查看: 1087|回复: 6
[VBA程序]:[VBA程序]:会vba的过来帮忙啊
发表于 2005-4-2 11:19:42 | 显示全部楼层 |阅读模式
求助:我在创建了几条封闭曲线,用addregion形成面后,怎么不能拉伸啊,下面是我的程序
Option Explicit
Dim ³ÝÂÖCAD As AcadApplication
Const pi As Double = 3.1415926
Private Sub Command1_Click()   'È¡Ïû¼ü
Me.Text1 = 27  'µ¶¾ß³ÝÊý
Me.Text2 = 5 'µ¶¾ßÄ£Êý
Me.Text3 = 20  'µ¶¾ßѹÁ¦½Ç
Me.Text4 = 100 'Ãæ³ÝÂÖ³ÝÊý
Me.Text5 = 280 'Ãæ³ÝÂÖ×î´óÍâ°ë¾¶
Me.Text6 = 250  'Ãæ³ÝÂÖ×îСÄÚ°ë¾¶
End Sub
Private Sub Command2_Click()
On Error Resume Next
'³ÝÂÖCAD.ActiveDocument.Close
³ÝÂÖCAD.Documents.Add
Dim ns, n2, m, a, r, rb, ra, rf, csb, b, ha, hf, d, thi
Dim th(3)
Dim i
Dim r2max, r2min, fgheight
ns = Me.Text1  'µ¶¾ß³ÝÊý
m = Me.Text2   'Ä£Êý
a = Me.Text3 * pi / 180   'ѹÁ¦½Ç
n2 = Me.Text4    'Ãæ³ÝÂÖ³ÝÊý
r2max = Me.Text5    'Ãæ³ÝÂÖ×î´óÍâ°ë¾¶
r2min = Me.Text6    'Ãæ³ÝÂÖ×îСÄÚ°ë¾¶
fgheight = r2max / 4  'Ãæ³ÝÂֳݿí
Dim newdirection(0 To 2) As Double
newdirection(0) = 1: newdirection(1) = 0.5: newdirection(2) = 0.5
³ÝÂÖCAD.ActiveDocument.ActiveViewport.Direction = newdirection
³ÝÂÖCAD.ActiveDocument.ActiveViewport = ³ÝÂÖCAD.ActiveDocument.ActiveViewport
³ÝÂÖCAD.ActiveDocument.Layers(0).Color = acRed
³ÝÂÖCAD.ActiveDocument.SendCommand "_shademode" + vbCr + "_G" + vbCr    '×ÅÉ«
r = m * ns / 2
rf = (r - 1.25 * m)
rb = r * Cos(a)
ra = r + m * 1.25
Dim height As Double
height = ra / 3  'µ¶¾ß³Ý¿í
Dim ³ÝÂÖ3D As Acad3DSolid
Dim cenpt(0 To 2) As Double
Dim topt(0 To 2) As Double
cenpt(0) = 0: cenpt(1) = 0: cenpt(2) = 0
topt(0) = 0: topt(1) = 0: topt(2) = -height / 2
'Set ³ÝÂÖ3D = ³ÝÂÖCAD.ActiveDocument.ModelSpace.AddCylinder(cenpt, ra, height)
'Dim Öá¿× As Acad3DSolid
'Set Öá¿× = ³ÝÂÖCAD.ActiveDocument.ModelSpace.AddCylinder(cenpt, ra / 3, height)
'³ÝÂÖ3D.Boolean acSubtraction, Öá¿×
'³ÝÂÖ3D.Color = acBlue
'ZoomAll
'Dim plineobj(0) As AcadLWPolyline
csb = Cos(a) * (pi * m / 2 + m * ns * (Tan(a) - (a)))
th(1) = (pi * m * Cos(a) - csb) / (2 * rb)
th(0) = th(1) / 3
th(2) = th(1) + Tan(a) - a
th(3) = th(1) + Tan(acos(rb / ra)) - acos(rb / ra)
thi = pi / ns
Dim curves(0 To 4) As AcadEntity
Dim points0(0 To 5) As Double
Dim points1(0 To 8) As Double
points0(0) = 0: points0(1) = rf      'µÚ0µã
points0(2) = rf * Sin(th(0)): points0(3) = rf * Cos(th(0))     'µÚ1µã
points0(4) = rb * Sin(th(1)): points0(5) = rb * Cos(th(1))     'µÚ2µã
Dim starttan(0 To 2) As Double
Dim endtan(0 To 2) As Double
starttan(0) = 0: starttan(1) = 0: starttan(2) = 0
endtan(0) = 0.5: endtan(1) = 0.5: endtan(2) = 0
points1(0) = points0(4): points1(1) = points0(5): points1(2) = 0    'µÚ2µã
points1(3) = r * Sin(th(2)): points1(4) = r * Cos(th(2)): points1(5) = 0     'µÚ3µã
points1(6) = ra * Sin(th(3)): points1(7) = ra * Cos(th(3)): points1(8) = 0   'µÚ4µã
If rb < rf Then    '&raquo;ù&Ocirc;&sup2;&ETH;&iexcl;&Oacute;&Uacute;&cedil;ù&Ocirc;&sup2;
