查看: 707|回复: 2
[ARX函数]:调试问题,请看一看程序哪儿有问题!谢谢!!
发表于 2005-1-7 17:03:37 | 显示全部楼层 |阅读模式
我选择了一条pline线,并对其中的点遍历,并把点坐标,导出到一个点数组points()中
但我的程序运行完了后,这条线就不能在CAD中编辑,一修改编辑,CAD就自动关闭了!
请版主看一看,谢谢!!!
AcDb2dPolyline* pline2d;
AcDbObjectId objId=AcDbObjectId::kNull;
AcGePoint3d lPt( 0.0, 0.0, 0.0);
int j;j=0;
long sslen;
int result;
ads_name m_ss;
struct resbuf* filter;
    result = acedSSGet(_T(":S"), NULL, NULL, NULL, m_ss);
acedSSLength(m_ss, &sslen);
    int ret;
    ads_name ent;
    for (long i=0L; i<sslen; i++) {
        ret = acedSSName(m_ss, i, ent);
        ASSERT(ret == RTNORM);
  Acad::ErrorStatus es = acdbGetObjectId(objId, ent);
    AcDbEntity * pEnt;
acdbOpenObject(pEnt,objId,AcDb::kForRead);
    AcDb3dPolyline* pline3d;
    AcDbPolygonMesh* pmesh;
    AcDbPolyFaceMesh* pface;
    AcDbPolyline* pline;
    AcDbObjectIterator* vertexIter;
   Acad::ErrorStatus es;
    if ((pline2d = AcDb2dPolyline::cast(pEnt)) != NULL)
        vertexIter = pline2d->vertexIterator();
    else if ((pline3d = AcDb3dPolyline::cast(pEnt)) != NULL)
        vertexIter = pline3d->vertexIterator();
    else if ((pmesh = AcDbPolygonMesh::cast(pEnt)) != NULL)
        vertexIter = pmesh->vertexIterator();
    else if ((pface = AcDbPolyFaceMesh::cast(pEnt)) != NULL)
        vertexIter = pface->vertexIterator();
    else if ((pline = AcDbPolyline::cast(pEnt)) != NULL)
  for (unsigned int j=0; j<pline->numVerts(); j++) {
   es = pline->getPointAt(j, lPt);
   if (es == Acad::eOk) {
    points[j].x=lPt.x;
    points[j].y=lPt.y;
  return j;
    else
        vertexIter = NULL;
pline->close();
pEnt->close();
return 0;
发表于 2005-1-7 19:08:17 | 显示全部楼层
return j;之前实体没有关闭
 楼主| 发表于 2005-1-7 20:01:31 | 显示全部楼层
真是这个问题
搞定了,谢谢!!
我真笨,这怎么没仔细看一看
再次感谢!
GMT+8, 2026-11-6 03:19 , Processed in 0.408009 second(s), 36 queries , Gzip On.
