查看: 1457|回复: 4
[求助] [求助]:如何连续在屏幕上获得任意个点?
发表于 2003-2-24 23:22:57 | 显示全部楼层 |阅读模式
如何连续在屏幕上获得任意个点?用鼠标右键停止。
已领礼包: 145个
发表于 2003-2-25 01:50:10 | 显示全部楼层
Re: [求助]:如何连续在屏幕上获得任意个点?
最初由 JQKA 发布
[B]如何连续在屏幕上获得任意个点?用鼠标右键停止。 [/B]
循环里面用GETPOINT获得点,然后保存到一个表里面即可
  1. <normalfont>
  2. (while (setq pt (getpoint "\n拾取点<退出>:"))
  3.    (setq ptl (cons pt ptl))
  4. )
  5. (setq ptl (reverse ptl))
  6. </normalfont>
发表于 2003-2-25 14:05:22 | 显示全部楼层
最初由 JQKA 发布
请说明你的用途,好吗?
发表于 2003-2-25 20:41:46 | 显示全部楼层
(setq loop T)
(while loop
        (if (setq pt (getpoint "\n请点取点:"))
          (setq ptlist (cons pt ptlist))
          (setq loop nil)
已领礼包: 8个
发表于 2003-2-26 11:51:08 | 显示全部楼层
  1. ;;;(wHILE (PRINC (STRCAT "\n" (VL-PRINC-TO-STRING (GRREAD T)))))
  2. (defun C:CLOUD ()
  3.   (grtext -1 "\n 画云妆线程序开始...<钱勇编>")
  4.   (SETVAR "PLINEWID" 0)
  5.   (SETVAR "OSMODE" 0)
  6.   (SETQ A (GETPOINT "\n 请输入云状线的起始点:.."))
  7.   (setq p (grread T))
  8.   (princ)
  9.   (setq pT (cadr p))
  10.   (command "line" A PT "")
  11.   (SETQ LS (ENTLAST))
  12.   (setq line1 (entget LS))
  13.   (COMMAND "PLINE" A)
  14.   (setq p (grread T))
  15.   (setq k (car p))
  16.   (SETQ PT (cADR P))
  17.   (setq p1 (TRANS PT 1 0))
  18.   (setq line1 (subst (CONS 11 P1) (assoc 11 line1) line1))
  19.   (entmod line1)
  20.   (setq mm T)
  21.   (while mm
  22.     (setq line1 (subst (CONS 11 P1) (assoc 11 line1) line1))
  23.     (entmod line1)
  24.     (setq p (grread T))
  25.     (setq k (car p))
  26.     (setq pT (cadr p))
  27.     (IF        (or (= (type PT) 'INT) (= (type PT) 'REAL))
  28.       (SETQ P1 (lIST 0 0 0))
  29.       (SETQ P1 (TRANS PT 1 0))
  30.     )
  31.     (if        (= k 3)
  32.       (cOMMAND PT)
  33.     )
  34.     (IF        (= K 25)
  35.       (PROGN
  36.         (SETQ MM NIL)
  37.         (COMMAND A "")
  38.         (ENTDEL LS)
  39.       )
  40.     )
  41.   )
  42. ;;;_____________________________________
  43.   (setq ent (entlast))
  44.   (REDRAW ENT 3)
  45.   (setq ED1 (entget eNT))
  46.   (setq newed ent)
  47.   (ENTDEL NEWED)
  48.   (setq #len (length ED1))
  49.   (SETQ COUNT 0)
  50.   (WHILE (< COUNT #LEN)
  51.     (setq #it (NTH (- #LEN COUNT 1) ED1))
  52.     (SETQ COUNT (1+ COUNT))
  53.     (SETQ LTM (CAR #iT))
  54.     (IF        (/= 42 LTM)
  55.       (SETQ BIAO (CONS #IT BIAO))
  56.       (PROGN
  57.         (SETQ #IT (CONS 42 0.5))
  58.         (SETQ BIAO (CONS #IT BIAO))
  59.       )                                        ;PROGN
  60.     )                                        ;IF
  61.   )                                        ;while
  62.   (ENTMAKE BIAO)
  63.   (setq bizo nil)
  64.    (prompt ".云妆线")
  65.   (PRINC)
  66. )
GMT+8, 2026-11-3 13:04 , Processed in 0.557062 second(s), 40 queries , Gzip On.
