查看: 1188|回复: 3
[求助]:各位高手,帮我看看程序错在那吧
发表于 2005-5-16 09:47:44 | 显示全部楼层 |阅读模式
void m_line(AcGePoint3dArray ptAr,CString linename,CString layer,double lwidth,int colorindex,double mheight)
        //        lin.gxDrawSplinePolyline(plId,ptAr,3,4,false,layer,"daolu");
        ///////////////////////AcDb::k2dQuadSplinePoly ,0,Adesk::kTrue,Width,Width);
        Clayer lay;
        lay.gxSetCurLayer(layer,true,colorindex,NULL);//设置当前图层
        AcDb2dPolyline *Newline1=new AcDb2dPolyline(AcDb::k2dQuadSplinePoly/*k3dSimplePoly*/,ptAr,mheight,Adesk::kFalse,lwidth,lwidth);
        if(Newline1->setColorIndex(colorindex)!=Acad::eOk)
                Newline1->close();
                return;
        CString str;
        str=linename;
        if(str.GetLength()>0)
                AcDbObjectId lineTypeId;
                if(gxgetLinetypeIdFromString(linename,lineTypeId))
                        if(Newline1->setLinetype(lineTypeId)!=Acad::eOk)
                                Newline1->close();return ;
                        if(Newline1->setLinetypeScale(1)!=Acad::eOk)
                                Newline1->close();return;
//取表名
        AcDbBlockTable *pBTable1;
        acdbHostApplicationServices()->workingDatabase()
                ->getSymbolTable(pBTable1, AcDb::kForRead);
        AcDbBlockTableRecord *pBTRecord1;
        pBTable1->getAt(ACDB_MODEL_SPACE,pBTRecord1,AcDb::kForWrite);
        pBTable1->close();
        pBTRecord1->close();
        AcDbObjectId plId1;
        if(pBTRecord1->appendAcDbEntity(plId1,Newline1)!=Acad::eOk)//运行到此处出错,为什么呢?
                Newline1->close();
        Newline1->close();
发表于 2005-5-16 10:16:23 | 显示全部楼层
Clayer lay;
Newline1->close();
return;
CString str;
str=linename;
//取表名
pBTable1->close();
//pBTRecord1->close();
AcDbObjectId plId1;
Newline1->close();
Newline1->close();
发表于 2005-5-16 10:19:04 | 显示全部楼层
已经close了 所以不能appendEntity
 楼主| 发表于 2005-5-16 10:48:59 | 显示全部楼层
谢谢,问题解决了
GMT+8, 2026-11-22 11:26 , Processed in 0.195021 second(s), 17 queries , Gzip On, File On.
