查看: 863|回复: 2
[求助] [求助]:求帮忙检查程序错误(已经解决)
发表于 2005-4-11 19:38:50 | 显示全部楼层 |阅读模式
已经解决.....
发表于 2005-4-11 21:45:55 | 显示全部楼层
写半径
  1. (defun c:Wt ()
  2.   (setvar "cmdecho" 0)
  3.   (setq ffn (getfiled "写出文件" "" "txt" 1))
  4.   (setq ff (open ffn "w"))
  5.   (close ff)
  6.   (princ "\n请选择欲输出的圆...")
  7.   (setq ss (ssget))
  8.   (setq i 0)
  9.   (setvar "pdmode" 33)
  10.   (repeat (sslength ss)
  11.     (setq ssn (ssname ss i))
  12.     (setq endata (entget ssn))
  13.     (setq ff (open ffn "a"))
  14.     (foreach n (cdr (assoc 10 endata))
  15.       (princ (strcat (rtos n 2 9) " ") ff)
  16.     )
  17.     (princ (rtos (cdr (assoc 40 endata)) 2 9) ff)
  18.     (princ "\n" ff)
  19.     (close ff)
  20.     (setq i (1+ i))
  21.   )
  22.   (princ (strcat "\n写出文件 " ffn))
  23.   (prin1)
  24. )
 楼主| 发表于 2005-4-11 23:23:33 | 显示全部楼层
楼上的大哥写的不错.优化了很多,谢谢!
GMT+8, 2026-11-6 05:12 , Processed in 0.371393 second(s), 36 queries , Gzip On.
