查看: 888|回复: 2
[下载]:outlineart,文字转曲线的工具
发表于 2004-11-27 12:38:19 | 显示全部楼层 |阅读模式
OutlineART,applied in CAD wordprocessing,is a tool to transform words and symbols into  vector-contour,we provide both windows desktop  version and ARX embedded version for   AutoCAD(supporting R14 and R2000),so that words and symbols can be transformed into not only  DXF file,but also polyline entity in AutoCAD
注意:本软件不支持中文字体!!
 楼主| 发表于 2004-11-27 12:40:27 | 显示全部楼层
 楼主| 发表于 2004-11-27 12:47:19 | 显示全部楼层
  1. Command: ot
  2. OutlineART for AutoCAD 2004/2005           2004.11  freefire studio.
  3. ===>Command: 'ot'  to run.
  4. ARX application : D:\Program Files\OutlineArt\OutlineARTR2004.arx is NOT MDI
  5. aware.
  6. Mode [ 1 -Input / 2 -Box] <1>:1
  7. Input text insert point:
  8. Command:  OT
  9. Mode [ 1 -Input / 2 -Box] <1>:
  10. Input text insert point:
  11. Outline Text Height <0.2>:
  12. Outline Text factor <0.7>:
  13. Outline Text line-width <0.0>:
  14. Open OutlineART dialog...
复制代码
GMT+8, 2026-11-2 23:10 , Processed in 0.535995 second(s), 37 queries , Gzip On.
