查看: 833|回复: 1
[LISP程序]:如何定义1个尺寸标注样式
发表于 2004-11-8 08:52:34 | 显示全部楼层 |阅读模式
设置标注样式很麻烦,运行lisp导入就方便很多了
如何定义1个尺寸标注样式???
发表于 2004-11-8 10:19:05 | 显示全部楼层
你的主题应该标明“如何用LISP定义。。。
请参考:
(DEFUN C:CD()
  (COMMAND "DIMSTYLE" "RESTORE" "CDIM" "LAYER" "SET" "DIMENSION" "" "DIM" "UPD")
(DEFUN C:DV()
  (COMMAND "DIMSTYLE" "RESTORE" "DIM" "LAYER" "SET" "DIMENSION" "" "DIM" "VER" PAUSE PAUSE PAUSE "" "EXIT")
GMT+8, 2026-11-5 12:25 , Processed in 0.448975 second(s), 34 queries , Gzip On.
