查看: 612|回复: 1
桩基承台计算书
发表于 2005-1-24 16:04:51 | 显示全部楼层 |阅读模式
桩基承台计算书
项目名称_____________日    期_____________
设 计 者_____________校 对 者_____________
一、示意图:
二、基本资料:
                承台类型:四桩承台                承台计算方式:程序自动设计
        1.依据规范:
                《建筑地基基础设计规范》(GB 50007--2002)
                《混凝土结构设计规范》(GB 50010--2002)
        2.几何参数:
                承台边缘至桩中心距: C = 400 mm
                桩列间距: A = 1200 mm                 桩行间距: B = 1200 mm
                承台根部高度: H = 450 mm                 承台端部高度: h = 450 mm
                纵筋合力重心到底边的距离: as = 70 mm                 平均埋深: hm = 2.50 m
                矩形柱宽: Bc = 400 mm                 矩形柱高: Hc = 400 mm
                方桩边长: Ls = 400 mm
        3.荷载设计值:(作用在承台顶部)
                竖向荷载: F = 1160.00 kN
                X向剪力: Vx = 161.00 kN                 Y向剪力: Vy = 26.70 kN
                绕X轴弯矩: Mx = 9.90 kN*m                 绕y轴弯矩: My = 62.40 kN*m
        4.作用在承台底部的弯矩
                绕X轴弯矩: M0x = Mx - Vy * h = 9.90 - (26.70)*0.45 = -2.11kN*m
                绕y轴弯矩: M0y = My + Vx * h = 62.40 + (161.00)*0.45 = 134.85kN*m
        5.材料信息:
                混凝土强度等级: C25
                fc = 11.90 N/mm2                ft = 1.27 N/mm2
                钢筋强度等级: HRB400                fy = 360.00 N/mm2
三、承台计算:
        1.基桩净反力设计值:
                计算公式:《建筑地基基础设计规范》(8.5.3-2)
                Ni = F/n ± M0x*yi/∑yj*yj ± M0y*xi/∑xj*xj
                N1 = F/n - M0x*y1/∑yj*yj + M0y*x1/∑xj*xj
                   = 1160.00/4 - -2.11*(0.60)/1.44 + 134.85*(-0.60)/1.44 = 234.69 kN
                N2 = F/n - M0x*y2/∑yj*yj + M0y*x2/∑xj*xj
                   = 1160.00/4 - -2.11*(0.60)/1.44 + 134.85*(0.60)/1.44 = 347.07 kN
                N3 = F/n - M0x*y3/∑yj*yj + M0y*x3/∑xj*xj
                   = 1160.00/4 - -2.11*(-0.60)/1.44 + 134.85*(-0.60)/1.44 = 232.93 kN
                N4 = F/n - M0x*y4/∑yj*yj + M0y*x4/∑xj*xj
                   = 1160.00/4 - -2.11*(-0.60)/1.44 + 134.85*(0.60)/1.44 = 345.31 kN
        2.承台受柱冲切验算:
                计算公式:《建筑地基基础设计规范》(8.5.17-1)
                Fl ≤ 2 * [β0x * (bc + a0y) + β0y * (hc + a0x)] * βhp*ft * h0
                X方向上自柱边到最近桩边的水平距离:
                a0x = (A - (bc + ls))/2 = (1200.00 - (400.00 + 400.00))/2 = 200.00 mm
                y方向上自柱边到最近桩边的水平距离:
                a0y = (B - (hc + ls))/2 = (1200.00 - (400.00 + 400.00))/2 = 200.00 mm
                作用于冲切破坏锥体上的冲切力设计值:
                Fl = F - ∑Qi = 1160.00 - 0.00 = 1160.00 kN
                X方向冲垮比:
                λ0x = a0x/h0 = 200.00/380.00 = 0.53
                y方向冲垮比:
                λ0y = a0y/h0 = 200.00/380.00 = 0.53
                X方向冲切系数:
                β0x = 0.84/(λ0x + 0.2) = 0.84/(0.53 + 0.2) = 1.16
                y方向冲切系数:
                β0y = 0.84/(λ0y + 0.2) = 0.84/(0.53 + 0.2) = 1.16
                2 * (β0x * (hc + a0y) + β0y * (bc + a0x)) * βhp * Ft * h0
                 = 2 * (1.16 * (400.00 + 200.00) + 1.16 * (400.00 + 200.00)) * 1270.00 * 380.00 * 0.00
                 = 1339529.74 N > Fl = 1160000.00 N 满足要求!
