查看: 1056|回复: 3
[求助]:2002的,怎样插入外部图块?
发表于 2005-3-27 16:58:48 | 显示全部楼层 |阅读模式
我用的是autocad2002版的,请问用vba编程,怎样插入外部图块?
请给出具体点的事例代码。
谢谢!
*-*8
发表于 2005-3-27 22:27:28 | 显示全部楼层
帮助里的例子都不愿意看?
Sub Example_InsertBlock()
    ' This example creates a block containing a circle.
    ' It then inserts the block.
    ' Create the block
    Dim blockObj As AcadBlock
    Dim insertionPnt(0 To 2) As Double
    insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0#
    Set blockObj = ThisDrawing.Blocks.Add(insertionPnt, "CircleBlock")
    ' Add a circle to the block
    Dim circleObj As AcadCircle
    Dim center(0 To 2) As Double
    Dim radius As Double
    center(0) = 0: center(1) = 0: center(2) = 0
    radius = 1
    Set circleObj = blockObj.AddCircle(center, radius)
    ' Insert the block
    Dim blockRefObj As AcadBlockReference
    insertionPnt(0) = 2#: insertionPnt(1) = 2#: insertionPnt(2) = 0
    Set blockRefObj = ThisDrawing.ModelSpace.InsertBlock(insertionPnt, "CircleBlock", 1#, 1#, 1#, 0)
    ZoomAll
End Sub
 楼主| 发表于 2005-3-28 08:27:28 | 显示全部楼层
好象这不是插入外部块的例子吧,插入外部块就是插入不打开另一个已存在图形中的块,我的机子只能装了2002,在2004中用objectdbx.
请问怎么做?
谢谢
发表于 2005-3-28 21:13:41 | 显示全部楼层 |阅读模式
插入外部块的正确解释是插入外部图形文件,而不是插入不打开另一个已存在图形中的块,提问题时请表述清楚,另,2002一样可以用objectdbx,参见:
http://www.vba.cn/bbs/dispbbs.as ... ;ID=6098&page=1
GMT+8, 2026-11-3 18:27 , Processed in 0.644993 second(s), 38 queries , Gzip On.
