查看: 1640|回复: 4
[分享]:cad快捷键
发表于 2005-3-26 20:50:58 | 显示全部楼层 |阅读模式
3A,        *3DARRAY
3DO,       *3DORBIT
3F,        *3DFACE
3P,        *3DPOLY
A,         *ARC
ADC,       *ADCENTER
AA,        *AREA
AL,        *ALIGN
AP,        *APPLOAD
AR,        *ARRAY
ATT,       *ATTDEF
-ATT,      *-ATTDEF
ATE,       *ATTEDIT
-ATE,      *-ATTEDIT
ATTE,      *-ATTEDIT
B,         *BLOCK
-B,        *-BLOCK
BH,        *BHATCH
BO,        *BOUNDARY
-BO,       *-BOUNDARY
BR,        *BREAK
C,         *CIRCLE
CH,        *PROPERTIES
-CH,       *CHANGE
CHA,       *CHAMFER
COL,       *COLOR
COLOUR,    *COLOR
CO,        *COPY
D,         *DIMSTYLE
DAL,       *DIMALIGNED
DAN,       *DIMANGULAR
DBA,       *DIMBASELINE
DBC,       *DBCONNECT
DCE,       *DIMCENTER
DCO,       *DIMCONTINUE
DDI,       *DIMDIAMETER
DED,       *DIMEDIT
DI,        *DIST
DIV,       *DIVIDE
DLI,       *DIMLINEAR
DO,        *DONUT
DOR,       *DIMORDINATE
DOV,       *DIMOVERRIDE
DR,        *DRAWORDER
DRA,       *DIMRADIUS
DS,        *DSETTINGS
DST,       *DIMSTYLE
DT,        *DTEXT
DV,        *DVIEW
E,         *ERASE
ED,        *DDEDIT
EL,        *ELLIPSE
EX,        *EXTEND
EXIT,      *QUIT
EXP,       *EXPORT
EXT,       *EXTRUDE
F,         *FILLET
FI,        *FILTER
G,         *GROUP
-G,        *-GROUP
GR,        *DDGRIPS
H,         *BHATCH
-H,        *HATCH
HE,        *HATCHEDIT
HI,        *HIDE
I,         *INSERT
-I,        *-INSERT
IAD,       *IMAGEADJUST
IAT,       *IMAGEATTACH
ICL,       *IMAGECLIP
IM,        *IMAGE
-IM,       *-IMAGE
IMP,       *IMPORT
IN,        *INTERSECT
INF,       *INTERFERE
IO,        *INSERTOBJ
L,         *LINE
LA,        *LAYER
-LA,       *-LAYER
LE,        *QLEADER
LEN,       *LENGTHEN
LI,        *LIST
LINEWEIGHT, *LWEIGHT
LO,        *-LAYOUT
LS,        *LIST
LT,        *LINETYPE
-LT,       *-LINETYPE
LTYPE,     *LINETYPE
-LTYPE,    *-LINETYPE
LTS,       *LTSCALE
LW,        *LWEIGHT
M,         *MOVE
MA,        *MATCHPROP
ME,        *MEASURE
MI,        *MIRROR
ML,        *MLINE
MO,        *PROPERTIES
MS,        *MSPACE
MT,        *MTEXT
MV,        *MVIEW
O,         *OFFSET
OP,        *OPTIONS
ORBIT,     *3DORBIT
OS,        *OSNAP
-OS,       *-OSNAP
P,         *PAN
