,特别是图层控制那些,让人茅塞顿开啊。。。。。赞楼主一把!!
发表于 2005-9-13 14:42:42 | 显示全部楼层
你这也叫最省事?圆用Y朵好,还有AL改为AG会更好用。还有你的
D好像有重复(ddim,dist) ,后面的我就没看了.
发表于 2005-9-14 10:25:12 | 显示全部楼层
改得很好,很合理,可只能在自己机上用,换在别人机上时,恐怕能以施展,我觉得应该改动与原版尽可能的小才好。
发表于 2005-9-20 22:49:05 | 显示全部楼层
虽然不一定合用,不过先收下了,谢谢
发表于 2005-9-23 12:24:42 | 显示全部楼层
呵呵 这也要收费呀  没道理  一般人都会定义的
发表于 2005-9-30 10:33:07 | 显示全部楼层
有些是不错。很顺手。但有些就。。。。
各人有保人的习惯嘛。
发表于 2005-10-5 16:20:52 | 显示全部楼层
我同意10楼的观点,每个人工作内容不同,常用命令就不一样。应该根据自己的需要来设定,不易太多。关键是要会方法及快捷键命名规则要合理,方便记忆。
发表于 2005-10-5 17:05:14 | 显示全部楼层
快捷健还是自己设置的好,记得住!!
GMT+8, 2026-11-3 13:55 , Processed in 0.488106 second(s), 46 queries , Gzip On.
