查看: 1609|回复: 7
[投诉]:why revit has not 3d snap?
发表于 2005-2-28 03:35:00 | 显示全部楼层 |阅读模式
it is too boring.and work plane can not rotate freely  in 3d space.as well as array actually is 2d rather than 3d.
发表于 2005-3-2 15:14:07 | 显示全部楼层
what do you mean? you mean it can't rotate intime? it's not true, just try hold Shift Button and your middle Button, what's happened then?
 楼主| 发表于 2005-3-2 22:59:08 | 显示全部楼层
yoou donnot understand my meaning.i  mean how to rotate a ref. plane rather than viewport.
发表于 2005-3-3 10:57:59 | 显示全部楼层
only rotate a ref. plan? why not use it's Rotate tools? it can rotate every thing. I really not fully understand your "Rather than" meaning. I guess, you mean, you want to rotate it in 3D space, right? if you want, you can draw it in diffirent view port, right?
发表于 2005-3-14 17:57:36 | 显示全部楼层
说中文吧老大
 楼主| 发表于 2005-3-29 01:26:46 | 显示全部楼层
I HAVE NOT CHINESE INPUT.SORRY
发表于 2005-3-29 11:30:54 | 显示全部楼层
you don't have a chinese input? what's your OS in your computer? Linux? Windows 2000 English Edition? I am Enlish OS(windows 2000), but still can 输入中文.
发表于 2005-3-29 21:29:24 | 显示全部楼层
:>满好玩的
GMT+8, 2026-11-22 09:01 , Processed in 0.179727 second(s), 22 queries , Gzip On, File On.