        3.承台受剪验算:
                计算公式:《建筑地基基础设计规范》(8.5.18-1)
                Fl ≤ βhs * β* ft * b0 * h0
                (1) Y方向上的抗剪计算
                y方向上自柱边到计算一排桩的桩边的水平距离:
                斜截面上最大剪力设计值:
                 Vl = 581.76
                计算截面的剪跨比:
                λ= a0/h0 = 200.00/380.00 = 0.53
                剪切系数:
                β= 1.75/(λ+ 1.0) = 1.75/(0.53 + 1.0) = 1.15
                承台计算截面的计算宽度:
                b0 = b1 * (1.0 - 0.5 * (h - he)/h0 * (1.0 - (bc + 2 * 50.0)/b))
                   = 2000 * (1.0 - 0.5 * (450 - 450)/380 * (1.0 - (400 + 2 * 50.0)/2000))
                   = 2000.00 mm
                βhs * β* fc * b0 * h0
                 = 1.00 * 1.15 * 11.90 * 2000.00 * 380.00
                 = 10369413.79 N > Vl = 581762.50 N 满足要求!
                (2) X方向上的抗剪计算
                X方向上自柱边到计算一排桩的桩边的水平距离:
                斜截面上最大剪力设计值:
                 Vl = 692.38
                计算截面的剪跨比:
                剪切系数:
                承台计算截面的计算宽度:
                   = 2000.00 mm
                 = 10369413.79 N > Vl = 692375.00 N 满足要求!
        4.承台角桩冲切验算:
                计算公式:《建筑地基基础设计规范》(8.5.17-5)
                Nl ≤ [β1x * (c2 + a1y / 2) + β1y * (c1 + a1x / 2)] * βhp * ft * h0
                角桩竖向冲反力设计值:
                 Nl = 347.07
                从角桩内边缘至承台外边缘的距离:
                c1 = C + ls/2 = 400.00 + 400.00/2 = 600.00 mm
                从角桩内边缘至承台外边缘的距离:
                c2 = C + ls/2 = 400.00 + 400.00/2 = 600.00 mm
                X方向上从承台角桩内边缘引45度冲切线与承台顶面相交点至角桩内边缘的水平
                距离:(当柱或承台变阶处位于该45度线以内时,则取由柱边或变阶处与桩内边
                      缘连线为冲切锥体的锥线)
                a1x = 200.00 mm
                Y方向上从承台角桩内边缘引45度冲切线与承台顶面相交点至角桩内边缘的水平
                      缘连线为冲切锥体的锥线)
                a1y = 200.00 mm
                X方向角桩冲垮比:
                λ1x = a0x1/h0 = 200.00/380.00 = 0.53
                Y方向角桩冲垮比:
                λ1y = a0y1/h0 = 200.00/380.00 = 0.53
                X方向角桩冲切系数:
                β1x = 0.56/(λ1x + 0.2) = 0.56/(0.53 + 0.2) = 0.77
                Y方向角桩冲切系数:
                β1y = 0.56/(λ1y + 0.2) = 0.56/(0.53 + 0.2) = 0.77
                (β1x*(c2 + a0y1/2) + β1y*(c1 + a0x1/2)) * βhp * ft * h0
                 = (0.77 * (600.00 + 200.00/2) + 0.77 * (600.00 + 200.00/2)) * 1.00 * 1.27 * 380.00
                 = 520928.23 N > Nl = 347068.75 N 满足要求!
        5.承台受弯计算:
                (1) 垂直X轴方向计算截面处弯矩计算:
                垂直X轴方向计算截面处弯矩设计值:
                M0y = ∑Ni * xi = 276.95 kN*m
                相对受压区高度:        ζ= 0.08                 配筋率:        ρ= 0.0026
                x向钢筋: Asx = 2107.15 mm2
                (2) 垂直Y轴方向计算截面处弯矩计算:
                垂直Y轴方向计算截面处弯矩设计值:
                M0x = ∑Ni * yi = 232.71 kN*m
                相对受压区高度:        ζ= 0.07                 配筋率:        ρ= 0.0022
                Y向钢筋: Asy = 1758.64 mm2
        6.承台受压验算:
                计算公式:《混凝土结构设计规范》(7.8.1-1)
                Fl ≤ 1.35*βc*βl*  fc * Aln
                局部荷载设计值:Fl = Fc = 1160.00 kN
                混凝土局部受压面积:Al = bc * hc = 400.00 * 400.00 = 160000.00mm2
                混凝土受压时计算底面积:Ab = 1440000.00mm2
                混凝土受压时强度提高系数:β= sqr(Ab/Al) = sqr(1440000.00/160000.00) = 3.00
                1.35 * βc * β * fc * Al
                 = 1.35 * 1.00 * 3.00 * 11.90 * 160000.00
                 = 7711200.00 N > Fl = 1160000.00 N 满足要求!
四、配筋结果:
        1.X方向钢筋计算结果
                计算面积As:        2107.15 mm2
                采用方案:f12@100
                实配面积:2375.04 mm2
        2.Y方向钢筋计算结果
                计算面积As:        1758.64 mm2
                采用方案:f12@120
                实配面积:1922.65 mm2
发表于 2005-2-21 17:22:42 | 显示全部楼层
还是不错的哦,比较清楚,可以参考
GMT+8, 2026-11-5 13:14 , Processed in 0.418272 second(s), 34 queries , Gzip On.
