查看: 1705|回复: 3
[求助] [求助]:菜鸟请教程序错误处理:未知命令“”
发表于 2007-2-26 17:43:15 | 显示全部楼层 |阅读模式
以下是一个列乘的小程序,运算可以执行,但总提示未知命令:“test”,大家帮忙看下,谢谢!
(defun c:test ()
   (setvar "cmdecho" 0)
   (setq odim (getvar "dimzin"))
   (setvar "dimzin" 1)
   (prompt "\n请选择第一列乘数:")
   (setq ss1 (ssget (list (cons 0 "TEXT"))))
   (prompt "\n请选择第二列乘数:")
   (setq ss2 (ssget (list (cons 0 "TEXT"))))
   (if (null (setq ent_f (getreal "\n输入小数点位数[2]:")))
       (setq ent_f 2)
   (setq pt1 (getpoint "\n选择基点:")
         pt2 (getpoint pt1 "\n指定置放点:")
   (setq ent1 (entlast))
   (command "copy" ss2 "" pt1 pt2 "")
   (setq ss3 (ssadd))
   (while (setq ent1 (entnext ent1))
          (ssadd ent1 ss3)
   (setq ss1n (sslength ss1)
         ss2n (sslength ss2)
   (setq i 0)
   (if (= ss1n ss2n)
       (repeat ss1n
           (setq ent3 (entget (ssname ss3 i)))
           (setq y3 (caddr (assoc 10 ent3)))
           (setq ii 0)
           (repeat ss1n
                   (if (= y3 (caddr (assoc 10 (entget (ssname ss1 ii)))))
                       (setq text1 (atof (cdr (assoc 1 (entget (ssname ss1 ii))))))
                   (if (= y3 (caddr (assoc 10 (entget (ssname ss2 ii)))))
                       (setq text2 (atof (cdr (assoc 1 (entget (ssname ss2 ii))))))
                   (setq ii (1+ ii))
           (setq text3 (rtos (/ (* text1 text2) 1000) 2 (fix ent_f)))
           (setq ent3 (subst (cons 1 text3) (assoc 1 ent3) ent3))
           (entmod ent3)
           (setq i (1+ i))
   (setvar "dimzin" odim)
   (princ)
发表于 2007-2-26 17:58:41 | 显示全部楼层
Try this==>
(command "copy" ss2 "" pt1 pt2)
发表于 2007-2-27 08:23:15 | 显示全部楼层
多了双引号,相当于多按了空格键,故提示未知命令。
 楼主| 发表于 2007-2-27 19:40:30 | 显示全部楼层
可以了。
谢谢两位!
GMT+8, 2026-11-22 08:18 , Processed in 0.504080 second(s), 16 queries , Gzip On, File On.
