查看: 847|回复: 3
[求助] [求助]:LISP中是否有把表转为字符的函数?
发表于 2005-1-20 10:18:08 | 显示全部楼层 |阅读模式
如:(1 2 3 4 5)->"1 2 3 4 5"
发表于 2005-1-20 13:10:28 | 显示全部楼层
可自定义一个!Look ......
;;TEST by qjcpj 05.01.20 PM12:10
;;Example: (list>-str '(1 2 3 4 5))
(defun list>-str        (lst / str)
        (setq str (itoa (car lst)))
        (foreach nb lst
                (setq str (strcat str (chr 32) (itoa nb)))
        (setq str (substr str 3))
        (eval 'str)
已领礼包: 593个
发表于 2005-1-20 13:17:09 | 显示全部楼层
这个程序网上早有现成的
  1. (defun spa (lst spa /)
  2.   (substr
  3.     (apply 'strcat
  4.            (mapcar '(lambda (x) (strcat spa (vl-princ-to-string x)))
  5.                    lst
  6.            )
  7.     )
  8.     (1+ (strlen spa))
  9.   )
  10. )
已领礼包: 488个
发表于 2005-1-20 22:12:13 | 显示全部楼层
命令: (vl-princ-to-string '(1 2 3 4))
"(1 2 3 4)"
GMT+8, 2026-11-5 21:20 , Processed in 0.399090 second(s), 38 queries , Gzip On.