-P,        *-PAN
PA,        *PASTESPEC
PARTIALOPEN, *-PARTIALOPEN
PE,        *PEDIT
PL,        *PLINE
PO,        *POINT
POL,       *POLYGON
PR,        *OPTIONS
PRCLOSE,   *PROPERTIESCLOSE
PROPS,     *PROPERTIES
PRE,       *PREVIEW
PRINT,     *PLOT
PS,        *PSPACE
PU,        *PURGE
R,         *REDRAW
RA,        *REDRAWALL
RE,        *REGEN
REA,       *REGENALL
REC,       *RECTANGLE
REG,       *REGION
REN,       *RENAME
-REN,      *-RENAME
REV,       *REVOLVE
RM,        *DDRMODES
RO,        *ROTATE
RPR,       *RPREF
RR,        *RENDER
S,         *STRETCH
SC,        *SCALE
SCR,       *SCRIPT
SE,        *DSETTINGS
SEC,       *SECTION
SET,       *SETVAR
SHA,       *SHADE
SL,        *SLICE
SN,        *SNAP
SO,        *SOLID
SP,        *SPELL
SPL,       *SPLINE
SPE,       *SPLINEDIT
ST,        *STYLE
SU,        *SUBTRACT
T,         *MTEXT
-T,        *-MTEXT
TA,        *TABLET
TH,        *THICKNESS
TI,        *TILEMODE
TO,        *TOOLBAR
TOL,       *TOLERANCE
TOR,       *TORUS
TR,        *TRIM
UC,        *DDUCS
UCP,       *DDUCSP
UN,        *UNITS
-UN,       *-UNITS
UNI,       *UNION
V,         *VIEW
-V,        *-VIEW
VP,        *DDVPOINT
-VP,       *VPOINT
W,         *WBLOCK
-W,        *-WBLOCK
WE,        *WEDGE
X,         *EXPLODE
XA,        *XATTACH
XB,        *XBIND
-XB,       *-XBIND
XC,        *XCLIP
XL,        *XLINE
XR,        *XREF
-XR,       *-XREF
Z,         *ZOOM
; The following are alternative aliases and aliases as supplied
;  in AutoCAD Release 13.
AV,        *DSVIEWER
CP,        *COPY
DIMALI,    *DIMALIGNED
DIMANG,    *DIMANGULAR
DIMBASE,   *DIMBASELINE
DIMCONT,   *DIMCONTINUE
DIMDIA,    *DIMDIAMETER
DIMED,     *DIMEDIT
DIMTED,    *DIMTEDIT
DIMLIN,    *DIMLINEAR
DIMORD,    *DIMORDINATE
DIMRAD,    *DIMRADIUS
DIMSTY,    *DIMSTYLE
DIMOVER,   *DIMOVERRIDE
LEAD,      *LEADER
TM,        *TILEMODE
; Aliases for Hyperlink/URL Release 14 compatibility
SAVEURL, *SAVE
OPENURL,   *OPEN
INSERTURL, *INSERT
; Aliases for commands discontinued in AutoCAD 2000:
AAD,        *DBCONNECT
AEX,        *DBCONNECT
ALI,        *DBCONNECT
ASQ,        *DBCONNECT
ARO,        *DBCONNECT
ASE,        *DBCONNECT
DDATTDEF,   *ATTDEF
DDATTEXT,   *ATTEXT
