查看: 919|回复: 9
[求助]:两个图元不共面如何解决
发表于 2004-12-19 04:33:29 | 显示全部楼层 |阅读模式
我时常用圆角命令时,选择对象的时候,有时会提示两个图元不共面,所以不能完成圆角的步骤,请问这是怎么回事,如何解决,请教各位大虾,我用圆角命令频率较高,小弟先在这里谢谢大家了.
发表于 2004-12-20 19:00:12 | 显示全部楼层
试试把z轴改为统一值。
不共面时一定做不成圆角的。
发表于 2004-12-20 21:09:35 | 显示全部楼层
Z轴如何归一呢?
发表于 2004-12-20 23:54:13 | 显示全部楼层
楼主可以试试用pe(多线编辑)+M(多选)将对象(一般是直线吧?)转化成多线后用J参数连在一起,一般可以解决不共面的问题。
发表于 2004-12-21 10:56:07 | 显示全部楼层
用PROPERTIES将图元Z坐标都改为统一值,或0.
发表于 2004-12-21 11:33:47 | 显示全部楼层
使用et扩展工具吧!很好用除了二维化对象外,其他命令也很方便的。值得研究!
发表于 2004-12-21 11:46:05 | 显示全部楼层
这是源文件+汉化包安装即可
发表于 2004-12-21 14:32:29 | 显示全部楼层
我常用的Z向归零程序和Z向标高设定程序
[php];;; z向归零
(defun c:za ()
  (setvar "cmdecho" 0)
  (setvar "blipmode" 0)
  (graphscr)
  (prompt "z向归零:")
  (terpri)
  (princ "请选择要归零的实体")
  (setq s (ssget))
  (setq len (sslength s))
  (setq index 0)
  (repeat len
    (setq a (entget (ssname s index)))
    (setq b10 (assoc 10 a))
    (setq b11 (assoc 11 a))
    (setq x10 (cadr b10))
    (setq y10 (caddr b10))
    (setq x11 (cadr b11))
    (setq y11 (caddr b11))
    (setq b101 (cons 10 (list x10 y10 0)))
    (setq b111 (cons 11 (list x11 y11 0)))
    (setq a (subst
              b101
              b10
              a
    (entmod a)
    (setq a (subst
              b111
              b11
              a
    (entmod a)
    (setq index (+ index 1))
  (princ)
[/php]
[PHP]
(defun c:zmatch (/ oldec ss i e elist elev e2 elist2 elev2 diff sdiff elset)
  (setvar "flatland" 0)
  (setq oldec (getvar "cmdecho"))
  (setvar "osmode" 0)
  (princ "select objects for elevation change:        ")
  (setq ss (ssget))
  (setq i 0)
  (if ss
    (progn
      (setq e (car (entsel "\nnew elevation, select object [return for kb input]: ")))
      (if (= e nil)                       ; if manual input
        (progn
          (setq elset (getvar "elevation"))
          (setq elev (getdist (strcat "\nenter new elevation <"
                                      (rtos elset) ">: "
          (if (= elev nil)
            (setq elev elset)
      (if (/= e nil)                       ; if selected object
        (progn
          (setq elist (entget e))
          (setq elev (caddr (cdr (assoc 10 elist)))) ; z value extracted
      (repeat (sslength ss)               ; start repeat on selection set
        (setq e2 (ssname ss i)
              e2list (entget e2)       ; extract z value
              elev2 (caddr (cdr (assoc 10 e2list)))
              diff (- elev elev2)      ; calc difference in z value
              sdiff (rtos diff 2 4)
        (command "move" e2 "" "0,0,0" (strcat "0,0," sdiff))
        (setq i (1+ i))
      (setvar "cmdecho" oldec)
      (prompt (strcat "\n total " (itoa i) " entities changed to "))
      (prompt (strcat "elevation " (rtos elev 4 6) " "))
  )                                       ; end if ss
  (princ)
[/PHP]
发表于 2004-12-21 16:01:35 | 显示全部楼层
可以使用Z向归零程序设定
 楼主| 发表于 2004-12-22 11:54:13 | 显示全部楼层
大家说的方法我都用了,2楼,6楼,8楼楼主的方法都可以用,谢谢大家了
GMT+8, 2026-10-22 05:01 , Processed in 0.617061 second(s), 50 queries , Gzip On.
