查看: 1881|回复: 2
[求助]:ARX改属性定义层
发表于 2007-11-1 18:12:47 | 显示全部楼层 |阅读模式
我是这样写的,可是运行错
Acad::ErrorStatus ConversionAttlay(CString layName,CString oldName)
        Acad::ErrorStatus es;
        AcDbObjectId objId;
        AcDbObject *pObj;
        AcDbEntity *pEn;
        ads_name ssName;
        struct resbuf eb;
        eb.restype=0;
        eb.resval.rstring="insert";
        eb.rbnext=NULL;
        if(RTNORM ==acedSSGet("X",NULL,NULL,&eb,ssName))
                long i;
                acedSSLength(ssName,&i);
                for(int j=0;j<i;j++)
                        AcDbBlockTableRecord *pBlockDef;
                        AcDbBlockTableRecordIterator *pIt;
                        AcDbEntity *pEn;
                        ads_name ent;
                        if (RTNORM !=acedSSName(ssName, j, ent))
                                acedSSFree(ssName);
                                return Acad::eNotAnEntity;
                        es = acdbGetObjectId( objId, ent );
                        if(es!=Acad::eOk){
                                acedSSFree(ssName);
                        return es;
                        es = acdbOpenObject(pObj, objId, AcDb::kForRead);
                        if(es!=Acad::eOk){
                                acedSSFree(ssName);
                                return es;
                        if(pObj->isKindOf(AcDbBlockTableRecord::desc())==Adesk::kTrue)
                                pBlockDef=AcDbBlockTableRecord::cast(pObj);
                        es=pBlockDef->newIterator(pIt);
                        if(es!=Acad::eOk){
                                acedSSFree(ssName);
                                pBlockDef->close();
                                return es;
                        for(pIt->start();!pIt->done();pIt->step())
                                pIt->getEntity(pEn,AcDb::kForWrite);
                                if(pEn->layer()==oldName)
                                        es=pEn->setLayer(layName);
                                        if(es!=Acad::eOk){
                                                acedSSFree(ssName);
                                                delete pIt;
                                                pEn->close();
                                                return es;
                                es=pEn->close();
                                if(es!=Acad::eOk){
                                        acedSSFree(ssName);
                                        delete pIt;
                                        pEn->close();
                                        pBlockDef->close();
                                        pObj->close();
                                        return es;
                                delete pIt;
                                es=pEn->close();
                                if(es!=Acad::eOk){
                                        acedSSFree(ssName);
                                        pBlockDef->close();
                                        pObj->close();
                                        return es;
                        es=pBlockDef->close();
                        if(es!=Acad::eOk){
                                acedSSFree(ssName);
                                pObj->close();
                                return es;
                        es=pObj->close();
                        if(es!=Acad::eOk){
                                acedSSFree(ssName);
                                pObj->close();
                                return es;
        acedSSFree (ssName);
        return Acad::eOk;
发表于 2007-11-2 09:49:56 | 显示全部楼层
acedSSGet  得到的是 AcDbEntity  ,再用   AcDbEntity::layerId Function 得到 AcDbBlockTableRecord
 楼主| 发表于 2007-11-2 18:35:48 | 显示全部楼层
多谢了,问题解决了.
我是用attributeIterator遍历块引用里的属性并修改层.
GMT+8, 2026-11-22 08:09 , Processed in 0.599587 second(s), 13 queries , Gzip On, File On.