DDCHPROP,   *PROPERTIES
DDCOLOR,    *COLOR
DDLMODES,   *LAYER
DDLTYPE,    *LINETYPE
DDMODIFY,   *PROPERTIES
DDOSNAP,    *OSNAP
DDUCS,      *UCS
; Tangent Aliases
;; 轴网
ZXZW,  *T61_TRectAxis
HXZW,  *T61_TArcAxis
CHZW,  *T61_TInsAAxis
QSZW,  *T61_TWall2Axis
LDZB,  *T61_TAxisDim2p
ZDZB,  *T61_TAxisDimp
CPZH,  *T61_TReAxisNo
DZBH,  *T61_TAxisNo
TBZH,  *T61_TAddLabel
SCZH,  *T61_TDelLabel
TJZX,  *T61_TInsAxis
TJJZ,  *T61_TInsAxisR
ZXCJ,  *T61_TClipAxis
;;柱子
BZZ,   *T61_TInsColu
JZ,    *T61_TCornColu
PZZZ,  *T61_TPolyColu
GGD,   *T61_TChHeight
GZZ,   *T61_TFortiColu
TJB,   *T61_TStatVolume
TJZB,  *T61_TPrjVolume
;;墙体
HZQT,  *T61_TWall
BLMQ,  *T61_TCurtainWall
DFJQ,  *T61_TDivWall
TJXQ,  *T61_TVirtWall
DXBQ,  *T61_TSWall
ZXSQ,  *T61_TAxisWall
DQJ,   *T61_TFillet
XQJ,   *T61_TFixWall
BXDQ,  *T61_TAlignWall
GQH,   *T61_TWallTHick
GWQH,  *T61_TExtThick
QDFK,  *T61_TChWallTerm
JBWC,  *T61_TAddInsulate
XBWC,  *T61_TDelInsulate
GWQG,  *T61_TChEWallHeight
YXLM,  *T61_TShapeWall
JXLM,  *T61_TDelWallShape
QMUCS, *T61_TUcsWall
SBNW,  *T61_TMarkWall
ZDNQ,  *T61_TMarkIntWall
ZDWQ,  *T61_TMarkExtWall
JLWQ,  *T61_THLExtWall
QTZX,  *T61_TAddPatch
GXZX,  *T61_TAUpdPatch
PXSX,  *T61_TWall2Curve
JXDQ,  *T61_TAdjWallBase
;;门窗
MC,    *T61_TOpening
DXC,   *T61_TBanWin
ZJC,   *T61_TCornerWin
YXD,   *T61_TPolyHole
JMCT,  *T61_TOpSlot
XMCT,  *T61_TDelOpSlot
GMCM,  *T61_TChWinLab
MCJC,  *T61_TValidOp
MCB,   *T61_TStatOp
MCZB,  *T61_TPrjOp
MCYX,  *T61_TOpTem
JMKX,  *T61_TDoorLine
BHFW,  *T61_TResetLabPos
NWFZ,  *T61_TMirWinIO
ZYFZ,  *T61_TMirWinLR
CLYS,  *T61_TMapWinFrame
CLZK,  *T61_TExpWinFrame
JZST,  *T61_TOpeningSlot
;;房间屋顶
CXMJ,  *T61_TSpArea
SSFJ,  *T61_TUpdSpace
FJLK,  *T61_TSpOutline
FJDM,  *T61_TSpGround
BZJJ,  *T61_TSan
BZGD,  *T61_TApart
BZGB,  *T61_TClap
SWDX,  *T61_TRoflna
RYPD,  *T61_TSlopeRoof
JLHC,  *T61_TDormer
TNMJ,  *T61_TApartArea
MJLJ,  *T61_TPlusText
JTJX,  *T61_TKickBoard
DTJX,  *T61_TBreakKickBoard
;;楼梯其他
ZXTD,  *T61_TLStair
YHTD,  *T61_TAStair
RYTD,  *T61_TCStair
TJFS,  *T61_THandRail
SPLT,  *T61_TRStair
DT,    *T61_TElevator
YT,    *T61_TBalcony
TJ,    *T61_TStep
PD,    *T61_TAscent
EWSS,  *T61_Toutlna
SWSS,  *T61_TOutl3d
NWGC,  *T61_TElevDiff
