查看: 676|回复: 1
[求助]:如何在VBA里取得一个矩形的各个顶点?
发表于 2005-4-18 15:00:00 | 显示全部楼层 |阅读模式
我在VBA里已经取得一个矩形(多段线)lwpolyline对象,现在怎么获得这个矩形的各个顶点呢?我在这个对象的属性里找不到相关的数据,请各位高手帮帮忙:)谢谢
发表于 2005-4-18 20:26:19 | 显示全部楼层
我对VBA不太熟悉,试着写了一个,不过对精度如何控制,因为坐标点都是double型的,看起来太恐怖了。
[php]
Sub test()
Dim recobj As AcadEntity
Dim data As Variant
Dim point1 As String
Dim point2 As String
Dim point3 As String
Dim point4 As String
ThisDrawing.Utility.GetEntity recobj, point, "选择一个矩形:"
data = recobj.Coordinates
point1 = CStr(data(0)) + " , " + CStr(data(1))
point2 = CStr(data(2)) + " , " + CStr(data(3))
point3 = CStr(data(4)) + " , " + CStr(data(5))
point4 = CStr(data(6)) + " , " + CStr(data(7))
MsgBox "所选择的矩形四个点的坐标为:" & vbCrLf & point1 & vbCrLf & point2 & vbCrLf & point3 & vbCrLf & point4
End Sub
[/php]
GMT+8, 2026-11-3 20:14 , Processed in 0.435245 second(s), 34 queries , Gzip On.
