查看: 804|回复: 2
[ARX程序]:各位高手,帮我看看程序错在那吧
发表于 2005-5-12 22:12:02 | 显示全部楼层 |阅读模式
char chPathName[MAX_PATH];
   ::GetModuleFileName(GetModuleHandl ("HzGyk.arx"),chPathName,255);
  CString strPathName=chPathName;
int nPos=strPathName.ReverseFind('\\');
CString strPath=strPathName.Left(nPos+1);
CString strFile=strPath+"Template\\"+"gyk3.dwg";
AcDbObjectId id;
AcDbObjectIdArray list;
AcDbDatabase extDatabase( Adesk::kFalse );
Acad::ErrorStatus es=extDatabase.readDwgFile(strFile);
if(es!=Acad::eOk)
    acutPrintf( "Error reading DWG!" );
     return;
AcDbBlockTable* pBT;
if (Acad::eOk != extDatabase.getSymbolTable( pBT, AcDb::kForRead ))
    acutPrintf( "Error getting BlockTable of DWG" );
   return;
AcDbBlockTableRecord* pBTR;
es = pBT->getAt( ACDB_MODEL_SPACE, pBTR, AcDb::kForRead );
pBT->close();
if (Acad::eOk != es)
   acutPrintf( "Error getting model space of DWG" );
   return;
AcDbBlockTableRecordIterator* pIT;
if (Acad::eOk != pBTR->newIterator( pIT ))
   acutPrintf( "Error iterating model space of DWG" );
   pBTR->close();
return;
for ( ; !pIT->done(); pIT->step())
     if (Acad::eOk == pIT->getEntityId( id ))
         list.append( id );
         AcDbEntity *pEnt;
        if ( Acad::eOk == pIT->getEntity(pEnt, AcDb::kForRead))
                                        AcDbObjectId obj;
                                        if ((obj = pEnt->extensionDictionary())
                                                != AcDbObjectId::kNull)
                                                AcDbDictionary *pDict = NULL;
                                                acdbOpenObject(pDict, obj, AcDb::kForWrite);
                                                if (pDict) {
                                                        pDict->setTreatElementsAsHard(Adesk::kTrue);
                                                        pDict->close();
                                        pEnt->close();
                delete pIT;
                pBTR->close();
                if (list.isEmpty()) {
                        acutPrintf( "No entities found in model space of DWG" );
                        return;
                AcDbDatabase *pTempDb;
                es= extDatabase.wblock( pTempDb, list, AcGePoint3d::kOrigin );
                if(es!=Acad::eOk)
                        acutPrintf( "wblock failed!" );
                        return;
                es=acdbHostApplicationServices()->workingDatabase()->insert( AcGeMatrix3d::kIdentity, pTempDb );
                if(es!=Acad::eOk)
                        acutPrintf( "insert failed!" );
                        return;
                delete pTempDb;
                //遍历模型空间,找到所有实体,建立一个内部块,然后再建立一个块引用.
                AcDbBlockTableRecord *pgykBTR=new AcDbBlockTableRecord();
                pgykBTR->setName("gyk3");
                if(pgykBTR==NULL)
                        acutPrintf("Create gyk Block table make error!");
                        return;
                es=acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBT,AcDb::kForWrite);
                if(es!=Acad::eOk)
                        acutPrintf("Can't open symbol table!");
                        return;
                AcDbObjectId blockId;
                es=pBT->add(blockId,pgykBTR);
                if(es!=Acad::eOk)
                        acutPrintf("Can't add block table record into the block table!");
                        return;
                es=pBT->getAt(ACDB_MODEL_SPACE,pBTR,AcDb::kForWrite);
                if(es!=Acad::eOk)
                        acutPrintf("Can't get symbol table record!");
                        return;
                es=pBT->close();
                if(es!=Acad::eOk)
                        acutPrintf("Can't close the block table!");
                        return;
                es= pBTR->newIterator( pIT );
                if(es!=Acad::eOk)
                        return;
                /*es=pBTR->close();
                if(es!=Acad::eOk)
                        acutPrintf("Can't close the block table record!");
                        return;
                for(pIT->start(true);!pIT->done();pIT->step())
                        AcDbEntity* pEnt;
                        es=pIT->getEntity(pEnt,AcDb::kForRead,false);
                        if(es!=Acad::eOk)
                                acutPrintf("Can't get entity in the model space!");
                                return;
                        AcDbObjectId entId;
            es=pgykBTR->appendAcDbEntity(entId,pEnt);
                        if(es!=Acad::eOk)
                                acutPrintf("Can't append entity to block table!");
                                return;
                        es=pEnt->erase();
                        if(es!=Acad::eOk)
                                acutPrintf("Can't erase the entity in the model space!");
                                return;
                delete pIT;
                pBTR->close();
       delete pgykBTR;
                AcDbBlockReference *pgykRef=new AcDbBlockReference();
                if(pgykRef==NULL)
                        acutPrintf("memory error!");
                        return;
                es=pgykRef->setBlockTableRecord(blockId);
                if(es!=Acad::eOk)
                        acutPrintf("set block reference's block make error!");
                        return;
                es=pgykRef->setPosition(AcGePoint3d(0,0,0));
                if(es!=Acad::eOk)
                        acutPrintf("set block reference's position make error!");
                        return;
                es=pgykRef->setRotation(0.0);
                if(es!=Acad::eOk)
                        acutPrintf("set block reference's rotation make error!");
                        return;
                es=pgykRef->setScaleFactors(AcGeScale3d(420,297,1.0));
                if(es!=Acad::eOk)
                        acutPrintf("set block reference's scale factors make error!");
                        return;
                es=acdbHostApplicationServices()->workingDatabase()->getSymbolTable(pBT,AcDb::kForRead);
                if(es!=Acad::eOk)
                        acutPrintf("Can't get block table!");
                        return;
                if(es!=Acad::eOk)
                        acutPrintf("Can't get model block table!");
                        return;
                es=pBT->close();
                if(es!=Acad::eOk)
                        acutPrintf("Can't close block table!");
                        return;
                es=pBTR->appendAcDbEntity(blockId,pgykRef);
                if(es!=Acad::eOk)
                        acutPrintf("Can't append entity to model space!");
                        return;
                pBTR->close();
                delete pgykRef;
各位大哥,大姐,帮俺看看吧,我调了一晚上,都没发现那里有错误.小弟在这里先谢了.
发表于 2005-5-13 12:40:31 | 显示全部楼层
这样让人家看代码和累, 先说说你程序的基本目的,调试出了什么问题,自己怀疑哪里有问题。这样自然有高手点拨。
发表于 2005-5-13 15:38:26 | 显示全部楼层
debug就0可以发现哪个地方出问题了
实在找不出那个地方的问题 再吧那个地方贴出来
GMT+8, 2026-11-6 08:04 , Processed in 0.439207 second(s), 36 queries , Gzip On.
