查看: 1364|回复: 7
[求助] [求助]:xyp64进入看看(能否加个回退功能谢谢)
发表于 2005-4-15 09:11:43 | 显示全部楼层 |阅读模式
[编程申请]:编一个画线程序?
(defun c:test ()
  (princ "第1点坐标")
  (setq    x (getreal "\nX坐标 : ")
    y (getreal "\nY坐标<退出> : ")
    j 1
  (command "pline")
  (while (and x y)
    (command (list x y))
    (princ "\n")
    (princ (strcat "第" (rtos (setq j (1+ j))) "点坐标"))
    (setq x (getreal "\nX坐标<退出> : "))
    (if    x
      (setq y (getreal "\nY坐标<退出> : "))
  (command "")
  (princ)
发表于 2005-4-15 15:33:00 | 显示全部楼层
请试试下面的程序,他的画线功能比较强!
;;本函数返回 Nil or 坐标,st 为T or nil,表示可否返回字符串
(defun InputPoint(pp prompt$ st / p p1)
  (setvar "osmode" 173)
    (while (not (progn
                      (initget 129 "  ")
                      (if pp (setq P (getpoint pp (strcat "\n" prompt$))) (setq P (getpoint (strcat "\n" prompt$))))
                      (setq p1 p)
                      (if (= 'LIST (type p))
                          (setq p p)
                          (if (= p "")
                              t
                              (progn (setq p (read p))
                                                          (if st
                                   (if (= 'INT (type p))
                                     (setq p (searchpoint p))
                                     (setq p p1)
                                     (setq p nil)
          (alert "请输入正确的点号或坐标!")
  (setvar "osmode" 0)
   (if (= "" p) (setq p nil) (setq p p))
(defun XianLu (/ pstart psecond pnext pfirst ptl Next)
  ;(setvar "OSMODE" 169)
   (setq ptl '() Next T)
   (setq pstart (inputpoint nil "\n输入起点 :" nil) pfirst pstart)
   (setq ptl (cons pstart ptl))
   (setq psecond (inputpoint pstart "\n第二点 :" nil))
   (IF (not psecond) (abcdefg))
   (setq ptl (cons psecond ptl))
   (command "pline" pstart psecond)
   (while Next
        ;|(progn (initget 129 "Close Undo  ")
                 (or (= 'LIST (type (setq pnext (inputpoint psecond (strcat "\nClose[Undo<" "下一点" ">]偏距 :") t))))
                                   (if (= 'STR (type pnext)) (/= "" pnext))
          (if (= nil pnext) (setq pnext "Over"))
          (cond ((= "Over" pnext) (setq Next nil))
                ((= 'LIST  (type pnext)) (command pnext) (setq pstart psecond psecond pnext) (setq ptl (cons psecond ptl) Next T))
                ((= "C" (strcase (substr pnext 1 1))) (command pfirst) (SETQ PTL (CONS PFIRST PTL) Next nil))
                ((= "U" (strcase (substr pnext 1 1))) (if (> (length ptl) 2)
                                      (progn
                                           (command "u")
                                           (setq ptl (cdr ptl) psecond pstart pstart (cadr ptl))
                                       (if (> (length ptl) 1)
                                           (progn (command "u")
                                                  (setq ptl (cdr ptl)  pstart pfirst psecond (inputpoint pstart "\n第二点 :" nil))
                                                  (if psecond
