查看: 560|回复: 2
[求助]:哪位老师帮下忙?
发表于 2004-11-29 00:39:00 | 显示全部楼层 |阅读模式
一段绘图说明,我英语太差,看不明白,先谢过了。
1:Draw the frame using Joes original AutoCAD procedure with the uniform frame thickness B - D. We prefer the thickness to be C - D at the top.
2:Draw straight line s A- B and A - C where A is any convenient point on the inside curve of the frame near the keel
3:Determine the angle between the two lines drawn in step 2. One method for this is to use the AutoCAD “angular dimension“ command.
4:Use the AutoCAD rotate command to rotate the inner curve about point A through the angle determined in step 3. The rotated curve is the curved line from A to C in the drawing above.
5:Erase the curve from A to B and the two straight lines.
6:Use the AutoCAD mirror command to draw the other half of the frame
发表于 2004-11-29 17:40:58 | 显示全部楼层
找金山词霸或东方快车吧
 楼主| 发表于 2004-12-2 00:43:33 | 显示全部楼层
早试过了,译出来的还是看不明白.
   难道没人肯帮我吗?:(
GMT+8, 2026-11-2 22:10 , Processed in 0.765354 second(s), 36 queries , Gzip On.
