查看: 848|回复: 4
[求助] [求助]:将图形路径写入文件中
已领礼包: 8644个
发表于 2004-12-13 17:40:48 | 显示全部楼层 |阅读模式
我想将一个目录下选择的文件的全路径写入一个新建的文件中,例如把c:\drawings下的1.dwg,2.dwg,3.dwg写入a.dat中,最好是用dos_lib函数,可以有文件选择对话框。望高手出招。
发表于 2004-12-13 18:23:56 | 显示全部楼层
这不是CAD应该解决的问题。
已领礼包: 488个
发表于 2004-12-13 23:03:01 | 显示全部楼层
vl-directory-files
open "W"
发表于 2004-12-13 23:43:30 | 显示全部楼层
(DEFUN C:ss (/ path date user monthlist txtpt tkpt)
        (setq path (strcase (strcat (getvar "dwgprefix") (getvar "dwgname"))))
        (setq monthlist (list "JAN" "FEB" "MAR" "APR" "MAY" "JUN"
                                                  "JUL" "AUG" "SEP" "OCT" "NOV" "DEC" ))
        (setq date (rtos (getvar "cdate") 2 0))
        (setq user (strcase (getvar "loginname")))
          (setq path (strcat path " " (substr date 7 2) "/"
                (nth (1- (atoi (substr date 5 2))) monthlist)
                                " " user))
          (setq tkpt (getpoint "插入点:"))
        (if (= tkpt nil) (C:TKPT))
        (setq txtpt (list (- (nth 0 tkpt) 200) (+ (nth 1 tkpt) 200)))
        (setq os (getvar "osmode"))
        (setvar "osmode" 0)
        (command "text" "j" "BR" txtpt "350" "" path)
        (setvar "osmode" os)
        (setvar "users1" path)
  (princ)
);end defun
;;;===== 更改图纸路径 =====
(DEFUN C:aa (/ ostr str e p l n path)
                        " " user))
        (if (/= path (getvar "users1"))
                (progn
                (setq p (ssget "x" (list (cons 0 "TEXT")) ));
                (if p (progn
                (setq l 0 n (sslength p))
                (if (> n 0)
                (while (< l n)
                        (setq str (cdr (assoc 1 (setq e (entget (ssname p l) )))))
                        (setq ostr str)
                        (if (wcmatch str "?:\\*DWG ??/??? *")
                        (progn
                        (setq str (strcase path))
                        (setq e (subst (cons 1 str) (cons 1 ostr) e))
                        (entmod e)
                        );progn
                        );if
                        (setq l (1+ l))
                );while
                );if
                ));if progn
                );progn
        );if
  (princ)
);end defun
已领礼包: 8644个
 楼主| 发表于 2004-12-14 08:57:18 | 显示全部楼层
谢谢aeo,我用dos_getfilem解决了问题.我很喜欢这种对话框选择.
GMT+8, 2026-11-6 15:21 , Processed in 0.476493 second(s), 40 queries , Gzip On.
