查看: 1373|回复: 1
[推荐]:我收集的程序
发表于 2005-5-22 15:23:08 | 显示全部楼层 |阅读模式
编制一个能够计算两点之间距离的程序,即可以使用鼠标选取两点,然后在命令行中直接给出这两点的距离。
(defun C:dn(/pt1 pt2d)
  (graphsar)
  (setvar "CMDECHO"0)
  (setq pt1 (getpoint"Pick the first point"))(terpri)
  (setq pt2 (getpoint"Next Point"pt2)(terpri)
  (setq d (distance pt1 pt2))
  (promat "Runing Distance:")(promat (rtos d 4 4))
       (while
       (setq pt1 (getpoint"First Point:"))(terpri)
       (setq pt2 (getpoint"Next Point"pt1))(terpri)
       (setq d(+distance pt1 pt2)d))
    (promat "Total Distance:")(promat (rtos d 4 4))
    (princ)
编制一个程序,能够将被选择的当前层的物体复制到另一个指定的层中去,但是物体仍然在原来的层中保留。
(defun C:CLONE(/s l)
    (setvar "cmdecho"0)
    (if
       (and
          (setq s (ssgetssss))
          (not (zerop (sslength s)))
          (not (zerop (strlen(setp1 (getstring"\n Layer to copy to"))))))
          (Command "copy"s"""@""@""change"s"""p""la"l"")
          (promat"Invalid")
           (progn))
发表于 2005-5-22 15:58:42 | 显示全部楼层
Re: [推荐]:我收集的程序
最初由 zhou041224 发布
[B]编制一个能够计算两点之间距离的程序,即可以使用鼠标选取两点,然后在命令行中直接给出这两点的距离。
  (graphsar)
  (setvar "CMDECHO"0)
  (setq pt1 (getpoint"Pick the first poin... [/B]
上载前最好进行测试。
这么多错误的东东,有点像“垃圾”,如果真是搜集的,不就像在拣破烂!
言过了……
GMT+8, 2026-11-22 08:35 , Processed in 0.309058 second(s), 12 queries , Gzip On, File On.