LJFS,  *T61_TLinkHand
DPLT,  *T61_TMultiStair
;;造型工具
PB,    *T61_TSlab
SB,    *T61_TVertSlab
LJQM,  *T61_TCurveMesh
LGK,   *T61_TRailLib
LG,    *T61_TRail
LJPL,  *T61_TRail
STZM,  *T61_TSol2Face
MPHC,  *T61_TMergeFace
SWQG,  *T61_TClip3D
YQBX,  *T61_THideEdge
HXBM,  *T61_TCurve2Face
BJMT,  *T61_TPolyMesh
DGJM,  *T61_TSlope
SWWJ,  *T61_TNetShelf
XZM,   *T61_TLine2Face
;;立面
JZLM,  *T61_TBudElev
DCLM,  *T61_TStdElev
GJLM,  *T61_TObjElev
LMMC,  *T61_TEWinLib
LMYT,  *T61_TEBalLib
LMLK,  *T61_TElevOutline
MCCS,  *T61_TEWPara
;;剖面
JZPM,  *T61_TBudSect
DCPM,  *T61_TStdSect
GJPM,  *T61_TObjSect
;;日照分析
JZGD,  *T61_TPoly2Build
DRJZ,  *T61_TFloor2Build
SXCC,  *T61_TSeqSunWin
CPCH,  *T61_TOrderSunWin
LDCC,  *T61_TInsWin2p
RZSK,  *T61_TRay2Time
CRZB,  *T61_TWinSunAna
CRZX,  *T61_TWinSunRay
DDFX,  *T61_TSunSPoint
DUFX,  *T61_TSunMPoint
YYLK,  *T61_TShadow2d
DZSX,  *T61_TSunEqCurve
RZFZ,  *T61_TShadow
YYCC,  *T61_TDelShadow
DDGX,  *T61_TPosSunRay
RZSZ,  *T61_TSetSunPrec
DLWZ,  *T61_TCityData
;;文字表格
WZYS,  *T61_TStyleEx
ZJZJ,  *T61_TTextAdjust
DHWZ,  *T61_TText
WZZH,  *T61_TTextConv
WZHB,  *T61_TTextMerge
WZPB,  *T61_TTextMask
XJBG,  *T61_TNewSheet
QPBJ,  *T61_TSheetEdit
DYBJ,  *T61_TCellEdit
DYHB,  *T61_TCellMerge
BHBJ,  *T61_TRowEdit
BLBJ,  *T61_TColEdit
FZJ,   *T61_TBig5_Gb
JZF,   *T61_TGB_Big5
CZTH,  *T61_TRepFind
;;尺寸标注
MCBZ,  *T61_TDim3
QHBZ,  *T61_TDimWall
QZBZ,  *T61_TDimWC
LDBZ,  *T61_TDimTP
ZDBZ,  *T61_TDimMP
BJBZ,  *T61_TDimRad
ZJBZ,  *T61_TDimDia
JDBZ,  *T61_TDimAng
GGWZ,  *T61_TChDimText
WZFW,  *T61_TResetDimP
WZFZ,  *T61_TResetDimT
CCZT,  *T61_TDimAdjust
CJYS,  *T61_TDimTrimExt
QXCC,  *T61_TDimDel
LJCC,  *T61_TMergeDim
ZBCC,  *T61_TBreakDim
QHJB,  *T61_TDimTog
CCZH,  *T61_TConvDim
HCBZ,  *T61_TDimArc
;;符号标注
DZBG,  *T61_TElev
LZBG,  *T61_TMElev
ZXSY,  *T61_TIndexPTr
PQSY,  *T61_TIndexSec
SYTM,  *T61_TIndexDim
PMPQ,  *T61_TSection
DMPQ,  *T61_TSection1
JTYZ,  *T61_TArrow
YCBZ,  *T61_TLeader
ZFBZ,  *T61_TComposing
HDCZ,  *T61_TSymmetry
HZBZ,  *T61_TNorthThumb
TMBZ,  *T61_TDrawingName
JZDX,  *T61_TRupture
ZZBD,  *T61_TCoord
ZBJC,  *T61_TCheckCoord
;;图库图案
TYTK,  *T61_TKW
TKZH,  *T61_TBlkConv
JXPB,  *T61_TBlkMask1
JQPB,  *T61_TBlkMask2
