查看: 917|回复: 3
[求助]:怎么样才能用LSP程序实现添加文件支持路径?
发表于 2005-4-5 08:25:53 | 显示全部楼层 |阅读模式
已领礼包: 208个
发表于 2005-4-5 09:13:30 | 显示全部楼层
论坛中刚刚讨论过.你搜索一下.
(setq path "c:\\mycad"
op (vla-get-supportpath(setq af(vla-get-files(vla-get-preferences(vlax-get-acad-object))))))
(vla-put-supportpath af (strcat op ";" path))
发表于 2005-4-7 22:50:32 | 显示全部楼层
  1. (defun addpath (/ a pa lst ls1 path)
  2.   (setq    a    (getenv "ACAD")
  3.     pa   (getstring "\n盘符 : ")
  4.     ;;要增加的路径
  5.     lst  (list ":\\ct2004"       ":\\ct2004\\Support"
  6.            ":\\ct2004\\dwg"       ":\\ct2004\\2002"
  7.            ":\\ct2004\\Fonts"       ":\\ct2004\\2004"
  8.           )
  9.     ls1  (car lst)
  10.     path (strcat ";" pa ls1)
  11.     lst  (vl-remove ls1 lst)
  12.   )
  13.   (while lst
  14.     (setq ls1  (car lst)
  15.       path (strcat path (strcat ";" pa ls1))
  16.       lst  (vl-remove ls1 lst)
  17.     )
  18.   )
  19.   (setenv "ACAD" (strcat a path))
  20.   (getenv "ACAD")
  21. )
 楼主| 发表于 2005-4-8 08:12:36 | 显示全部楼层
谢谢!
GMT+8, 2026-11-6 05:13 , Processed in 0.502560 second(s), 36 queries , Gzip On.
