查看: 1140|回复: 4
[其他]:评价一下你的ARX开发水平
发表于 2005-4-8 12:53:34 | 显示全部楼层 |阅读模式
今天偶然打开了一下ARX的sample文件夹,找到了下面一段文字,大家可以对照着看一下自己在ARX程序方面达到了什么程度
     Beginning Level:
         At this level the developer has an understanding of the AutoCAD database, and konws how to do the following:
            *  Open and close objects.
            *  Understand symbol tables and symbol table records and how to use interators.
            *  Understand the Named Objects Dictionary and Extension Dictionaries.
            *  Understand ObjectARX's standard objects and entities.
            *  Create a standard entity/object and manipulate its properties.
     Medium Level:
         At this level the developer knows how to:
            * Create a custom class derived from AcDbObject, AcDbEntity and understand what virtual functions need to be overridden as a result.
            * Understand transactions and transient and persistent reactors.
            * Understand the Multiple Document Interface.
            * Understand Document Management.
     High Level:
            * Create a custom class derived from AcDbCurve and understand what virtual functions need to be overridden as a result.
            * Understand how to use AcEdJig.
            * Using MFC with ObjectARX.
     Advanced Level:
            * Understand deep cloning.
            * Understand protocol extensions.
            * Understand COM and ActiveX as it pertains to AutoCAD and ObjectARX.
            * Understand Design Center, Input Point processing and Object Property Manager.
发表于 2005-4-8 18:07:37 | 显示全部楼层
是指南上的东东!
发表于 2005-4-9 11:06:18 | 显示全部楼层
需要用什么就学什么。
发表于 2005-4-9 13:10:29 | 显示全部楼层
够用就可以了,还能解决问题
发表于 2005-4-9 16:21:41 | 显示全部楼层
Medium Level:
GMT+8, 2026-11-22 09:10 , Processed in 0.586877 second(s), 19 queries , Gzip On, File On.
