查看: 1008|回复: 1
[编程申请]:寻求你的帮助
发表于 2003-2-20 14:08:59 | 显示全部楼层 |阅读模式
打开一个文件  但其中的文字是 MTEXT模式得  怎么才能 选取它  并 把它 EXPLODE成  TEXT模式,
  然后 ,导出到一个 文本文件中,用 LISP 编写。
不胜感谢
发表于 2003-2-20 14:19:58 | 显示全部楼层
你先炸开,然后用下面的程序,这个程序是按列上的顺序导出到d:\output\acadtxt.txt
(defun c:dcwb()
  (setq cm (getvar "cmdecho"))
  (setvar "cmdecho"0)
  (setq os (getvar "osmode"))
  (setvar "osmode" 0)
  (setq ducs (getvar "worlducs"))
  (if (= ducs 0)
    (progn
      (command "ucs" "w")
  (princ "请选择要导出的一列文本:")
  (setq a (ssget '((0 . "TEXT"))))
  (setq f (open "d:\\output\\acadtxt.txt" "a"))
  (setq n (sslength a))
  (setq nnn (1- n))
  (setq number 0 nn 0)
  (repeat n
    (setq a1 (ssname a number))
    (setq a11 (entget a1))
    (setq a_y (caddr (assoc 10 a11)))
    (if (= nn 1)
       (progn
         (if (> a_y y)
           (progn
             (setq y a_y yold a_y)
             (setq text (cdr (assoc 1 a11)))
       (progn
          (setq nn 1 y a_y yold a_y)
    (setq number (1+ number))
  (write-line text f)
  (repeat nnn
    (setq number 0 nn 0 dy 0 a_y 0)
    (repeat n
      (setq b_y (caddr (assoc 10 a11)))
      (if (= nn 1)
         (setq a_y (- b_y y))
      (if (and (< b_y y) (= nn 0))
         (setq dy (- b_y y) nn 1 c11 a11 a_y_new b_y)
      (if (and (< a_y 0) (> a_y dy))
        (setq dy a_y c11 a11 a_y_new b_y)
    (setq text (cdr (assoc 1 c11)))
    (write-line text f)
    (setq y a_y_new)
  (close f)
  (setvar"cmdecho" cm)
  (setvar"osmode"os)
  (setq n (rtos n 2 0))
  (princ (strcat n "个文本导出!"))
  (princ)
GMT+8, 2026-11-3 13:58 , Processed in 0.452875 second(s), 34 queries , Gzip On.