                                                    (progn (setq ptl (cons psecond ptl)) (command psecond))
                                                    (setq Next nil)
                ((= "R" (strcase (substr pnext 1 1)))
                        (setq pnext (atof (substr pnext 2)))
                        (if (equal 0.0 pnext 0.00001)
                             (progn (setq ang1 (angle pstart psecond))
                                     (setq pstart psecond)
                                     (setq psecond (polar pstart (- ang1 (/ pi 2)) pnext))
                                     (command psecond)
                                     (setq ptl (cons psecond ptl) Next t)
                 ((= "L" (strcase (substr pnext 1 1)))
                                 (setq psecond (polar pstart (+ ang1 (/ pi 2)) pnext))
                                 (command psecond)
                            ((= "E" (strcase (substr pnext 1 1)))
                                                  (setq psecond (polar pstart ang1 pnext))
                                                 (command psecond)
                         ((< 0 (atof pnext)) (command (atof pnext))
                                             (setq pnext (getvar "lastpoint"))
    (command "")
;(setvar "OSMODE" 0)
    (setq ptl (reverse ptl))
 楼主| 发表于 2005-4-15 22:14:13 | 显示全部楼层
楼上我想这样:
在画给定坐标点的直线时,需要通过键盘输入坐标值
。这样的情况下当然是利用右边的数字键盘输入较为方便
。但若直接使用AutoCAD的pLine命令画直线,在x和y两个
坐标值之间需要输入一个逗号“,”作为分隔,而数字键
盘区又没有该逗号,所以仍然不方便。能否编一个直线程序只要求用户输入坐标值,
而由程序自动调用pLine命令画出直线,并能提示第一点、第二点.......坐标.因此用户不用离开数字键盘区就能完成工作。
发表于 2005-4-15 22:33:17 | 显示全部楼层
我劝你不要继续
实践证明这么做没什么效率
我一般在文本编辑软件里面写好xy值,存为scr文件,拉入cad即可
输入x y值的时候可用空格代替",",输入完成之后替换空格为",".
这么做方便核查,也方便修改,发现不对的地方,改文本格式的值,再次拉入cad即可
发表于 2005-4-15 23:02:26 | 显示全部楼层
楼上说得对,可以先编个坐标数据文件,然后用程序读入:
[php]
;;;加载通用函数
;;;下载:http://www.xdcad.net/forum/showthread.php?s=&threadid=325268
(load "xyp_lib")
;;;数据画线
;;;文本格式的一组坐标点调入AutoCAD自动绘制段线或多线段
;;;已知一组 X、Y ,并且已写入一文件TXT1.TXT,要根据此文件让其自动用“PLINE”绘出。
;;;文件内容格式如下:
;;;X坐标 Y坐标 Z坐标
;|实例:
123 456
222 333
444 555
777 888
888 999
999 754
111 755
333 666
555 777
(defun c:SJHX ()
  (cmdla0)
  (alert
    "数据格式:
  X坐标 Y坐标
  X坐标 Y坐标
  X坐标 Y坐标
  (prompt "\n\t稍候 ")
  (MKLA "建筑-红线" 1)
  (setq tn (getfiled "坐标数据文件(txt;dat;*)" "" "txt;dat;*" 2))
  (setq fle (findfile tn))
  (if (not fle)
    (setq fle (getfiled "请选择数据文件" "txt1" "txt;dat;*" 8))
  (if fle
    (progn
      (setq fn (open fle "r"))
      (command "pline")
      (while (setq pt (read-line fn))
        (princ ".")
        (command (read (strcat "(" pt ")")))
      (command "")
      (close fn)
    (princ "\n未选择数据文件,退出")
  (prompt " 完毕!")
  (cmdla1)
(PXYP "SJHX  (数据画线)")
[/php]
 楼主| 发表于 2005-4-16 12:13:19 | 显示全部楼层
(command (read (strcat "(" pt ")"))) 这段是什么意思?
发表于 2005-4-16 12:43:51 | 显示全部楼层
这个是把字符串转为表的基本手筋.
自己试试就清楚
(read (strcat "(" "这段 是什么 意思" ")")) ->(这段 是什么 意思)
 楼主| 发表于 2005-4-16 15:29:54 | 显示全部楼层
谢谢狂刀
GMT+8, 2026-11-6 06:12 , Processed in 0.426579 second(s), 46 queries , Gzip On.
