查看: 1164|回复: 0
[求助] [求助]:IAcadPlot的使用
发表于 2004-12-20 18:51:26 | 显示全部楼层 |阅读模式
同过以下代码实现了dwg输出dwf文件。但是我如何通过程序设置打印区域呢
        AutoCAD::IAcadApplication *IApp;
        AutoCAD::IAcadDocument *IDoc;
        AutoCAD::IAcadPlot *IPlot ;
        AutoCAD::IAcadLayouts *ILayouts;
          CString result ;
HRESULT hr = NOERROR;
CLSID clsid;
LPUNKNOWN pUnk = NULL;
LPDISPATCH pAcadDisp = NULL;
CoInitialize(NULL);
hr = ::CLSIDFromProgID(L"AutoCAD.Application",&clsid);
if (FAILED(hr))
  MessageBox("2","2",0) ;
return;
if(::GetActiveObject(clsid, NULL, &pUnk) != S_OK)
  MessageBox("3","3",0) ;
return;
hr = pUnk->QueryInterface(IID_IDispatch, (LPVOID*) &pAcadDisp);
pUnk->Release();
if (FAILED(hr))
return;
//利用获得的IUnknown 接口获得AutoCAD 应用程序对象。同时确保AutoCAD程序可见。代码如下:
hr = pAcadDisp->QueryInterface(AutoCAD::IID_IAcadApplication,(void**)&IApp);
pAcadDisp->Release();
if (FAILED(hr))
  MessageBox("","",0) ;
return;
IApp->put_Visible(true);
//MessageBox()
//从AutoCAD应用程序接口可以获得菜单条和菜单组集合。
        // TODO: Add extra validation here
        TRY
IApp->get_ActiveDocument(&IDoc) ;
IDoc->get_Plot(&IPlot) ;
IDoc->get_Layouts(&ILayouts) ;
//IAcadLayout *ILayout ;
_bstr_t tt = "c:\\wlj4.dwf" ;
_variant_t str("PublishToWeb DWF.pc3") ;
VARIANT_BOOL bt = FALSE ;
if (FAILED(IPlot->PlotToFile(tt,str,&bt)))
  MessageBox("fail","",0) ;
  MessageBox("success","",0) ;
//IApp->AttachDispatch(acedGetAcadWinApp()->GetIDispatch(TRUE)) ;
//IDoc.AttachDispatch(IApp->get_ActiveDocument()) ;
//AutoCAD::IAcadPlot IPlot(IDoc.get_Plot());
//ariant_t str("jxxl.pc3");
//ariant_t bc(0) ;
//TR strfile;
//rcpy(strfile,"c:\\tt2.dwf") ;
//lot->PlotToFile(strfile, str,bc);
CATCH(COleDispatchException,e)
e->ReportError();
e->Delete();
END_CATCH;
GMT+8, 2026-11-22 10:14 , Processed in 0.303245 second(s), 10 queries , Gzip On, File On.
