查看: 696|回复: 1
[求助] [求助]:如何在VLISP调其它dll中的函数???
发表于 2004-12-30 18:59:48 | 显示全部楼层 |阅读模式
发表于 2004-12-30 19:08:25 | 显示全部楼层
Imports information from a type library
(vlax-import-type-library :tlb-filename filename [:methods-prefix mprefix :properties-prefix pprefix :constants-prefix cprefix])
Arguments
filename
A string naming the type library. A file can be one of the following types:
A type library (TLB) or object library (OLB) file
An executable (EXE) file
A library (DLL) file containing a type library resource
A compound document holding a type library
Any other file format that can be understood by the LoadTypeLib API
If you omit the path from tlb-filename, AutoCAD looks for the file in the Support File Search Path.
mprefix
Prefix to be used for method wrapper functions. For example, if the type library contains a Calculate method and the mprefix parameter is set to "cc-", Visual LISP generates a wrapper function named cc-Calculate. This parameter defaults to "".
pprefix
Prefix to be used for property wrapper functions. For example, if the type library contains a Width property with both read and write permissions, and pprefix is set to "cc-", then Visual LISP generates wrapper functions named cc-get-Width and cc-put-Width. This parameter defaults to "".
cprefix
Prefix to be used for constants contained in the type library. For example, if the type library contains a ccMaxCountOfRecords property with both read and write permissions, and cprefix is set to "cc-", Visual LISP generates a constant named cc-ccMaxCountOfRecords. This parameter defaults to "".
Note the required use of keywords when passing arguments to vlax-import-type-library.
Return Values
T, if successful.
Examples
Import a Microsoft Word type library, assigning the prefix "msw-" to methods and properties, and "mswc-" to constants:
_$ (vlax-import-type-library
   :tlb-filename "c:/program files/microsoft office/msword8.olb"
   :methods-prefix "msw-"
   :properties-prefix "msw-"
   :constants-prefix "mswc-")
T
Remarks
Function wrappers created by vlax-import-type-library are available only in the context of the document vlax-import-type-library was issued from.
In the current release of Visual LISP, vlax-import-type-library is executed at runtime, rather than at compile time. In future releases of Visual LISP, this may change. The following practices are recommended when using vlax-import-type-library:
If you want your code to run on different machines, avoid specifying an absolute path in the tlb-file-name parameter.
If possible, avoid using vlax-import-type-library from inside any AutoLISP expression (that is, always call it from a top-level position).
In your AutoLISP source file, code the vlax-import-type-library call before any code that uses method or property wrappers or constants defined in the type library.
Returns a running instance of an application object, or creates a new instance if the application is not currently running
(vlax-get-or-create-object prog-id)
Arguments
prog-id
A string containing the programmatic identifier of the desired ActiveX object. The format of prog-id is
<Vendor>.<Component>.<Version>
For example:
AutoCAD.Drawing.15
Return Values
The object.
Examples
_$ (vlax-get-or-create-object "Excel.Application")
#<VLA-OBJECT _Application 0017bb5c>
GMT+8, 2026-11-5 22:39 , Processed in 0.417483 second(s), 34 queries , Gzip On.