points0(2) = points1(3) * 0.2: points0(3) = points0(1) + 0.25 * m * 0.03    '&micro;&Uacute;1&micro;&atilde;
points0(4) = points1(3) * 0.7: points0(5) = points0(1) + 0.25 * m * 0.8     '&micro;&Uacute;2&micro;&atilde;
points1(0) = points0(4) * 0.2: points1(1) = points0(5): points1(2) = 0      '&micro;&Uacute;2&micro;&atilde;
End If
'&Oacute;&Eacute;0&pound;&not;1&pound;&not;2&micro;&atilde;×é&sup3;&Eacute;
Set curves(0) = &sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddLightWeightPolyline(points0)
curves(0).SetBulge 1, 0.2
Set curves(1) = &sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddSpline(points1, starttan, endtan) '&Oacute;&Eacute;2,3,4&micro;&atilde;×é&sup3;&Eacute;
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
point1(0) = 0: point1(1) = 0: point1(2) = 0
point2(0) = 0: point2(1) = 1: point2(2) = 0
Set curves(2) = curves(1).Mirror(point1, point2)  '&micro;&para;&frac34;&szlig;&Oacute;&Ograve;±&szlig;&sup2;&iquest;·&Ouml;
Set curves(3) = curves(0).Mirror(point1, point2)
Set curves(4) = &sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddArc(cenpt, ra, pi / 2 - th(3), pi / 2 + th(3)) '&Ocirc;&sup2;&raquo;&iexcl;&sup2;&iquest;·&Ouml;
'curves.Color = acRed
'For i = 0 To 4
'Dim retval As Variant
'retval = curves(i).ArrayPolar(ns + 1, 2 * pi, cenpt)
'Next i
Dim cc As Variant
cc = &sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddRegion(curves)
Dim axispt(0 To 2) As Double
Dim axisdir(0 To 2) As Double
axispt(0) = 0: axispt(1) = 1: axispt(2) = 0
axisdir(0) = ra + fgheight / 2: axisdir(1) = 0: axisdir(2) = 0
Dim cc3d As Acad3DSolid
'Set cc3d = &sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddExtrudedSolid(cc(0), height, 0)
Set cc3d = &sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddRevolvedSolid(cc(0), axispt, axisdir, 2 * pi)
cc3d.Update
'Dim &sup3;&Yacute;&sup2;&Ucirc;3D As Acad3DSolid
'Set &sup3;&Yacute;&sup2;&Ucirc;3D = &sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddExtrudedSolid(&sup3;&Yacute;&sup2;&Ucirc;(0), height, 0)
'&sup3;&Yacute;&sup2;&Ucirc;3D.Update
'&sup3;&Yacute;&sup2;&Ucirc;3D.Move cenpt, topt
'Dim &sup3;&Yacute;&sup2;&Ucirc;3D&Otilde;ó&Aacute;&ETH; As Variant
'&sup3;&Yacute;&sup2;&Ucirc;3D&Otilde;ó&Aacute;&ETH; = &sup3;&Yacute;&sup2;&Ucirc;3D.ArrayPolar(ns + 1, 2 * pi, cenpt)
'For i = 0 To ns - 1
'&sup3;&Yacute;&Acirc;&Ouml;3D.Boolean acSubtraction, &sup3;&Yacute;&sup2;&Ucirc;3D&Otilde;ó&Aacute;&ETH;(i)
'Next i
'&sup3;&Yacute;&sup2;&Ucirc;3D.Delete
'&sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddRegion(curves).Delete
'&sup3;&Yacute;&sup2;&Ucirc;.Delete
'&sup3;&Yacute;&Acirc;&Ouml;3D.Update
ZoomAll
'Dim toppt(0 To 2) As Double
'toppt(0) = 0: toppt(1) = 0: toppt(2) = fgheight / 3
'Dim &Atilde;&aelig;&sup3;&Yacute;&Acirc;&Ouml;out As Acad3DSolid
'Dim &Atilde;&aelig;&sup3;&Yacute;&Acirc;&Ouml;in As Acad3DSolid
