查看: 899|回复: 4
[求助] [求助]:编写一下在图纸空间和模型空间自动切换的程式.
发表于 2005-3-31 09:21:24 | 显示全部楼层 |阅读模式
最好能够自定义图框.然后生成每一个模型的长宽高尺雨!
发表于 2005-3-31 10:22:13 | 显示全部楼层
怎么没人说话啊
发表于 2005-3-31 16:56:09 | 显示全部楼层
我这里有一个类似的,在模型空间选定范围后,自动切换到图纸空间,根据你输入的比例大小画图mv窗口!r14下编写!
  1. (defun set_ini ()
  2.   (setq cmdsave (getvar "cmdecho"))
  3.   (setq os (getvar "OSMODE"))
  4.   (setvar "cmdecho" 0)
  5.   (setvar "OSMODE" 0)
  6. ) ;_ end of defun
  7. (defun err_new (msg)
  8.   (princ msg)
  9.   (set_close)
  10. ) ;_ end of defun
  11. (defun set_close ()
  12.   (setvar "OSMODE" os)
  13.   (setvar "cmdecho" cmdsave)
  14.   (setq *error* err_old)
  15. ) ;_ end of defun
  16. (defun c:arr ()
  17.   (setq err_old *error*
  18.         *error* err_new
  19.   ) ;_ end of setq
  20.   (set_ini)
  21.   (princ "\n请点取需要出图范围第一角点:\n")
  22.   (setq FP (getpoint))
  23.   (setq SP (getcorner FP "\n请点取出图范围另一角点:\n"))
  24.   (setq HT (abs (- (cadr sp) (cadr fp))))
  25.   (setq WD (abs (- (car sp) (car fp))))
  26.   (setq Sca (getstring "\n请输入出图比例<1/100>:"))
  27.   (if (= sca "")
  28.     (setq sca "1/100")
  29.   ) ;_ end of if
  30.   (setq scal (atoi (substr sca 3)))
  31.   (command "tilemode" 0)
  32.   (command "_zoom" "e")
  33.   (princ "\n请点取图的左下角点:\n")
  34.   (setq BLP (getpoint))
  35.   (setq        TRP (list (+ (car BLP) (/ Wd scal))
  36.                   (+ (cadr BLP) (/ HT scal))
  37.                   0
  38.             ) ;_ end of list
  39.   ) ;_ end of setq
  40.   (command "_zoom" BLP TRP)
  41.   (command "_mview" BLP TRP)
  42.   (command "_mspace")
  43.   (command "_zoom" fp sp)
  44.   (command "_zoom" (strcat sca "xp"))
  45.   (command "_pspace")
  46.   (command "_zoom" "e")
  47.   (set_close)
  48.   (gc)
  49.   (princ)
  50. ) ;_ end of defun
发表于 2005-3-31 21:28:03 | 显示全部楼层
能不能编一个2004的
发表于 2005-3-31 21:37:59 | 显示全部楼层
14下能用的2004下也应该没问题的!
GMT+8, 2026-11-6 05:12 , Processed in 0.412285 second(s), 39 queries , Gzip On.
