查看: 857|回复: 4
[求助] [求助]:粗糙度标注程序
发表于 2004-11-13 15:42:34 | 显示全部楼层 |阅读模式
现在需要一个粗糙度标注的程序,我在论坛中没有搜到
先谢谢各位了
发表于 2004-11-14 07:09:49 | 显示全部楼层
怎么会搜索不到呢?本论坛有关粗糙度的贴子有30多个呢!
下面的程序可依所选取点附近的实体自动设置符号的方位:
[php]
(defun c:test ()
  (setvar "osmode" 0)
  (setq p0 (getpoint "\nInput point"))
  (setq high (* (getvar "dimscale")(getvar "dimtxt")))
  (setq p1 (osnap p0 "near"))
  (if p1 (setq ang (angle p1 p0))(setq ang (/ pi 2) p1 p0))
  (if (or (null cvalue)(= cvalue ""))(setq cvalue "32"))
  (princ "\nInput Crudity Value <")
  (princ cvalue)
  (princ ">")
  (setq string (getstring))
  (if (or (null string)(= string ""))
 (setq string cvalue)
 (setq cvalue string)
  (vl-cmdf "pline" (polar p1 (- ang (/ pi 6))(/ high 0.3)) p1
                   (polar p1 (+ ang (/ pi 6))(/ high 0.6))
                   (Polar p1 (- ang (/ pi 6)) (/ high 0.6)) "")
  (if (and (< ang (/ (* pi 6) 7))(> ang (/ pi 6)))
    (setq d 1 p0 (polar p1 ang (/ high 0.55)))
    (setq d -1 p0 (polar p1 ang (/ high 0.35)))
  (vl-cmdf "text" "j" "f" (polar p0 (+ ang (* d (/ pi 2))) high)
                          (polar p0 (- ang (* d (/ pi 2))) high) high string)
[/php]
 楼主| 发表于 2004-11-15 10:24:02 | 显示全部楼层
感谢长老提供的程序
我会在论坛中再搜一下看看还能不能找到其它的
已领礼包: 16个
发表于 2004-11-15 19:48:49 | 显示全部楼层
发表于 2004-11-19 11:19:20 | 显示全部楼层
我加载上去不知道怎么用!
GMT+8, 2026-11-5 14:40 , Processed in 0.553826 second(s), 40 queries , Gzip On.
