查看: 949|回复: 0
[ARX程序]:OBJECTARX编程中如何改变DWG中文字内容
发表于 2005-3-5 23:23:53 | 显示全部楼层 |阅读模式
由于要将DWG文件中N多的文字进行翻译, 想到了先将所有的文字全部导出到一文本文件中(已实现,代码如下)
//导出DWG文件中的文字串
void CTransTextDlg::OnBtExportText()
// TOD Add your control notification handler code here
AcDbDatabase* pDb;
    AcDbBlockTable *pBlockTable;
    pDb = acdbHostApplicationServices()->workingDatabase();
    pDb->getSymbolTable(pBlockTable, AcDb::kForRead);
    AcDbBlockTableRecord *pBlockTableRecord;
    pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForRead);
    pBlockTable->close();
    AcDbBlockTableRecordIterator *pBlockIterator;
    pBlockTableRecord->newIterator(pBlockIterator);
//打开文件用于输出
CString szFilter=_T("Data Files (*.dat;*.txt)|*.dat; *.txt|All Files (*.*)|*.*||");
CString szDefExt(_T(".DAT"));
CAcUiFileDialog dlg(FALSE, szDefExt, NULL,
  OFN_HIDEREADONLY | OFN_OVERWRITEPROMPT, szFilter);
dlg.DoModal();
CString strFileName;
strFileName = dlg.GetFileName();
ofstream out(strFileName);
if(!out)
  MessageBox("指定导出文件无法打开!");
  return;
//设置计数器
LONG lCounts = 0;
    for (; !pBlockIterator->done(); pBlockIterator->step())
        AcDbEntity *pEntity;
        pBlockIterator->getEntity(pEntity, AcDb::kForRead);
        const char *pCname = pEntity->isA()->name();
  if(!strcmp(pCname, "AcDbText")) //是单行文字类
   //获取文字内容
   lCounts++;
   const char *pText = ((AcDbText*)pEntity)->textString();
   out<<pEntity->objectId()<<",\t"<<pText<<endl;
  else if(!strcmp(pCname, "AcDbMText")) //是多行文字类
   lCounts++;
   const char *pMText = ((AcDbMText*)pEntity)->contents();
   out<<pEntity->objectId()<<",\t"<<pMText<<endl;
   if(pMText)
    pMText = NULL;
        pEntity->close();
out.close();
    delete pBlockIterator;
    pBlockTableRecord->close();
翻译后欲重新导入原DWG文件中, 如下:
void CTransTextDlg::OnBtSubsTexts()
//打开文件用于输出
AcDbDatabase* pDb;
    pDb->getBlockTable(pBlockTable, AcDb::kForRead);
CAcUiFileDialog dlg(TRUE, szDefExt, NULL,
dlg.DoModal();
ifstream in(strFileName);
if(!in)
  MessageBox("指定导入文件无法打开!");
  return;
//设置计数器
LONG lCounts = 0;
LONG lID;
  Acad::ErrorStatus es;
        es = pBlockIterator->getEntity(pEntity, AcDb::kForRead);
  switch(es)
  case Acad::eOk:
   acutPrintf("Acad::eOk\n");
   break;
  case Acad::ePermanentlyErased:
   acutPrintf("Acad::ePermanentlyErased\n");
   break;
  case Acad::eAtMaxReaders:
   acutPrintf("Acad::eAtMaxReaders\n");
   break;
  case Acad::eWasOpenForNotify:
   acutPrintf("Acad::eWasOpenForNotify\n");
   break;
  case Acad::eWasNotifying:
   acutPrintf("Acad::eWasNotifying\n");
   break;
  case Acad::eWasOpenForUnd
   acutPrintf("Acad::eWasOpenForUndo\n");
   break;
  case Acad::eWasOpenForWrite:
   acutPrintf("Acad::eWasOpenForWrite\n");
   break;
  case Acad::eWasOpenForRead:
   acutPrintf("Acad::eWasOpenForRead\n");
   break;
  default:
   acutPrintf("Unknown error type.\n");
   break;
   //获取文字内容
   acutPrintf("Step -- %ld\n", 4+lCounts);
   lCounts++;
   char inStr[256];
   in>>lID>>inStr;
   ((AcDbText*)pEntity)->setTextString(inStr);
   lCounts++;
   char inStr[1024];
   in>>lID>>inStr;
   ((AcDbMText*)pEntity)->setContents(inStr);
        pEntity->close();
in.close();
可却有错! 请教了!!!
EMAIL: yuleyue@yahoo.com
GMT+8, 2026-11-22 09:34 , Processed in 0.202682 second(s), 10 queries , Gzip On, File On.
