查看: 1389|回复: 0
[ARX程序]:AcDb3dPolyline第一个顶点为什么不能删除?
发表于 2007-11-5 16:21:06 | 显示全部楼层 |阅读模式
我想通过程序删除3DPolyline线的一些顶点,我发现只要我删除了第一个顶点时,删除后的这条线就不完整了,如果不查看顶点看不出来问题所在,只要用CAD属性窗口移动顶点时,发现就有问题了,顶点数就0和1之间跳,而且顶点坐标都为0了,不知有谁能告诉我怎么解决,急死了?
下面是简单例子:
void MyTest()
#ifdef OARXWIZDEBUG
        acutPrintf ("\nOARXWIZDEBUG - Ftest() called.");
#endif // OARXWIZDEBUG
        ads_name ss;
        long nLen;
        ads_name entName;
        AcDbObjectId entId;
        if(acedSSGet(NULL, NULL, NULL, NULL, ss) == RTNORM)
                acedSSLength(ss, &nLen);
                for(int i=0; i<nLen; i++)
                        acedSSName(ss, i, entName);
                        acedGetObjectId(entId, entName);
                acedSSFree(ss);
                AcDb3dPolyline *p3dPline=NULL;
                if(acdbOpenObject(p3dPline, entId, AcDb::kForWrite) == Acad::eOk)
                        AcDbObjectIterator *pVertIter=p3dPline->vertexIterator();
                        AcDb3dPolylineVertex  *pVert;
                        int i = 0;
                        for(pVertIter->start(); !pVertIter->done(); pVertIter->step())
                                if(i>=1)
                                        continue;
                                AcDbObjectId idTemp;
                                idTemp = pVertIter->objectId();
                                if(idTemp.isErased() || !idTemp.isValid())
                                        continue;
                                if(p3dPline->openVertex(pVert,idTemp,AcDb::kForWrite) == Acad::eOk)
                                        pVert->erase();
                                        pVert->close();
                                        i++;
                        delete pVertIter;
                        pVertIter = NULL;
                        p3dPline->close();
                        p3dPline = NULL;
GMT+8, 2026-11-25 03:24 , Processed in 0.250973 second(s), 10 queries , Gzip On, File On.
