查看: 1082|回复: 6
[求助] [求助]:关于图层合并
发表于 2005-1-1 07:51:39 | 显示全部楼层 |阅读模式
谁能提供将同一图层的图合并在一起的lisp呢?我现在是用group来实现的,好麻烦.希望大侠们能提供一个快捷的lisp.
发表于 2005-1-1 09:27:38 | 显示全部楼层
[php]
;;;同一图层的物体合并成组(group)
(defun c:test035 (/ s1 la ss)
  (setq        s1    (entsel "\n选择图层物体 : ")
        Gname (ustr 1 "\n\t组名" Gname nil)
        la    (dxf 8 (entget (car s1)))
        ss    (ssget "X" (list (cons 8 la)))
  (command "-group" "C" Gname "" ss "")
  (princ)
(defun dxf (code elist) (cdr (assoc code elist)))
(defun ustr (bit msg def spflag / inp nval)
   (if (and def (/= def ""))
       (setq msg (strcat "\n" msg "<" def ">:")
             inp (getstring msg spflag)
             inp (if (= inp "") def inp))
       (progn
         (setq msg (strcat "\n" msg ": "))
         (if (= bit 1)
             (while (= "" (setq inp (getstring msg spflag))))
             (setq inp (getstring msg spflag)))))
   (if inp inp def)
[/php]
发表于 2005-1-1 09:31:27 | 显示全部楼层
做成块
  1. (defun c:tt (/ e)
  2.   (setq e (car (entsel)))
  3.   (command "_.copybase" "0,0,0"(ssget "x" (list (assoc 8 (entget e))))"")
  4.   (command "_.erase" (ssget "x" (list (assoc 8 (entget e)))) "")
  5.   (command "_pasteblock" "0,0,0")
  6. )
发表于 2005-1-1 09:41:37 | 显示全部楼层
自动管理组
  1. (defun c:tt (/ e lyr grp ss)
  2.   (if (setq e (car (entsel "\n拾取实体: ")))
  3.     (progn
  4.       (setq lyr (assoc 8 (entget e)))
  5.       ;|(setq grp (getstring "\n组名<匿名>: "))
  6.       (if (= grp "")
  7.         (setq grp "*")
  8.       )|;
  9.       (setq ss (ssget "x" (list lyr)))
  10.       (command ".group" "c" "*" "" ss "")
  11.     )
  12.   )
  13.   (princ)
  14. )
发表于 2005-1-1 21:48:57 | 显示全部楼层
2楼的很好
发表于 2005-1-1 23:02:06 | 显示全部楼层
我觉得既然是同一图层了,控制图层的开关就可以轻松编辑了。
发表于 2005-1-2 15:22:16 | 显示全部楼层
还是2楼楼主方法好一些
GMT+8, 2026-11-5 21:30 , Processed in 0.395178 second(s), 44 queries , Gzip On.
