楼主: xyp1964
[程序发布] [分享]:【实用程序汇总】test000系列!
 火 [复制链接]
 楼主| 发表于 2009-2-14 19:44:26 | 显示全部楼层
  1. [FONT=courier new];; 数据文本文件写图
  2. ;; 格式:520   1572   1.07
  3. (defun c:test759 ()
  4.   (if (setq fn (getfiled "\nxy file name of data" "数据文件" "txt" 8))
  5.     (progn
  6.       (setq fo (open fn "r"))
  7.       (while (setq str (read-line fo))
  8.         (setq lst (xyp-get-HzEngNum str 3)
  9.               tx  (caddr lst)
  10.               pt0 (list (atof (car lst)) (atof (cadr lst)))
  11.         )
  12.         (command "text" "non" pt0 "2" "0" tx)
  13.       )
  14.       (close fo)
  15.     )
  16.   )
  17.   (princ)
  18. )[/FONT]
 楼主| 发表于 2009-2-14 19:44:52 | 显示全部楼层
  1. [FONT=courier new];|
  2. dcl对话框参考:
  3. 程式化对话框设计
  4. 幻灯片显示
  5. |;
  6. (defun c:test760 ()
  7.   (CMDLA0)
  8.   (defun aaa ()
  9.     (xyp-Dcl-Gettile '("k1" "k2" "k3" "k4"))
  10.     (cond ((= k1 "1") (xyp-show-sld "k0" "acad(stone01)"))
  11.           ((= k2 "1") (xyp-show-sld "k0" "acad(stone03)"))
  12.           ((= k3 "1") (xyp-show-sld "k0" "acad(stone04)"))
  13.           ((= k4 "1") (xyp-show-sld "k0" "acad(stone05)"))
  14.     )
  15.   )
  16.   (xyp-initSet
  17.     '(k1 k2 k3 k4 kd gd)
  18.     '("1" "0" "0" "0" 100.0 100.0)
  19.   )
  20.   (setq        Ilst '(("k0" nil "imagebutton" "-2" "36" "AIONIC" "(XYP-ABOUTME)")
  21.                (nil nil "spacer;")
  22.                (nil nil ":boxed_radio_row{label="设计样式";")
  23.                ("k1" "1" "radio" "(aaa)")
  24.                ("k2" "2" "radio" "(aaa)")
  25.                ("k3" "3" "radio" "(aaa)")
  26.                ("k4" "4" "radio" "(aaa)")
  27.                (nil nil "}")
  28.                ("kd" "宽度" "real" "10")
  29.                ("gd" "高度" "real" "10")
  30.                (nil nil "user" "(aaa)")
  31.                (nil nil "spacer;")
  32.               )
  33.   )
  34.   (if (= (xyp-Dcl-Init Ilst "【图像辅助设计】" t) 1)
  35.     (princ)
  36.   )
  37.   (CMDLA1)
  38. )[/FONT]
 楼主| 发表于 2009-2-14 19:46:06 | 显示全部楼层
  1. [FONT=courier new];; 多段线圆弧半径
  2. (defun c:test761 ()
  3.   (princ "\n选择圆弧: ")
  4.   (command "dim" "rad" pause "" "" "e")
  5.   (setq s1 (entlast))
  6.   (setq r (cdr (assoc 42 (entget s1))))
  7.   (entdel s1)
  8.   (princ)
  9.   (alert (strcat "半径=" (rtos r 2 4)))
  10.   (princ)
  11. )[/FONT]
 楼主| 发表于 2009-2-14 19:46:48 | 显示全部楼层
  1. [FONT=courier new];; 相交线的平分面
  2. (defun c:test762 ()
  3.   (CMDLA0)
  4.   (setq s1 (car (entsel "\n选择: ")))
  5.   (setq        s2   (car (entsel "\n选择: "))
  6.         p1   (xyp-get-dxf 10 s1)
  7.         p2   (xyp-get-dxf 11 s1)
  8.         p3   (xyp-get-dxf 10 s2)
  9.         p4   (xyp-get-dxf 11 s2)
  10.         p5   (inters p1 p2 p3 p4 nil)
  11.         rad1 (angle p1 p2)
  12.         rad2 (angle p3 p4)
  13.         p6   (polar p5 rad1 100)
  14.         p7   (polar p5 rad2 100)
  15.         p8   (xyp-get-MidPoint p6 p7)
  16.   )
  17.   (command "circle" "non" p5 200)
  18.   (command "rotate3d" (entlast) "" "2" p5 p8 90)
  19.   (CMDLA1)
  20. )[/FONT]
 楼主| 发表于 2009-2-14 19:48:55 | 显示全部楼层
  1. [FONT=courier new];; 双多段线中间插入中线
  2. (defun c:test763 ()
  3.   (CMDLA0)
  4.   (xyp-MkLaCo "中心线" 1)
  5.   (setq        e1   (entsel "\n选择: ")
  6.         slst (xyp-ATSel e1)
  7.         ptn1 (xyp-get-Vertexs (car slst) 0)
