查看: 1041|回复: 2
[求助]:ARX (VC60+ACAD2002)自定义实体类读写出错
发表于 2005-6-7 18:32:10 | 显示全部楼层 |阅读模式
定义成员:
        AcGePoint3d                mFirst, mSecond, mThree, mFour;
        AcGePoint3d                mCenter;
Acad::ErrorStatus cascoCEntity::dwgInFields(AcDbDwgFiler* pFiler)
        assertWriteEnabled();
        Acad::ErrorStatus es;
        // Call dwgInFields from AcDbEntity
        if ((es = AcDbEntity::dwgInFields(pFiler)) != Acad::eOk) {
                return es;
        // Read version number.
        Adesk::UInt16 version;
        pFiler->readItem(&version);
        if (version > VERSION_CASCOCENTITY)
                return Acad::eMakeMeProxy;
        // Read the data members.
        switch (version)
        case (1):
                // TODO: here you can file datamembers not
                //       created by the ObjectARX Add-In.
                pFiler->readItem(&mCenter);
                pFiler->readItem(&mFirst);
                pFiler->readItem(&mSecond);
                pFiler->readItem(&mThree);
                pFiler->readItem(&mFour);
                break;
        return pFiler->filerStatus();
Acad::ErrorStatus cascoCEntity::dwgOutFields(AcDbDwgFiler* pFiler) const
        assertReadEnabled();
        // Call dwgOutFields from AcDbEntity
        if ((es = AcDbEntity::dwgOutFields(pFiler)) != Acad::eOk) {
                return es;
        // Write version number.
        pFiler->writeItem((Adesk::UInt16) VERSION_CASCOCENTITY);
        // Write the data members.
                pFiler->writeItem(mCenter);
                pFiler->writeItem(mFirst);
                pFiler->writeItem(mSecond);
                pFiler->writeItem(mThree);
                pFiler->writeItem(mFour);
Acad::ErrorStatus cascoCEntity::dxfInFields(AcDbDxfFiler* pFiler)
        struct resbuf rb;
        if ((AcDbEntity::dxfInFields(pFiler) != Acad::eOk) ||
            !pFiler->atSubclassData("cascoCEntity"))
        pFiler->readItem(&rb);
        if (rb.restype != AcDb::kDxfInt16) {
                pFiler->pushBackItem();
                pFiler->setError(Acad::eInvalidDxfCode,
                                "nError: expected object version group code %d",
                                 AcDb::kDxfInt16);
        } else {
                Adesk::UInt16 version = rb.resval.rint;
    if (rb.restype != AcDb::kDxfXCoord)
                mCenter = asPnt3d(rb.resval.rpoint);
    if (rb.restype != AcDb::kDxfXCoord +1)
                mFirst = asPnt3d(rb.resval.rpoint);
    if (rb.restype != AcDb::kDxfXCoord +2)
                mSecond = asPnt3d(rb.resval.rpoint);
    if (rb.restype != AcDb::kDxfXCoord +3)
                mThree= asPnt3d(rb.resval.rpoint);
    if (rb.restype == AcDb::kDxfXCoord +4)
                mFour = asPnt3d(rb.resval.rpoint);
Acad::ErrorStatus cascoCEntity::dxfOutFields(AcDbDxfFiler* pFiler) const
        if ((es = AcDbEntity::dxfOutFields(pFiler)) != Acad::eOk)
                return es;
        // Write subclass marker.
        pFiler->writeItem(AcDb::kDxfSubclass, "cascoCEntity");
        pFiler->writeItem(AcDb::kDxfInt16, (Adesk::UInt16) VERSION_CASCOCENTITY);
        pFiler->writeItem(AcDb::kDxfXCoord, mCenter);
        pFiler->writeItem(AcDb::kDxfXCoord, mFirst);
        pFiler->writeItem(AcDb::kDxfXCoord, mSecond);
        pFiler->writeItem(AcDb::kDxfXCoord, mThree);
        pFiler->writeItem(AcDb::kDxfXCoord, mFour);
        return es;
请问我这个自定义实体类保存读取出错在哪儿?
还有本例中夹点函数、拉伸函数、变换函数以及对象捕捉点函数如何编程?
Acad::ErrorStatus cascoCEntity::getGripPoints(AcGePoint3dArray& gripPoints,
                                              AcDbIntArray& osnapModes,
                                              AcDbIntArray& geomIds) const
Acad::ErrorStatus cascoCEntity::getStretchPoints(AcGePoint3dArray& stretchPoints) const
Acad::ErrorStatus cascoCEntity::moveGripPointsAt(const AcDbIntArray& indices,
                                                 const AcGeVector3d& offset)
Acad::ErrorStatus cascoCEntity::moveStretchPointsAt(const AcDbIntArray& indices,
请各位大侠帮帮忙呀,求求你们了。
发表于 2005-6-7 19:17:32 | 显示全部楼层
pFiler->readItem(&version);[/COLOR]
switch (version)
case (1):
读了两次吧
 楼主| 发表于 2005-6-8 08:54:00 | 显示全部楼层
谢谢binbin的解答,问题就是出在这儿。有空的时候看看这个帖子http://www.mjtd.com/bbs/dispbbs. ... ID=38142&page=1,方便的化给俺一个从entity派生的例子。谢谢了!
GMT+8, 2026-11-22 09:12 , Processed in 0.362230 second(s), 14 queries , Gzip On, File On.
