查看: 930|回复: 4
[求助] [求助]:两个选择:输入数值或选物体
发表于 2004-11-28 19:44:08 | 显示全部楼层 |阅读模式
以下该如何实现
command: 选择要加粗的曲线(PLINE,LINE,ARC,CIRCLE,PLINE)
command:线宽/参照已加粗曲线
                输入一个数值或选择物体
目前我只能这样:
   (INITGET 4 "R")
(PROMPT"选择要加粗的曲线:")
((SETQ EN(SSGET"\N选择要加粗的曲线:"))
(IF EN(SETQ WID(GETREAL"\N线宽/参照粗线(R)")))
     (COND ......
已领礼包: 6530个
发表于 2004-11-29 06:49:52 | 显示全部楼层
ssget不可同时使用关键字,所以你的思路是对的,程序应该这样:
  1. (PROMPT"选择要加粗的曲线:")
  2. (SETQ EN(SSGET"\N选择要加粗的曲线:")
  3. (if en
  4.   (progn
  5.     (INITGET 1 "R")
  6.     (setq wid (getdist "\n输入线宽或 [选择参照粗线(R)]: ")
  7.     ...
 楼主| 发表于 2004-11-29 20:31:22 | 显示全部楼层
谢谢,看来只能这样了.
已领礼包: 488个
发表于 2004-11-30 01:14:57 | 显示全部楼层
用grread可以做出一个很好的来.
动动脑筋:)
发表于 2004-11-30 10:46:12 | 显示全部楼层
[php]
(defun c:test (/)
  ;;程序内容
  (setq        txt5 (@ukword 1
                      "A B"
                      "\n请选择处理方式:A-线宽/B-参照已加粗曲线"
                      txt5
  (cond
    ((= txt5 "A")(sub1)
     (= txt5 "B")(sub2)
  ;;程序内容
(defun @ukword (bit kwd msg def / inp)
  (if (and def (/= def ""))
    (setq msg (strcat "\n" msg "<" def ">:")
          bit (* 2 (fix (/ bit 2)))
    (setq msg (strcat "\n" msg ":"))
  (initget bit kwd)
  (setq inp (getkword msg))
  (if inp
    inp
    def
(defun sub1()
(defun sub2()
[/php]
GMT+8, 2026-11-5 13:55 , Processed in 0.379558 second(s), 40 queries , Gzip On.