QXPB,  *T61_TBlkUnMask
TKGC,  *T61_TBlkLay
SEWK,  *T61_TMVBlock
QEWK,  *T61_TChMvBlock
XTA,   *T61_TLinePattern
JSWK,  *T61_TMkBlk3d
;;设置观察
RJYL,  *TCurTips
LCB,   *T61_TFloorList
SWZH,  *T61_TGroupFloor
TXBX,  *T61_TMap2D
DQCG,  *T61_TLHeight
DQBL,  *T61_TPScale
SXSK,  *T61_TUpdView
DTGC,  *T61_T3DO
XJTS,  *T61_TCamera
WQEW,  *TShow2D
WQSW,  *TShow3D
ZDQD,  *TShowAuto
JBYC,  *T61_TMkHide
JBKJ,  *T61_TLocVis
HFKJ,  *T61_TUnHide
DXXZ,  *T61_TSelObj
DXCX,  *T61_TobjInfo
DXBJ,  *T61_TObjEdit
XNMY,  *T61_TVrCamera
HRDH,  *T61_TPathVideo
CSDH,  *T61_TWalkVideo
SKFD,  *T61_TMaxVport
SKHF,  *T61_TResVport
JDXR,  *T61_TQuickRender
STMP,  *T61_TFullView
STCP,  *T61_TSaveView
DWGC,  *T61_TCamLocator
STGD,  *T61_TFixView
;; 渲染
YSTC,  *T61_TFillColor
TPTC,  *T61_TFillImage
CZFZ,    *T61_TMaterial
CZGl,   *T61_TMatMan
;;工具
ZYFZ,  *T61_TDragCopy
ZYYD,  *T61_TDragMove
YW,    *T61_TMove
HDGL,  *T61_TSLb
FX,    *T61_TRevPline
BJ,    *T61_TUPoly
CJ,    *T61_TSPoly
JJ,    *T61_TIPoly
XCCX,  *T61_TRemoveDup
CLBJ,  *T61_TGetExtend
TYBG,  *T61_TModElev
SSLK,  *T61_TSeOutline
TXCJ,  *T61_TClip
TXQG,  *T61_TCutDrawing
ZYNT,  *T61_TPasteClip
SZLM,  *T61_TUcsElev
JX,    *T61_TRect
;;文件接口
DKWJ,  *T61_TOpen
FJDX,  *T61_TExplode
LCJB,  *T61_TSaveAs
JTZH,  *T61_TConvTch
PLZJ,  *T61_TBatSave
;;布图
DYSK,  *T61_TMakeVp
GBBL,  *T61_TChScale
BJBC,  *T61_TSaveLayout
BJHF,  *T61_TRestoreLayout
BJXZ,  *T61_TLayoutRot
;;体量建模
CFT,  *T61_TSolBox
YZT,  *T61_TSolCylinder
YTT,  *T61_TSolCone
QT,   *T61_TSolSphere
XT,   *T61_TSolWedge
QQT,  *T61_TSOLSPHEREPIECE
SLZT, *T61_TSOLPYRAMID
QGT,  *T61_TSOLARCBRIDGE
YGT,  *T61_TSOLARCCOLUMN
SQT,  *T61_TSOLHILLWALL
JMLS, *T61_TSolExtrude
JMXZ, *T61_TSolRevolve
JMFY, *T61_TSolSweep
BEBJ, *T61_TSolUnion
BECJ, *T61_TSolSubtract
BEJJ, *T61_TSolIntersect
BJST, *T61_TSolEdit
STQG, *T61_TSolSlice
FLZJ, *T61_TSolSeparate
WQFL, *T61_TSolSeparateAll
QCCS, *T61_TSolPurge
发表于 2005-3-26 20:56:32 | 显示全部楼层
这样的帖子太多,楼主都不会看看吗?
发表于 2005-3-26 22:15:11 | 显示全部楼层
老大这么多怎么看得过来啊,能不能用上啊
已领礼包: 194个
发表于 2005-3-26 22:32:55 | 显示全部楼层
好多啊,把几个常用的记住就可以了。
发表于 2005-3-27 00:05:58 | 显示全部楼层
这个也可以发啊!
GMT+8, 2026-10-23 07:28 , Processed in 0.501812 second(s), 40 queries , Gzip On.
