查看: 1007|回复: 0
[ARX程序]:插入外部图块时的错误,提示实体为空???????????????
发表于 2005-3-10 12:01:49 | 显示全部楼层 |阅读模式
acDocManager->lockDocument( acDocManager->curDocument(), AcAp::kWrite, NULL, NULL,true) ;
AcDbObjectId id;
AcDbObjectIdArray list;
AcDbDatabase extDatabase( Adesk::kFalse );
if (Acad::eOk != extDatabase.readDwgFile( "C:\\d.dwg"))  //打开图库文件
//  if (Acad::eOk != extDatabase.readDwgFile( dwgName ))
        acedAlert( "Error reading DWG!" );
        return;
    AcDbBlockTable* pBT;
    if (Acad::eOk != extDatabase.getSymbolTable( pBT, AcDb::kForRead ))
        acedAlert( "Error getting BlockTable of DWG" );
        return;
    AcDbBlockTableRecord* pBTR;
    Acad::ErrorStatus es = pBT->getAt( _T("bigblock"), pBTR, AcDb::kForRead );
//"bigblock"是要插入的块名
    pBT->close();
    if (Acad::eOk != es) {
        acedAlert( "Error getting the specific blockDef of DWG" );
        return;
AcDbBlockReferenceIdIterator *pItr;
if (Acad::eOk != pBTR->newBlockReferenceIdIterator(pItr))
  acedAlert( "Error iterating" );
        pBTR->close();
        return;
for (pItr->start(); !pItr->done(); pItr->step())
  AcDbObjectId blkRefId;
  if (Acad::eOk == pItr->getBlockReferenceId(blkRefId))
   list.append(blkRefId);
   break;
delete pItr;
pBTR->close();
    if (list.isEmpty()) {
        acedAlert( "No entities found in model space of DWG" );
        return;
    AcDbDatabase *pTempDb;
    if (Acad::eOk != extDatabase.wblock( pTempDb, list, AcGePoint3d::kOrigin ))
        acedAlert( "wblock failed!" );
        return;
    if (Acad::eOk != acdbHostApplicationServices()->workingDatabase()
        ->insert( AcGeMatrix3d::kIdentity, pTempDb ))
        acedAlert( "insert failed!" );
    delete pTempDb;
// 如果不需要插入块参照,将模型空间中的最后一个对象删除即可
ads_name lastEnt;
if (acdbEntLast(lastEnt) != RTNORM)
  acedAlert("获得模型空间最后一个实体失败!");
  return;
AcDbObjectId entId;
es = acdbGetObjectId(entId, lastEnt);
AcDbEntity *pEnt;
es = acdbOpenAcDbEntity(pEnt, entId, AcDb::kForWrite);
pEnt->erase();
pEnt->close();
//用窗口的时候
acDocManager->unlockDocument( acDocManager->curDocument());//
程序运行插入块时提示实体为空"No entities found in model space of DWG" ,应该是这里出错了,list.append(blkRefId);
   break;这两句没有执行,这是什么原因?
GMT+8, 2026-11-6 07:08 , Processed in 0.501053 second(s), 32 queries , Gzip On.
