查看: 950|回复: 2
[求助] [求助]:怎样实现进度显示
发表于 2005-4-6 08:28:35 | 显示全部楼层 |阅读模式
在进行循环插入块的程序中
由于数量巨大,往往让人感到像当机
能不能像recover命令一样,下面显示进度
发表于 2005-4-6 09:31:07 | 显示全部楼层
你可以参考我给你的等分点程序
里面一个子程序用到了进度控制
.....当你需要串接的线很长时就会看到
进度显示了...
(defun hy_apline(ename1 / vla-obj endpoint ename startpoint i ss1 nn ssm ssn itemx);;;選擇一條線串接與之相聯的圖元為多義線
  (if (= "LWPOLYLINE" (cdr(assoc 0 (entget ename1)))) (command "._explode" ename ""))
  (setq ename (entlast))
  (setq vla-obj (vlax-ename->vla-object ename))
   (setq startpoint (vlax-curve-getstartpoint vla-obj)
         endpoint (vlax-curve-getendpoint vla-obj))
;(safearray-value(vlax-variant-value(vla-get-endpoint vla-obj))))
  (if (OR (= "POLYLINE" (cdr(assoc 0 (entget ename))))
          (= "LWPOLYLINE" (cdr(assoc 0 (entget ename)))))
  (setq i 1)(SETQ I 0))
  (setq j 0);;計數器歸0
  (setq nn 0)
  (princ " ─── \r")
  (while (> (distance startpoint endpoint) 0.0000001);(= (vla-get-closed vla-obj) :vlax-false)
    ;(setq ss1 (ssget "x" (list (cons -4  "<or") (cons 10 endpoint)(cons 11 endpoint) (cons -4  "or>"))))
    (setq ss1 (ssadd))
    (setq ssn (ssget "f" (list endpoint (polar endpoint 0.8 0.1))))
    (foreach itemx (ap-sslist ssn)
      (if (or (< (distance endpoint (vlax-curve-getstartpoint (vlax-ename->vla-object itemx))) 0.0000001)
              (< (distance endpoint (vlax-curve-getendpoint (vlax-ename->vla-object itemx))) 0.0000001))
          (setq ss1 (ssadd itemx ss1))
   (setq ss2 (ssadd))
   (setq ssm (ssget "f" (list startpoint (polar startpoint 0.8 0.1))))
    (foreach itemx (ap-sslist ssm)
      (if (or (< (distance startpoint (vlax-curve-getstartpoint (vlax-ename->vla-object itemx))) 0.0000001)
              (< (distance startpoint (vlax-curve-getendpoint (vlax-ename->vla-object itemx))) 0.0000001))
          (setq ss2 (ssadd itemx ss2))
   (setq ssg (addss ss1 ss2))
   (if (= 0 i)(command "pedit" ename "y" "j" ssg "" "")
               (command "pedit" ename  "j" ssg "" ""))
    (setq i (1+ i))
    (setq nn (1+ nn))
    (cond ((= nn 15)(princ  (strcat "線很長..正在串接中,請稍侯 ......  ───" "\r")));;;;;进度控制!!!
          ((= nn 30)(princ  (strcat "線很長..正在串接中,請稍侯 ......  ﹨﹨﹨" "\r")))
          ((= nn 45)(princ  (strcat "線很長..正在串接中,請稍侯 ......  │││" "\r")))
          ((= nn 60)(princ  (strcat "線很長..正在串接中,請稍侯 ......  ∕∕∕" "\r")))
    (if (> nn 60) (setq nn 1))
    (setq j (1+ j))
    (IF (and (= 1 (sslength ssg))(= (vla-get-closed vla-obj) :vlax-false))
          (setq startpoint '(0 0 0) endpoint '(0 0 0)));(alert "\n請注意!****串接不線不能封閉!")
  (if (> j 1000)(prompt (strcat "\n恭喜你一共把" (itoa (+ (* 2 j) 3)) "條線串接成了一個封閉的復線!")))
 楼主| 发表于 2005-4-6 10:14:43 | 显示全部楼层
谢谢舟兄
GMT+8, 2026-11-6 02:38 , Processed in 0.379919 second(s), 36 queries , Gzip On.
