楼主: woaining
[编程申请]:递增复制 非完全数字(有字母或字符)
已领礼包: 24个
发表于 2005-1-22 10:16:33 | 显示全部楼层
最初由 zh_6531394 发布
[B]我运行了"Error: no function definition: ACET-ERROR-INIT"
请问原因 [/B]
ACET-ERROR-INIT的定义在ACETUTIL.FAS里,功能类似xdrx_begin
在ACETUTIL.FAS里定义的函数有:
External Functions:
ACET-ERROR-INIT --> ACETUTIL.FAS   Intializes bonus error routine
ACET-ERROR-RESTORE --> ACETUTIL.FAS   Restores old error routine
ACET-GEOM-TEXTBOX --> ACETUTIL.FAS   Returns textbox points for text or Mtext
ACET-GETVAR --> ACETUTIL.FAS   Retrieves custom variables
ACET-GROUP-MAKE-ANON    --> ACETUTIL.FAS   Creates anonymous group
ACET-LAYER-LOCKED --> ACETUTIL.FAS   Checks to see if layer is locked
ACET-LIST-M-ASSOC--> ACETUTIL.FAS   Retrieves multiple assoc's from list
ACET-SPINNER --> ACETUTIL.FAS   Creates spinning bar
ACET-SETVAR --> ACETUTIL.FAS   Stores custom variables
ACET-SS-INTERSECTION    --> ACETUTIL.FAS   Returns ss with common entities
ACET-SS-NEW  --> ACETUTIL.FAS   Creates selection set from starting ent
ACET-SS-REDRAW   --> ACETUTIL.FAS   Redraws all entities in selection set
ACET-SS-REMOVE--> ACETUTIL.FAS   Removes entities from selection set
ACET-SS-UNION  --> ACETUTIL.FAS   Combines two selection sets
ACET-STR-FORMAT   --> ACETUTIL.ARX   Alternate to strcat
ACET-SYSVAR-RESTORE--> ACETUTIL.FAS   Restores sysvars from global list
ACET-SYSVAR-SET  --> ACETUTIL.FAS   Saves sysvars to global list
ACET-UCS-TO-OBJECT  --> ACETUTIL.FAS   Sets ucs to object
ACET-UI-POLYGON-SELECT  --> ACETUTIL.FAS   Simulates CP or WP and returns points
ACET-UI-FENCE-SELECT    --> ACETUTIL.FAS   Simulates fence selction and returns points
ACET-XDATA-SET    --> ACETUTIL.FAS   Attaches data to entity using xdata
ACET-XDATA-GET   --> ACETUTIL.FAS   Reads data from entity set with acet-xdata-set
BNS_SS_MOD --> ACETUTIL.FAS   Filters selctions for locked layers etc.
发表于 2005-1-22 14:15:52 | 显示全部楼层
楼上的不好意识,写了这么多,我没看懂,麻烦你能否在简单些
发表于 2005-1-22 14:55:20 | 显示全部楼层
以前XD工具箱0.29里有个修改序号,可以实现
现在0.30里这个命令不知为何不能用
已领礼包: 24个
发表于 2005-1-22 15:32:06 | 显示全部楼层
最初由 zh_6531394 发布
[B]楼上的不好意识,写了这么多,我没看懂,麻烦你能否在简单些 [/B]
如果你要使用tcount,那么你就装express tools
如果你要学习tcount的编程技巧,那么就跳过acet-error-init的函数定义
如果你不装express tools的情况下使用tcount,那么就要先加载ACETUTIL.FAS。
如果你还不明白,那么就忘掉我这个伤心的人吧,呵呵。
发表于 2005-3-7 23:43:49 | 显示全部楼层
直接用偶的组成编号程序,支持前、后缀:
http://www.xdcad.net/forum/showthread.php?s=&threadid=279675
发表于 2005-3-8 14:51:42 | 显示全部楼层
下不了啊~
发表于 2006-2-8 23:08:24 | 显示全部楼层
试用下,看看,谢了
GMT+8, 2026-11-6 23:35 , Processed in 0.543538 second(s), 38 queries , Gzip On.