  8.         ptn2 (xyp-get-Vertexs (cadr slst) 0)
  9.         i    0
  10.         ptn  '()
  11.   )
  12.   (foreach pt ptn1
  13.     (setq pt1 (nth i ptn2)
  14.           pt2 (xyp-get-MidPoint pt pt1)
  15.           i   (1+ i)
  16.           ptn (cons pt2 ptn)
  17.     )
  18.   )
  19.   (xyp-Entmake-lwPolyline ptn nil)
  20.   (CMDLA1)
  21. )[/FONT]
 楼主| 发表于 2009-2-14 19:49:21 | 显示全部楼层
  1. [FONT=courier new];; 平行线之中心线
  2. (defun c:test764 ()
  3.   (CMDLA0)
  5.   (while (setq s1 (entsel "\nLine线: "))
  6.     (setq ptn (xyp-get-MidLinePT s1))
  7.     (xyp-add-line (car ptn) (cadr ptn))
  8.   )
  9.   (CMDLA1)
  10. )[/FONT]
 楼主| 发表于 2009-2-14 19:49:59 | 显示全部楼层
  1. [FONT=courier new];; 保留数字文本大值
  2. (defun c:test765 ()
  3.   (CMDLA0)
  4.   (setq        ss  (ssget '((0 . "TEXT")))
  5.         lst '()
  6.         i   -1
  7.   )
  8.   (while (setq s1 (ssname ss (setq i (1+ i))))
  9.     (if        (setq b (xyp-get-dxf 1 s1))
  10.       (setq lst (cons (list b s1) lst))
  11.     )
  12.   )
  13.   (if lst
  14.     (foreach a (cdr
  15.                  (vl-sort lst
  16.                           '(lambda (e1 e2) (> (distof (car e1)) (distof (car e2))))
  17.                  )
  18.                )
  19.       (xyp-erase (cadr a))
  20.     )
  21.   )
  22.   (CMDLA1)
  23. )[/FONT]
 楼主| 发表于 2009-2-14 19:59:53 | 显示全部楼层
  1. [FONT=courier new];; 相同内容文字按上→下→左→右相连线
  2. (defun c:test766 (/ s1 ss i ptn)
  3.   (cmdla0)
  4.   (if (and (setq s1 (car (entsel "\n请选取要连线的其中一个文字: ")))
  5.            (= (xyp-get-dxf 0 s1) "TEXT")
  6.       )
  7.     (progn
  8.       (prompt "\n框选所要连线的范围: ")
  9.       (setq ss        (ssget (list '(0 . "TEXT") (cons 1 (xyp-get-dxf 1 s1))))
  10.             i        -1
  11.             ptn        '()
  12.       )
  13.       (setvar "osmode" 0)
  14.       (xyp-MkLaCo "TEST" 1)
  15.       (while (setq s1 (ssname ss (setq i (1+ i))))
  16.         (setq ptn (cons (xyp-get-dxf 10 s1) ptn))
  17.       )
  18.       (if ptn
  19.         (xyp-Entmake-lwPolyline (xyp-Sort-PListByXYZ ptn) nil)
  20.       )
  21.     )
  22.   )
  23.   (cmdla1)
  24. )[/FONT]
发表于 2009-2-18 21:32:43 | 显示全部楼层
能不能用 都先谢谢咯
发表于 2009-2-26 21:16:11 | 显示全部楼层
谁发一个 多个文本同时加减乘除一个数值 的LSP 代码上来用用
 楼主| 发表于 2009-3-14 00:29:00 | 显示全部楼层
  1. [FONT=courier new];;万花筒-六角形
  2. (defun c:test789 ()
  3.   (CMDLA0)
  4.   (setvar "osmode" 0)
  5.   (setq        ra 0
  6.         dr (xyp-ang2rad 3)                          ;旋转角度
  7.         r1 (xyp-ang2rad 120)                          ;外接角度
  8.         i  0
  9.         p0 '(0 0)
  10.         p1 (polar p0 0 1)
  11.   )
  12.   (repeat 721                                          ;次数
  13.     (setq P1 (inters p0 (polar p0 ra 10) p1 (polar p1 (+ ra r1) 10) nil)
  14.           ra (- ra dr)
  15.           i  (rem (1+ i) 256)
  16.     )
  17.     (if        (and (>= i 0) (< i 8))
  18.       (setq i 8)
  19.     )
  20.     (command "_polygon" 6 p0 "" p1)
  21.     (xyp-put "color" (entlast) i)
  22.     (command "zoom" "e")
  23.   )
  24.   (CMDLA1)
  25. )[/FONT]
发表于 2009-3-20 10:31:11 | 显示全部楼层
很好的东东。
 楼主| 发表于 2009-3-24 08:10:21 | 显示全部楼层
增减复制01
发表于 2009-3-25 10:55:14 | 显示全部楼层
下不了啊
发表于 2009-4-9 14:26:25 | 显示全部楼层
的确是好东东!!!!
GMT+8, 2026-10-12 05:43 , Processed in 0.525802 second(s), 54 queries , Gzip On.