'Set &Atilde;&aelig;&sup3;&Yacute;&Acirc;&Ouml;out = &sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddCylinder(cenpt, r2max, fgheight)
'Set &Atilde;&aelig;&sup3;&Yacute;&Acirc;&Ouml;in = &sup3;&Yacute;&Acirc;&Ouml;CAD.ActiveDocument.ModelSpace.AddCylinder(cenpt, r2min, fgheight / 3)
'&Atilde;&aelig;&sup3;&Yacute;&Acirc;&Ouml;in.Move cenpt, toppt
'&Atilde;&aelig;&sup3;&Yacute;&Acirc;&Ouml;out.Boolean acSubtraction, &Atilde;&aelig;&sup3;&Yacute;&Acirc;&Ouml;in
'Dim axispt(0 To 2) As Double
'Dim axisdir(0 To 2) As Double
'axispt(0) = 0: axispt(1) = 1: axispt(2) = 0
'axisdir(0) = ra + fgheight / 2: axisdir(1) = 0: axisdir(2) = 0
'rotationagle = pi / 2
'&Atilde;&aelig;&sup3;&Yacute;&Acirc;&Ouml;out.Rotate3D cenpt, axispt, -pi / 2
'&Atilde;&aelig;&sup3;&Yacute;&Acirc;&Ouml;out.Move cenpt, axisdir
'Dim topt2(0 To 2) As Double
'topt2(0) = 0: topt2(1) = 0: topt2(2) = r2max - height / 2
'&sup3;&Yacute;&Acirc;&Ouml;3D.Move cenpt, topt2
End Sub
Private Sub Form_Load()
Me.Caption = "&sup3;&Yacute;&Acirc;&Ouml;&frac14;&Oacute;&sup1;¤&Egrave;&yacute;&Icirc;&not;&para;&macr;&raquo;&shy;·&Acirc;&Otilde;&aelig;"
Me.Left = (Screen.Width - Me.Width)
Me.Top = 0
Me.Text1 = 27
Me.Text2 = 5
Me.Text3 = 20
Me.Text4 = 100
Me.Text5 = 280
Me.Text6 = 250
Dim ns, n2, m, a, r, rb, ra, rf, csb, umax, u, b, ha, hf
ha = 1.25 '&sup3;&Yacute;&para;&yen;&cedil;&szlig;&Iuml;&micro;&Ecirc;&yacute;
hf = 1.25 '&sup3;&Yacute;&cedil;ú&cedil;&szlig;&Iuml;&micro;&Ecirc;&yacute;
b = 20 '&sup3;&Yacute;&iquest;í
Set &sup3;&Yacute;&Acirc;&Ouml;CAD = GetObject(, "autocad.application")
If Err Then
Err.Clear
Set &sup3;&Yacute;&Acirc;&Ouml;CAD = CreateObject("autocad.application")
If Err Then
MsgBox ("please install autocad")
Unload Me
Exit Sub
End If
End If
&sup3;&Yacute;&Acirc;&Ouml;CAD.WindowState = acMax
End Sub
发表于 2005-4-2 18:53:23 | 显示全部楼层
偶这看到的是乱码,另外程序太长了,把出错的地方标明一下
发表于 2005-4-2 19:04:22 | 显示全部楼层
在复制代码时,先打开中文输入法,就没乱码了。
发表于 2005-4-4 20:02:07 | 显示全部楼层
region 本来就是不可以拉伸的,只能UNION 和 sub
发表于 2005-4-5 15:47:25 | 显示全部楼层
最初由 scottfotis 发布
[B]region 本来就是不可以拉伸的,只能UNION 和 sub [/B]
搞清楚对象模型再发言
RetVal = object.AddExtrudedSolid(Profile, Height, TaperAngle)
Object
ModelSpace 集合, PaperSpace 集合, Block
使用该方法的对象。
Profile
轮廓对象; 仅用于输入
只能是 Region 对象。
Height
Double[双精度]; 仅用于输入
沿对象坐标系统的Z轴方向拉伸的高度。如果输入为正数, AutoCAD 将沿正 Z 轴方向拉伸对象。如果输入为负数,AutoCAD 将沿负 Z 轴的方向拉伸对象。
TaperAngle
Double[双精度]; 仅用于输入
拉伸的倾斜角度必须为弧度。倾斜角度的范围从 -90 到 +90 度。正角度是从基底向内倾斜,而负角度则向外倾斜。默认角度为0,它按与二维对象平面的垂直方向拉伸。
RetVal
3DSolid 对象
作为新创建的拉伸实体的 3DSolid 对象。
说明
只能拉伸二维平面的面域。
只有顶点连接的环才能拉伸锥形。大的倾斜角度或长的拉伸高度可能导致对象或对象的一部分在到达拉伸高度前自身相交。如果结果实体自身相交时,AutoCAD 将不允许任何拉伸。
发表于 2005-4-5 22:41:59 | 显示全部楼层
怎么全都是乱码呀?
为什么打开中文输入法就没有乱码了呢?
发表于 2005-4-12 09:19:57 | 显示全部楼层
有乱码,看不懂,请楼主重新发贴!!!!
GMT+8, 2026-11-3 20:19 , Processed in 0.561112 second(s), 44 queries , Gzip On.
