查看: 811|回复: 2
[推荐]:3mdsmax5快捷键说明
发表于 2005-3-23 10:38:43 | 显示全部楼层 |阅读模式
3mdsmax5快捷键说明
安装方法
将kjj目录中的所有文件拷贝至3dsmax安装目录中的ui目录下,覆盖源文件,启动3dsmax即可使用快捷键
快捷键说明
1、        创建类
(1)        基本体
Box Object                                  3                                        Cylinder Object                                4
Sphere Object                        5                                        Cone Object                                Shift+V
Torus Object                        Shift+Q                                Tube Object                                Shift+U
(2)        扩展体
ChamferBox Object                Shift+3                                Chamfer Cylinder Object                Shift+4
(3)        基本型
Rectangle Shape                        7                                        Circle Shape                                        8
Line Shape                                9                                        Arc Shape                                        Shift+A
Arc Shape                                Shift+A                                 Text Shape                                        Shift+T
Section Shape                        Shift+S
(4)        复合体
Boolean Compound Object        Shift+B                                Loft Compound Object                        Shift+F
(5)        灯光、相机
Target Camera                        Shift +X                                 Target Directional Light                Shift+D
Target Spotlight                        Shift+P                                Omni Light                                Shift+O
Hide Cameras Toggle                Shift+C                                Hide Lights Toggle                        Shift+L
2、        编辑类
(1)        编辑器
Edit Mesh Modifier                6                                         Edit Spline Modifier                        0
Extrude Modifier                        Y                                        UVW Map Modifier                        Q
Smooth Modifier                        Alt+S                                Taper Modifier                                Alt+T
Bend Modifier                        Alt+B                                Bevel Modifier                                Alt+V
Lattice Modifier                        Alt+L                                XForm Modifier                                Alt+X
Optimize Modifier                Alt+O                                 FFD 3x3x3 Modifier                        Alt+F
FFD Box Modifier                Ctrl+F                                FFD 2x2x2 Modifier                        Alt+Ctrl+F
Delete Objects                        Delete
(2)        次物体
Sub-object Selection Toggle        O
Sub-object Level Cycle        ;
Attach (Spline)                        Ctrl+Q                                Attach Multiple (Spline)                Alt+Q
Refine (Spline)                        Insert                                Outline (Spline)                                Shift+Ctrl+O
3、        主工具条、下拉菜单
(1)        选择类
Select-by-Name Dialog        N                                        Edit Named Selections                        Shift+N
Window / Crossing Toggle        F4                                        Cycle Selection Method                ,
Select By Color                        Alt+Ctrl+C                         Select All                                        Alt+Ctrl+A
Select Invert                        Alt+I                                 Select None                                Ctrl+D
Selection Lock Toggle                Space
(2)        坐标类
Restrict to X                        F5                                        Restrict to Y                                F6
Restrict to Z                        F7                                        Restrict Plane Cycle                        F8
Local Coordinate System        End                                        View Coordinate System                Home
Center Point Cycle                `                                        Scale Cycle                                F2
(3)        编辑类
Align                                        Alt+A                                 Array                                                Alt+R
Mirror Tool                        Alt+M                                Transform Type-In Dialog                F12
Clone                                Alt+C
(4)        捕捉类
Snap Toggle                        S                                        Angle Snap Toggle                        A
(5)        渲染类
Render Scene                        F9                                         Quick Render                                F10
Render Last                        F11                                        Show Last Rendering                        Ctrl+I
(6)        其他类
Redo Scene Operation                Ctrl+A                                Undo Scene Operation                        Ctrl+Z
Material Editor                        M
(7)        群组
Group Open                        Alt+2                                        Group                                        2
Group Close                        Ctrl+2                                Group Explode                                Shift+2
(8)        文件类
Open File                                Ctrl+O                                Import File                                        Ctrl+P
Merge File                                Ctrl+M                                Save File As                                Alt+Ctrl+S
Save File                                Ctrl+S                                Save Selected                                Shift+Ctrl+S
Summary Info                        Shift+I
4、        显示类
Top View                                T                                         Bottom View                                B
Front View                                F                                         Back View                                        K
Left View                                L                                         Right View                                        R
Camera View                        C                                         Isometric User View                        U
Rotate View Mode                V                                         Backface Cull Toggle                        Alt+K
Pan View                                P                                        Pan Viewport                                I
Wireframe / Smooth+Highlights Toggle        F3
Maximize Viewport Toggle        W
Zoom Region Mode                Ctrl+W                                 Zoom Extents All                        E
Zoom Extents Selected                Shift+E                                Zoom Mode                                Z
Zoom In 2X                                =                                         Zoom Out 2X                                -
Zoom In 2X All                        Ctrl+=                                 Zoom Out 2X All                        Ctrl+-
Transform Gizmo Toggle        X
Show All Grids Toggle        Shift+G
Freeze Unselected                NumPad 4                                 Freeze Selection                                NumPad 5
Unfreeze All                        NumPad 6                         Hide Unselected                                NumPad 7
Hide Selection                        NumPad 8                                Unhide All                                        NumPad 9
发表于 2005-3-26 12:04:17 | 显示全部楼层
好好人啊,谢谢楼主
发表于 2005-3-26 12:20:35 | 显示全部楼层
好用吗,有没有快捷键的汉语说明呀
GMT+8, 2026-11-3 13:43 , Processed in 0.426293 second(s), 36 queries , Gzip On.
